May 21, 2013, 03:48:49 PM *
Members: 6617  •  Posts: 178491  •  Topics: 18114
Author Topic: Austria Microsystems AS3935 Franklin Lightning Sensor IC  (Read 3274 times)
miraculon
« on: June 03, 2012, 06:39:27 PM »
I came across an interesting IC dedicated to lightning detection. I am not much of a programmer, but this could be a cool project for someone who is so inclined. Or maybe, one of the weather equipment suppliers like Davis or AcuRite could integrate it into one of their designs.
It has both SPI and I2C interfaces. Hardware wise, it looks like it requires minimal external circuitry.
http://www.ams.com/eng/Products/RF-Products/Lightning-Sensor/AS3935
I found the datasheet at Future Electronics: http://www1.futureelectronics.com/doc/AUSTRIAMICROSYSTEMS/AS3935.pdf
I also found an Evaluation kit, completely assembled that also includes a "Lightning Emulator" to test it. I found the eval kit manual at:
http://media.digikey.com/pdf/Data%20Sheets/Austriamicrosystems%20PDFs/AS3935_EvalManual_AN.pdf
« Last Edit: June 04, 2012, 08:09:41 PM by miraculon » Logged
rdsman
Senior Member
« Reply #1 on: January 01, 2013, 02:20:40 PM »
I've ordered a couple of these to play with:
http://embeddedadventures.com/as3935_lightning_sensor_module_mod-1016.html
Maybe I can emulate the Boltek!
miraculon
« Reply #2 on: January 01, 2013, 05:50:54 PM »
That is a nice project board. Keep us posted on your progress. What are you going to control it with?
Greg
rdsman
Senior Member
« Reply #3 on: January 01, 2013, 07:21:09 PM »
I don't really have a plan for them.  I will probably just write some code and see if they work well enough to pursue a "real project" using one.
kd7eir
« Reply #4 on: February 12, 2013, 12:29:05 PM »
I have a couple AS3935 Franklin Demo Board kits coming in the mail from Future Electronics.  I will be evaluating these for making a realistically priced lightning detector for hobby use.  There is really no reason for a lightning detector to cost hundred of dollars, it's just not that complicated to implement.  My plan is to link the AS3935 with an ATMega microprocessor for display and analysis purposes.  I believe that this could be produced for well under $100 USD for a basic system, and well under $200 USD for a multi-sensor system to allow for triangulation of the strikes.
Bushman
« Reply #5 on: February 12, 2013, 03:16:39 PM »
I'd be in for one of those!  Keep us posted.
rdsman
Senior Member
« Reply #6 on: February 12, 2013, 07:18:32 PM »
I2C or SPI?  While the chip supports both, my BOB only does I2C, so I guess that I am leaning in that direction.
kd7eir
« Reply #7 on: February 12, 2013, 07:33:00 PM »
I definitely plan to use I2C for the interface.
rdsman
Senior Member
« Reply #8 on: February 16, 2013, 07:41:26 PM »
I am leaning towards a stand alone lightning detector, with a USB interface.  It would plot time /distance.  The vertical line colors could change based on distance, intensity, etc.  It could look something like the picture below:
kd7eir
« Reply #9 on: February 22, 2013, 06:08:00 PM »
I finally got the  AS3935 demonstration kits in, so now I can start working on the code and getting some testing done.
miraculon
« Reply #10 on: April 16, 2013, 12:16:57 PM »
Any further progress on these projects? Just wondering.
Greg H
rdsman
Senior Member
« Reply #11 on: April 16, 2013, 12:42:58 PM »
I did get some code written that would do the calibration/sensitivity functions correctly.  It can detect a grill starter and clasify it as a "Disturber".  One big problem - No Lightning has been around since!
So it's going about the same as my Si4707 Weather Band receiver project - I only get to test it on Wednesdays during the Required Weekly Test (RWT).
rdsman
Senior Member
« Reply #12 on: May 19, 2013, 09:45:24 AM »
A line of thunderstorms came through yesterday and early this morning.  They lasted just long enough for me to tweak my code.  The screenshot below shows the results.  I plan to let it run for a while, clean up the code, then I will post it for anyone interested.
Page created in 0.104 seconds with 18 queries.
