May 22, 2013, 01:46:21 PM *
Members: 6617  •  Posts: 178566  •  Topics: 18123
Author Topic: Monthly Report data not updating since upgrade  (Read 3174 times)
Stetson1
Stetson Hills Weather
« on: May 25, 2012, 12:09:05 PM »
So I upgraded to 10.37R 26 last Friday and since then no data is showing up in my station monthly report, any ideas?
Todd
Weather Underground PWS KCOCOLOR131
MADIS ID: D4524
Weather Display
« Reply #1 on: May 25, 2012, 02:27:16 PM »
I do not have any other reports of this problem, and I do not have this problem myself
so
try
action, convert WD logfiles to data files
then click on convert
(assuming your WD logfile for the current month is OK)
Stetson1
« Reply #2 on: May 25, 2012, 02:45:20 PM »
Is there anyway to see why it is not uploading the May2012.htm file? I've converted and all the data is there but the file is simply not being uploaded.
Todd
MADIS ID: D4524
Weather Display
« Reply #3 on: May 25, 2012, 03:08:48 PM »
a bit confusing
I took it from your post that there was no data
not that it was not uploading
make sure you have it set to do the av/ext upload in the ftp/internet setup, upload times setup
is the file updated OK on your PC?
any errors in WD under view, program event log?
mackbig
« Reply #4 on: May 27, 2012, 07:47:48 AM »
WD
I think Todd is talking about seeing the history on his Saratoga templated site..... so its not really a WD issue.
Todd
Were you using a very old version of WD?   and do you have an old version of Ken's templates/wxhistory.php.
There was a change a while back, cant recall exactly when, but after that I had the same issue.  Ken told me to update the wxhistory.php from the current full release.  It fixed it instantly.
Andrew
Weather Display
« Reply #5 on: May 27, 2012, 05:51:11 PM »
that sounds like it
(was a change in case of the file names used)
Stetson1
« Reply #6 on: May 29, 2012, 05:58:10 PM »
Will try it tonight. The file May2012.htm is in the webfiles, just not making it to the server for whatever reason.
Todd
MADIS ID: D4524
Weather Display
« Reply #7 on: May 30, 2012, 12:18:08 AM »
well thats a different issue
any errors under view, program event log?
which version of WD did you upgrade from?
do you have ticked to do the daily av/ext uploads under control panel, FTP/ internet setup, upload times?
Stetson1
« Reply #8 on: May 30, 2012, 12:37:35 AM »
I updated from two versions previous (sorry can't remember the exact number). I will check for errors, haven't done that yet. The daily uploads are the same as they were prior to the upgrade.
At this point I am somewhat lost, the file quit updating after the last upgrade so I assume it has something to do with it. Need to go check the logs now.
Todd
MADIS ID: D4524
Stetson1
« Reply #9 on: May 30, 2012, 10:00:34 AM »
So no errors in the log last night. I double checked all the settings and they are the same. Decided to downgrade to an earlier version, nothing, in fact it seemed that other files were now not updating either.
When all else fails, reboot. I did and that didn't seem to help but I did catch the FTP program in WD attempting to upload files and locking up. Killed it off and restarted it, voila all files are now uploading. Not sure what caused it, will upgrade to 28 tonight and see if all runs well. Probably the FTP process got stuck somewhere and just needed a kick.
Thanks for all the input.
Todd
MADIS ID: D4524
Weather Display
« Reply #10 on: May 30, 2012, 05:28:39 PM »
sounds like some sort of problem with the FTP
Stetson1
« Reply #11 on: June 12, 2012, 02:09:27 PM »
So it ran until the end of May and stopped again. No June data even though the June2012.htm file is in the webfiles directory. Rebooted, restarted and nothing. Not sure what is going here now, checked the FTP program and it seems to be running fine.
Todd
MADIS ID: D4524
Stetson1
« Reply #12 on: June 13, 2012, 10:19:39 PM »
Doing some checking and it seems the month to date graph is also not being uploaded. Trying to catch the FTP program and figure out what is updated is difficult. I am not sure what changed, running 30 now but not all the files that used to upload do and not all seem to be created anymore. Is there somewhere that I can check to see what is happening, no program events are listed in the log and everything on the FTP/Internet looks like it always has.
Any ideas are welcome at this point, not sure what to do but not everything is working as it should.
Todd
MADIS ID: D4524
Weather Display
« Reply #13 on: June 13, 2012, 11:28:50 PM »
no problems with uploads here for my setup, even for the month to date graph
.zip and email me your settings files and I will check/test here with those
Stetson1
« Reply #14 on: June 17, 2012, 01:15:18 AM »
No errors in the events log. Will get the file to you tomorrow.
Todd
MADIS ID: D4524
Weather Display
« Reply #15 on: June 21, 2012, 10:56:26 PM »
I one of  the problems
you have selected to upload a time stamped web cam image every minute
in the ftp/internet setup, web cam upload setup
change that to just jpegwebcam.jpg (and not 1800jpgwebcam.jpg)
also you have set some of the files in the customise internet and file creation setup to upload but you do not have any times set to create those files
Stetson1
« Reply #16 on: June 22, 2012, 12:26:23 PM »
Fixed all the noted issues, still not seeing the monthly report updating. Maybe a reboot is in order.
Todd
MADIS ID: D4524
Weather Display
« Reply #17 on: June 22, 2012, 01:33:33 PM »
it wont update until just after midnight though
did you wait until then?
once I fixed up the settings problems in your settings, I see the time to just after midnight and let WD go through to 15 minutes past midnight and it was uploaded OK in testing here with your settings
I also notice you are HTTP downloading a file every minute from another web site
I would reduce that to say every 10 minutes (untick the every minute setting)
as I doubt the information you are downloading is going to change that much I would say they would not be impressed in you sraping their web site every minute
« Last Edit: June 22, 2012, 01:35:05 PM by Weather Display » Logged
Stetson1
« Reply #18 on: June 22, 2012, 02:19:32 PM »
Which site is that?
MADIS ID: D4524
Weather Display
« Reply #19 on: June 22, 2012, 03:16:51 PM »
something about river status
in the HTTP download in the FTP/Internet setup
Stetson1
« Reply #20 on: June 22, 2012, 05:44:24 PM »
Ah, that is running every 15 minutes, I think I just changed it to an hour. Just river data which is not going to be on the new revision to the site.
Todd
MADIS ID: D4524
Weather Display
« Reply #21 on: June 24, 2012, 04:13:00 AM »
you had ticked the 1 minute setting....so it was downloading every minute
untick that
Stetson1
« Reply #22 on: June 26, 2012, 02:27:56 PM »
Everything is working again, thanks for the help.
Todd
MADIS ID: D4524
Page created in 0.112 seconds with 20 queries.
