| Monthly Report data not updating since upgrade |
| (1/5) > >> |
Stetson1: So I upgraded to 10.37R 26 last Friday and since then no data is showing up in my station monthly report, any ideas? Todd |
Weather Display: I do not have any other reports of this problem, and I do not have this problem myself so try action, convert WD logfiles to data files then click on convert (assuming your WD logfile for the current month is OK) |
Stetson1: Is there anyway to see why it is not uploading the May2012.htm file? I've converted and all the data is there but the file is simply not being uploaded. Todd |
Weather Display: a bit confusing I took it from your post that there was no data not that it was not uploading make sure you have it set to do the av/ext upload in the ftp/internet setup, upload times setup is the file updated OK on your PC? any errors in WD under view, program event log? |
mackbig: WD I think Todd is talking about seeing the history on his Saratoga templated site..... so its not really a WD issue. Todd Were you using a very old version of WD? and do you have an old version of Ken's templates/wxhistory.php. There was a change a while back, cant recall exactly when, but after that I had the same issue. Ken told me to update the wxhistory.php from the current full release. It fixed it instantly. Andrew |
| Navigation |
| Message Index |
| Next page |
