June 19, 2013, 06:28:13 AM *
Members: 6695  •  Posts: 181358  •  Topics: 18410
Author Topic: Weather prediction software  (Read 2279 times)
meteorologist
« on: May 19, 2012, 06:23:39 AM »
 Hello,
 Do you need very precise weather forecasting software?
 The spring thunderstorms can be forecasted very well with weather prediction model. It's a software for Linux, running on fast hardware, downloading data from a meteo center, making a lot of mathematical calculations.
 The software display variables like temperature, wind, pressure, moisture, precipitation, cape, 0-1 and 0-6 km  wind shear, helicity, vorticity, heights, specific humidity, mixing ratio, water vapor pressure, stom motion, virtual temperature, omega, static stability, potential temperature, theta-e, dew point depression, ground temperature, surface pressure, storm relative flow at given levels, accumulated rainfall, potential vorticity, lifted condensation level, level of free convection, radar reflectivity, infra red simulated satellite image, cloud top temperature, divergence, convergence, energy helicity index, precipitable water vapor, density, virtual potential temperature, wet bulb temperature,  ageostrophic wind, vorticity generation potential, vertical velocity, absolute vorticity and others.
 The JET weather outlook software forecast various weather phenomena, like cloud type - cirrus, cirrostratus, cirrocumuls,  altostratos, altocumulus, nimbostratus, cumulus, cumulus humilis, cumulus humilis fractos, mediocris, congestus/ towering cumulus, Cb, singlecell, multicell, supercell, mini supercell, pulse storm, thunder-storm, thunder-snow, microburst, convective inversion, rain, snow, sleet, frozen ground, shower, low visibility due to mist, fog, industrial fog, warm and cold air advection, blizzard, extreme cold temperatures, fire danger due to low huimidity and high winds, low visiblity due to intensive precipitation, turbulence, jet stream, jet streak, floods, flash floods, wind chill, lightnings, tornado watch, wind categroy from Beaufort and others.
 The software is continously developed by very bright scientist, currently the temperature bias between observed and forecasted temperature in the range 0-18 forecast hours is around 0.8 degree C and in the next version will be around 0.4C.
 Do you like all that? I can go further into details about the math, physics, and meteorological side of the software.
 I you need it, I will be happy to install it for you. Mail: stormlaboratory@gmail.com.
 Best regards,
 Angel Dimitrov
 Only for US/Canada
ocala
« Reply #1 on: May 19, 2012, 08:46:20 AM »
.08 degree C for 18 hours? That's pretty impressive.
Would this be available in the US?
meteorologist
« Reply #2 on: May 19, 2012, 09:31:01 AM »
 Hello,
 The 0.8 degree C bias is an average value. In the next version this value will be around 0.4C and later on even more precise. Sometimes the temperature is few degrees lower and sometimes higher, no more than 1-3 degrees, 5 is rare. And as better is the surface observational network, like synoptic stations, airports, mesonet, and private weather stations, as better is the forecast.
 Yes. The model can be started for any place of the Earth.
 I added objective analysis, so the initial  conditions of the model are improved with local observations. This increase, at least in theory, the forecast quality.
 Do you have a Linux Fedora? Are you familiar with the Linux console? Please send me a mail for details.
 Best regards,
 Angel Dimitrov
« Last Edit: May 28, 2012, 06:08:06 AM by meteorologist » Logged
jgillett
unnamed weather station, Boltek, Win7 Pro
« Reply #3 on: May 19, 2012, 04:20:37 PM »
Is this something that you host that we can access and possibly upload to our personal sites, or do we host it ourselves?
W7JKG
meteorologist
« Reply #4 on: May 20, 2012, 04:22:21 AM »
 Hello,
 The both options are available, as you prefer. If you don't have time to setup a server, that's ok.
 Angel
iisfaq
Christchurch Weather Live
« Reply #5 on: May 20, 2012, 05:49:02 AM »
 Hello,
 Angel
Is there any plans for Windows Version?
Cost?
chris
Bushman
« Reply #6 on: May 20, 2012, 11:56:22 AM »
Is the code open source?  Where can one see this in action?
fubaya
« Reply #7 on: May 20, 2012, 01:49:53 PM »
Where can I get it?
meteorologist
« Reply #8 on: May 25, 2012, 11:14:02 AM »
 Hello,
 The web page will be online (I don't know when exactly), so you will be able to order the software.
 Best regards,
 Angel
jgillett
« Reply #9 on: May 25, 2012, 04:37:00 PM »
Just a polite suggestion - you should have had the website up and running before you started talking about the software here. That would have made things a lot easier, and more upfront, for everybody.
Just my opinion, but that comes from 48+ years experience in the computer field, including over 19 years experience as a web developer. Personally, I am suspicious.
W7JKG
meteorologist
« Reply #10 on: May 26, 2012, 03:07:38 AM »
 Thank you for this suggestion.
 Yes. The site is offline and this is a problem that should be fixed before to offer any services. I will speed up the rebuilding.
 Angel
Bushman
« Reply #11 on: May 28, 2012, 12:29:40 PM »
http://www.weathergraphics.com/forum/viewtopic.php?f=21&p=6339
meteorologist
« Reply #12 on: June 15, 2012, 10:33:27 AM »
 Hello,
 My site is back online and updated. Now I offer weather forecast services for Bulgaria: http://www.stormlab.net.
 Do you need weather forecast for your region? This include various weather maps, animations, and text weather outlook for selected cities.
 Best regards,
 Angel Dimitrov
Bushman
« Reply #13 on: June 15, 2012, 11:00:34 AM »
It appears to be locked.  It might be nice to see what you are actually offering.  And 5 bucks for a forecast for Bulgaria?  Uhh... no thanks.
Page created in 0.078 seconds with 18 queries.
