ejfudd
Offline
« on: May 15, 2012, 11:05:02 AM » |
I am looking to install my wireless transmitter/anemometer on my roof. This will be the center of a peaked roof. I would like to stay away from metal as much as possible as I do not see full compliant grounding as an option due to homeowner association rules and the ugly grounding wire. :^) So are there any fiberglass rooftop tripods out there? Any code gurus care to criticize/comment on this possible setup? Other materials are welcome as well...
Another possibility would be a metal tripod with a PVC mast... Would the metal on this need to be grounded if it is ~ the same height as my hvac vent?
Bushman
« Reply #1 on: May 15, 2012, 11:17:33 AM » |
Fiberglass/composite won't help you in a lightning strike.
ejfudd
Offline
« Reply #2 on: May 15, 2012, 11:22:11 AM » |
Why not? Isn't fiberglass simply glass fibers (insulator) within a resin (insulator) over a dry wood (insulator) base? What part of fiberglass would conduct?
dalecoy
« Reply #3 on: May 15, 2012, 11:25:57 AM » |
Often, when there is a lightning strike, it's raining and everything is wet. What is your local requirement for ... full compliant grounding ...
ejfudd
Offline
« Reply #4 on: May 15, 2012, 11:33:26 AM » |
same as NEC. But does this apply in the case of non-metallic rooftop items without wires going into/around the structure? (wooden roof w/ asphalt shingles) I am unfamiliar with local building code, so would not know if there is anything saying the top most point must be grounded...
Bushman
« Reply #6 on: May 15, 2012, 11:52:55 AM » |
Why not? Isn't fiberglass simply glass fibers (insulator) within a resin (insulator) over a dry wood (insulator) base? What part of fiberglass would conduct? Fiberglass whip antenna on boats are hit regularly. Who knows what lightning is thinking?? Regardless, the current will travel to the nearest metal; the glass conduit is merely a vector.
SLOweather
« Reply #7 on: May 15, 2012, 12:17:36 PM » |
And rain, dew and dust make the fiberglass conductive on the skin. We live across the canyon from some high voltage transmission lines. We can hear the crackle of the arcs across the big ceramic insulators, and sometimes, see them at night.
At lightning voltages, dang near everything will conduct, at least on the surface.
d_l
« Reply #8 on: May 15, 2012, 12:57:46 PM » |
Grounding for an anemometer pole on your roof would be primarily to dissipate possible static charge build up which could travel down your anemometer wire to the Davis electronics (ISS or anemometer transmitter) if it isn't discharged.
--Dave--Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*2-Meteohub, WL 6.0.0, WU & W4U= KNVRENO37 NetcamXLPeople always talk about the weather, but they never do anything about it. Not me. I'm gonna measure it. www.tceweather.com
SlowModem
« Reply #9 on: May 15, 2012, 03:29:32 PM » |
I have a 500kv line that runs across my property. It crackles and pops all the time. It is said that if you go out on a humid, damp, or foggy night and hold up a fluorescent light, that it will light up. I've never tried it, though. There's a big metal tower in my yard (you can see the base of it in my avatar). I call it a monument to my employer, since I operate a powerhouse.
C5250
« Reply #10 on: May 15, 2012, 11:26:08 PM » |
The NEC does not require lightning protection.
True, NFPA has pretty much eliminated any mention of traditional structure lightning protection systems. But there are still some requirements, such as the grounding conductor of communications cables must be tied to the structure ground. Somewhat related to the OP's question is 810.15(2002). Which states "The antenna mast that supports radio, HAM, television and satellite receiving antennas must be grounded". It is debatable, if this would apply to a wireless transmitter, but I wouldn't want to put up a lightning attractor without proper grounding. Note to OP, "same as NEC" is meaningless without stating which code cycle your AJU is using.
Precious little in your life is yours by right and won without a fight.
dalecoy
« Reply #11 on: May 15, 2012, 11:32:37 PM » |
You can't "attract" lightning.
Bushman
« Reply #12 on: May 15, 2012, 11:33:55 PM » |
Then what are lightning rods for?
C5250
« Reply #13 on: May 15, 2012, 11:54:21 PM » |
Lightning rods don't "attract" lightning, they drain the static charge buildup that might attract lightning.
SlowModem
« Reply #14 on: May 16, 2012, 09:21:16 AM » |
Tell that to Ben Franklin!
DanS
« Reply #15 on: May 16, 2012, 09:37:27 AM » |
millions of volts aren't all that selective with what they strike. You "hit the nail on the head" with that explanation.
dalecoy
« Reply #16 on: May 16, 2012, 01:06:50 PM » |
Tell that to Ben Franklin!  Ben didn't attract lightning.
Aardvark
« Reply #17 on: May 16, 2012, 05:20:49 PM » |
you don't need to ground it , however, if it will take a load off your shoulders, let you sleep at night in a storm, then by all means do it.
A direct hit, nothing is going to save it and a nearby hit, will screw the transmitter a bit. IF I were to ground it, use a thick copper non insulated wire with a good set of stand off insulators and a six foot grounding rod .
I would recommend going either to a HAM radio center or to an electrical company for the parts.
Davis VP2 Plus;Daytime FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP; Weatherlink Serial and USB;Windows 7; Webcam
