May 19, 2013, 12:32:41 PM *
Members: 6609  •  Posts: 178247  •  Topics: 18102
Please welcome TargY, our newest member.
Author Topic: Wind vane freedom of movement  (Read 416 times)
miraculon
« on: May 20, 2012, 09:48:20 AM »
We went up on the roof of our building to inspect our VP2 installed in April of 2011.
The only thing that I questioned was the wind vane. The movement seems slightly stiff. I am thinking that when I installed my own VP2 in January of this year that it turned more easily.
Is there a slight 'drag' feel to the vane? Maybe it is the potentiometer wiper and I am accustomed to one (AAG) with magnets and reed switches, which only have the bearing friction.
The anemometer is very responsive and everything else checks out OK. Am I just imagining things?
Skywatch
Weather isn't just a hobby, it's a passion.
Life's a game of fight or flight.
« Reply #1 on: May 20, 2012, 09:53:06 AM »
I have the same problem with mine. I have a WMR200 and the Vantage Pro2 anemometers installed together not even a foot apart. The WMR200's wind vane is always moving but the VP2 doesn't seem to do anything until the wind hits 3 MPH. I noticed this from day one. I think maybe an issue with the potentiometer. I've sent an email to Davis about this. Maybe the VP3 will have a better sensor.   Laughing
Davis VP2+ & leaf/soil stn, WMR200-UVN800-2xTHGR810-THWR800. Acu-rite 00639W WeatherDisplay V10.37 B45
WU KTXMCKIN27
PWS MCKTXAWS1
CWOP DW4088
WXbug p14388
HAKUNA MATATA
johnd
« Reply #2 on: May 20, 2012, 11:15:55 AM »
TBH I'm not sure that a small amount of friction on the vane is any bad thing (provided obviously that it's not abnormal/excessive) because it provides a degree of damping to the direction readings. If you look carefully at a log of successive direction values from a VP2 anemometer in most non-ideal locations (ie where the wind gusts and buffets around whatever structures are in the vicinity) you'll see that is already typically a very marked amount of direction variability minute to minute. This would be even more pronounced if some limited damping or averaging weren't applied to the readings.
stevebrtx
Online Online
« Reply #3 on: May 20, 2012, 11:30:40 AM »
I still have my OS on the roof and the Davis anemometer is less sensitive at low wind rates. The OS cups will turn with only a breath while it seems to take a bit more for the Davis, however, the OS tops out at 30mph, never registered more than that, I suspect when the stormy season starts next month the Davis will record higher winds.
Page created in 0.102 seconds with 19 queries.
