May 21, 2013, 08:17:32 AM *
Members: 6615  •  Posts: 178467  •  Topics: 18111
Please welcome Christea, our newest member.
Author Topic: Powering DFARS from console on a cabled VP2?  (Read 357 times)
Kurgan
« on: April 30, 2012, 06:10:52 PM »
I own a cabled VP2, and I can also run a second cable eventually. Could it be a nice idea to buy a DFARS kit and then power the motor from the console cable or from a dedicated power supply? Did someone do it? I suppose the motor runs on about 3 volts, and if I  discover how much current if draws, I can see if it is feasible to power it from the same power that runs the SIM, given some diodes in series to reduce it from 5 to 3 volts.
Kurgan
(IZ4UFQ)
dalecoy
« Reply #1 on: April 30, 2012, 06:22:49 PM »
Yes, I use a cabled VP2 with a daytime FARS that is powered 24/7 by a Radio Shack wall-wart.
I would not personally want to power it from the console.
Kurgan
« Reply #2 on: April 30, 2012, 06:31:34 PM »
Thanks for your answer. I suppose that I have to buy the complete kit with the (useless in my case) solar panels... well, I can build something else with that panel.
Kurgan
(IZ4UFQ)
dalecoy
« Reply #3 on: April 30, 2012, 06:47:51 PM »
See this topic:  http://www.wxforum.net/index.php?topic=11585
Or just go to Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=3802149
Oops - I forgot you are in Italy.
« Last Edit: April 30, 2012, 06:51:40 PM by dalecoy » Logged
Kurgan
« Reply #4 on: April 30, 2012, 07:00:38 PM »
Thanks.
So 3 volts will be fine, I will recycle some old computer equipment power supply. I remember I have a 3 vdc 100 mA or so somewhere. Maybe 100 mA will be enough. If not, I will find a better power supply. I don't like running the motor at more than 3 volts, even if it will become a great insect-blender, I suppose.
Kurgan
(IZ4UFQ)
Page created in 0.097 seconds with 18 queries.
