May 21, 2013, 07:46:19 PM *
Members: 6617  •  Posts: 178511  •  Topics: 18114
Please welcome TheMOX, our newest member.
Author Topic: Date format  (Read 752 times)
jdpsys
« on: April 30, 2012, 08:02:53 PM »
I'm using Meteohub and a Davis Station.
I would like the date formate to be APR 30 2012 instead of 30/04/2012
Looked in the settings, but seems I'm overlooking something.
Jon
Davis Vantage Pro II - Meteohub (4.9 b929 - SheevaPlug)
http://www.fairfieldwx.com
jdpsys
« Reply #1 on: April 30, 2012, 08:04:03 PM »
Forgot to add
www.fairfieldwx.com
Jon
jdpsys
« Reply #2 on: May 01, 2012, 07:34:46 AM »
I set WDdateMDY = false  and when I refresh the page the date shows up as 1 May 2012 untill the page completes loading, then it reverts back to 1/5/2012
Jon
saratogaWX
Administrator
Saratoga, CA, USA Weather - free PHP scripts
« Reply #3 on: May 01, 2012, 01:34:44 PM »
Unfortunately, the AJAX routine does not provide a Mon dd yyyy format for display, only dd/mm/yyyy or mm/dd/yyyy format are available.  I suggest you choose the numeric-only format for display.
Sorry...
Best regards,
Ken
Davis Vantage Pro Plus - FARS, Boltek-PCI/NexStorm, GRLevel3, WD, WL, VWS, Cumulus, Meteohub
jdpsys
« Reply #4 on: May 01, 2012, 01:43:29 PM »
Not a big problem.
How do I get it to show mm/dd/yyyy ?
Jon
saratogaWX
Administrator
« Reply #5 on: May 01, 2012, 02:11:54 PM »
Use in Settings.php
Code:
$SITE['dateOnlyFormat'] = 'm/d/Y';
BTW.. the reason the AJAX routines don't have Month abbreviations available is due to the lack of abbreviated month names in the language scripts .. the language-LL.js scripts have full month names, but not all languages use the first 3 characters as the abbreviation, so it was just easier to avoid the issue Smile
Best regards,
Ken
jdpsys
« Reply #6 on: May 01, 2012, 02:42:50 PM »
Now it shows 05/01/2012 until the gizmo updates, then shows 01/05/2012
Jon
saratogaWX
Administrator
« Reply #7 on: May 01, 2012, 02:59:31 PM »
It's due to Meteohub clientraw.txt showing the date as '01/05/2012' instead of Weather-Display's clientraw.txt which has '05/01/2012' and the ajaxMHwx.js script just uses the value of clientraw[74] for display.
I'll need to add some code to ajaxMHwx.js to allow selection of MDY or DMY formats for the dates...
Should be ready shortly.
Best regards,
Ken
jdpsys
« Reply #8 on: May 01, 2012, 03:37:36 PM »
THANKS! suspected that was it.
New visistors to my site are already pinging me about it
Jon
saratogaWX
Administrator
« Reply #9 on: May 01, 2012, 04:39:16 PM »
Ok... try the attached (save as ajaxMHwx.js)
Best regards,
Ken
jdpsys
« Reply #10 on: May 01, 2012, 04:49:58 PM »
thank you!
fixed now.
Jon
saratogaWX
Administrator
« Reply #11 on: May 01, 2012, 04:54:20 PM »
Great!
I've added your site to the list also Smile
Best regards,
Ken
Page created in 0.104 seconds with 19 queries.
