May 19, 2013, 07:41:40 AM *
Members: 6609  •  Posts: 178232  •  Topics: 18100
Please welcome TargY, our newest member.
Author Topic: Wanted: Used Davis UV sensor.  (Read 1015 times)
Skywatch
Weather isn't just a hobby, it's a passion.
Life's a game of fight or flight.
« on: April 24, 2012, 02:55:01 PM »
I want to get UV on my VP2. I don't like the price of 315$. I can't really afford much. I'm saving up for a new computer to replace a failing one. Doesn't need to be in good condition, just needs to work.
Thanx.
Davis VP2+ & leaf/soil stn, WMR200-UVN800-2xTHGR810-THWR800. Acu-rite 00639W WeatherDisplay V10.37 B45
WU KTXMCKIN27
PWS MCKTXAWS1
CWOP DW4088
WXbug p14388
HAKUNA MATATA
SLOweather
Administrator
« Reply #1 on: April 24, 2012, 03:57:14 PM »
Rob at rainmanweather.com has 'em for $237.98.
Bushman
« Reply #2 on: April 24, 2012, 04:24:00 PM »
Whatever happened to the low cost version that some folks here beta-tested?
d_l
Slide Mtn - Mt Rose
« Reply #3 on: April 24, 2012, 05:29:41 PM »
It was a newly designed version, but we only guessed that it may be lower cost because the current version seems pricey and many skip buying it because of that.
Our resident "beta" testers of it haven't reported in for a long time. Maybe there are problems with it?
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*2-Meteohub, WL 6.0.0, WU & W4U=KNVRENO37 NetcamXL
People always talk about the weather, but they never do anything about it.  Not me.  I'm gonna measure it.  www.tceweather.com
Skywatch
« Reply #4 on: April 24, 2012, 09:27:48 PM »
Well the reason I was primarily looking for an old used sensor is to get a good deal. Maybe someone replaced an old Vantage Pro Plus or pro2 Plus and had the sensors just lying around. I don't want to spend over 100$. May sound crazy, but I'd like UV but not the cost. If it works I could care less about any other conditions.
Thanx
WU KTXMCKIN27
PWS MCKTXAWS1
CWOP DW4088
WXbug p14388
HAKUNA MATATA
kray1000
Purveyor of wry
« Reply #5 on: April 24, 2012, 10:24:38 PM »
Another way of going about this is to look for a used VP2 Plus, keep the sensor(s) you want, then sell it as a used VP2.
Kevin Ray
Roanoke, VA
Wireless VP2, Stardot NetCam, ImageSalsa 2.0.12, MovieSalsa, Nexstorm, WASP2, Skymet, VWS14.01p33, WD 10.37N build 03
Weather Display
Online Online
« Reply #6 on: April 24, 2012, 11:24:04 PM »
you can add 1 wire UV via WD
Silversword
--Stan Y.
Contributor
« Reply #7 on: April 25, 2012, 02:58:12 PM »
If you like to tinker with a system, 1-wire by Hobby Boards has a solution.  If you have a 1-wire system going, then you can add a UV sensor for less than $50 USD, but if you have to start from scratch, it will cost about $100 USD to get the 1-wire system going and let WD do the rest.  Also if you have a system going then you can add more sensors as needed.  I have the UV, Solar and Lightning sensors going at the present time with WD for the past couple of years without too much maintenance...
This is just a suggestion and hope that you will be able to achieve your goal.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
MS Windows XP Pro-SP3
Davis Vantage Pro 2 Wireless + 1-Wire Solar  + 1-Wire UV  + 1-Wire Lighting
Webcam:Panasonic BL-C1A
Bushman
« Reply #8 on: April 25, 2012, 04:06:56 PM »
{Shameless Ad here}  http://www.wxforum.net/index.php?topic=7815.0  Smile
Skywatch
« Reply #9 on: April 25, 2012, 06:59:12 PM »
My computer crashed again. This time  permanently. I might need to replace hard drive but the UV sensor will have to wait.
Thanx
WU KTXMCKIN27
PWS MCKTXAWS1
CWOP DW4088
WXbug p14388
HAKUNA MATATA
Page created in 0.114 seconds with 19 queries.
