May 22, 2013, 09:48:51 PM *
Members: 6617  •  Posts: 178608  •  Topics: 18127
Please welcome TheMOX, our newest member.
Author Topic: Q: sea-level bar input for WL?  (Read 1515 times)
Old Tele man
« on: April 10, 2012, 02:39:02 PM »
Q: is "sea-level barometer" input required for WL?
As I was walked through the "Setup" procedure, the "Set Barometer" input asked for two inputs: Station Elevation in feet and Sea-level Barometer in inches. So, I entered what I knew: Station Elevation = 2330 ft. but I left the Sea-Level Barometer entry 'blank' because I didn't know what value to enter.
So-o-o-o-o, what *should* I enter there, if required, or can I leave it empty without causing problems? I'm at 2330 ft and the main weather station is located at the airport at 2641 ft about 25 miles away!
• SYS: Davis VP2/WL-IP & Envoy8X/WL-USB
• CWOP: DW6988 - Cortaro, AZ
• WU: KAZTUCSO202 - Countryside Homes
George Richardson
« Reply #1 on: April 10, 2012, 03:33:21 PM »
IF you have a Davis Vantage product, plug your station elevation into the console, give it a few hours settle in (actually about 24 hours) and read the barometric pressure (SLP) on the console.
FWIW, barometric pressure has such a low gradient that the airport pressure (@ 25 miles) would be very close. The problem is airports use altimeter pressure and not all report both.
Questions  Wink
George
beaudog
« Reply #2 on: April 10, 2012, 03:58:16 PM »
This one should be pretty close.
http://raws.wrh.noaa.gov/cgi-bin/roman/meso_table_mesowest.cgi?stn=KTUS&unit=0&time=LOCAL
or
http://raws.wrh.noaa.gov/cgi-bin/roman/meso_table_mesowest.cgi?stn=D7579&unit=0&time=LOCAL
You might find this usful to some extent.
http://www.softwx.com/weather/vppressurecalc.html
« Last Edit: April 10, 2012, 04:04:50 PM by beaudog » Logged
dalecoy
« Reply #3 on: April 10, 2012, 05:15:07 PM »
No.
George Richardson
« Reply #4 on: April 10, 2012, 05:35:26 PM »
"Sounds more like a 'crap-shoot' than a true 'scientific guess' situation."
You want Scientifically correct, http://www.starpath.com/barometers/baro_cal.php
George
beaudog
« Reply #5 on: April 19, 2012, 06:08:00 PM »
I don't see you on the WU map.    Are you reporting to WU?
Old Tele man
« Reply #6 on: December 01, 2012, 09:28:55 PM »
...I am now.
Scalphunter
« Reply #7 on: December 02, 2012, 12:27:55 AM »
3 airports close to you report Altimeter...KRYN, KDMA,KTUS. Two of these also report SLP in their METARS,....KDMA AND KTUS
Hope you know how to read them as the info is there.
Page created in 0.11 seconds with 18 queries.
