Author Topic: WxMesg  (Read 5483 times)
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
WxMesg
« on: March 30, 2012, 05:58:47 PM »
Ok everything running. I think.
The test message is working:
This is a test of your email server settings.
From Weather Message
But when I try test alert, I get this error:
03/30/12 17:42:44.89 SMTP Error: 162 Error communicating with server.
03/30/12 17:42:44.92 sendToSmtp: General ErrorIPWorksSSLSmtpsException - Connection failed:
« Last Edit: March 31, 2012, 04:20:12 PM by ed2kayak »
Ed
Offline DaculaWeather
  • It's a Jeep thing... you wouldn't understand.
  • SCCA EM #156
    • North Georgia and US Weather
Re: WxMesg
« Reply #1 on: March 30, 2012, 07:45:39 PM »
What settings are you using for the email setup?
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #2 on: March 30, 2012, 07:59:45 PM »
Ok anything running. I think.
Does your smtp server use SSL?  It looks as if maybe you're trying it that way but the server doesn't like it.
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline ed2kayak
  • Ed
Re: Re: Re: WxMesg
« Reply #3 on: March 30, 2012, 09:03:50 PM »
Yes, thats the answer. Changed to SSL  auto and it worked. :)
Ed
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: Re: Re: WxMesg
« Reply #4 on: March 31, 2012, 12:57:31 PM »
If you need any more help with it just let me know...had it a little over a year now and have gotten pretty good with it and like it's flexibility.
Weather radios:
Reecom R-1650
Sangean CL-100
Offline ed2kayak
  • Ed
Re: WxMesg
« Reply #5 on: April 02, 2012, 04:18:57 PM »
NWS has a frost advisory tonight  for my county. I only have a 2 email alarms setup now. (WRNCTP + WSWCTP)
 So I have to add a product (frost warning) and county code to the WxMesg setup?
Reason I ask, didn't see frost warning in the product code list. Probably missed it
Thanks in advance.
Ed
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #6 on: April 02, 2012, 05:19:58 PM »
Thanks in advance.
Frost warning is likely part of a WSW (Winter weather message) and is a VTEC product.  So you could select this (WSW) for your WFO, then use select VTEC and choose frost advisory/warning setup.
EDIT:  It might also be part of a NPW message (Non-precip-warning).
« Last Edit: April 02, 2012, 05:27:51 PM by BigOkie »
Weather radios:
Reecom R-1650
Sangean CL-100
Offline ed2kayak
  • Ed
Re: WxMesg
« Reply #7 on: April 02, 2012, 06:25:19 PM »
Ok, I added NPW. If I refresh the WxMessage Map will it show up there also, are they two independent products?
ok, you have to assign client/map. Obviously I have some reading to do.
« Last Edit: April 02, 2012, 08:30:13 PM by ed2kayak »
Ed
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #8 on: April 03, 2012, 10:02:08 AM »
These are all the products and how I set them up to use the WXMap program.  This is how it looks in the server setup grid.
Weather radios:
Reecom R-1650
Sangean CL-100
  • SCCA EM #156
Re: WxMesg
« Reply #9 on: April 03, 2012, 10:23:09 AM »
Then you can choose your state/and county.
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #10 on: April 03, 2012, 01:36:36 PM »
In this case though, all those entries are specifically for the map, so I don't choose any states/counties/zones and send it to the map client (note: if you use WXLoader, that acts as a map client as well).
Weather radios:
Reecom R-1650
Sangean CL-100
Offline ed2kayak
  • Ed
Re: WxMesg
« Reply #11 on: April 04, 2012, 09:59:52 AM »
Suggestions needed for truncating message length for text messaging. I think Verizon is 160 character limit.
Email not issue, working fine.
Ed
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #12 on: April 04, 2012, 05:03:54 PM »
Search the Yahoo group for 'shortcode'; I believe you'll find some suggestions in there.
Weather radios:
Reecom R-1650
Sangean CL-100
Offline ed2kayak
  • Ed
Re: WxMesg
« Reply #13 on: April 07, 2012, 04:48:15 PM »
Question of the day. The fax option requires a modem?
Will try to dig up a USB modem for testing.
« Last Edit: April 07, 2012, 08:07:03 PM by ed2kayak »
Ed
  • SCCA EM #156
Re: WxMesg
« Reply #14 on: April 08, 2012, 08:07:07 AM »
So Ed, it sounds like you're really giving it a workout!
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: WxMesg
« Reply #15 on: April 09, 2012, 11:59:00 AM »
A little late, but correct.  If you use some sort of email option to do faxes (I know some use a gateway) then you'd need to set that up appropriately.
Weather radios:
Reecom R-1650
Sangean CL-100
Offline larry.lovering
Re: Re: Re: WxMesg
« Reply #16 on: July 05, 2016, 12:44:58 PM »
I've been using Weather Message for over two years now, and recently went to a new email server and so, changed the password.  Now, I am getting this when I test:
Starting Test ... (server name)
--- Connecting to mail server.
Remote host connection complete. Status 0 - OK
--- Connected.
-~~ Starting secure channel handshake.
-~~ Sending 131 bytes of handshake data.
-~~ Receiving 179 bytes of handshake data.
SSL connection broken. Status 276 - Error during handshake: The token supplied to the function is invalid (0x80090308)
Remote host disconnected. Status 276 - Error during handshake: The token supplied to the function is invalid (0x80090308)
Error: 276 - Error during handshake: The token supplied to the function is invalid (0x80090308)
Email Test Failed....
Since SSL is deprecated, I use Auto for the SSL and 587 for the SMTP port.  I keep getting this error and the email logs say they can't connect to the server.  My own email is working to the email server.  Thank you for any help.
Larry Lovering
  • SCCA EM #156
Re: WxMesg
« Reply #17 on: July 05, 2016, 12:51:16 PM »
Try posting your question here: WxMesg@yahoogroups.com
