NEWX85
Offline
« on: March 26, 2012, 09:34:22 AM » |
i Have installed Weatherlink 5.9.3. All of my dates are correct on the base but when i want to view my reports it says its June 11th 2011 and its not updating at all plus the date is wrong. How do I fix this?
JACK10562
« Reply #1 on: March 26, 2012, 02:19:57 PM » |
Did you setup the correct date and time in WL 5.9.3? Close the Weather Bulletin for now, and click setup, verify that the correct date is showing. Is your PC clock set correctly?
CWOP: DW5051MADIS ID:D5051 WU:KMAEASTH4 CoCoRaHS:MA-BA-23 DavisVantagePro2Plus#6163 Cumulus 1.9.3(1059)←☼
dalecoy
« Reply #2 on: March 26, 2012, 02:25:10 PM » |
If this is a new system, I suggest uninstalling WeatherLink completely, deleting the WeatherLink folder, and then re-installing. During setup of WeatherLink, make sure to update the time on the console, and delete all archived data. If you are updating an old system, then it's a more complex problem.
NEWX85
Offline
« Reply #3 on: March 26, 2012, 08:04:53 PM » |
Ok I deleted everything and re-installed. I also deleted all my records I saved on the Data Logger. See if that works. The time Date etc is correct.
NEWX85
Offline
« Reply #4 on: March 26, 2012, 08:16:17 PM » |
Also I tried doing firmware updates but have errors. The Data logger firmware froze on me couldnt detect anything. Also None of the Updates work Im using a USB thats connected and says cant find it hmmm
NEWX85
Offline
« Reply #5 on: March 26, 2012, 08:31:30 PM » |
Working
dalecoy
« Reply #6 on: March 26, 2012, 08:38:03 PM » |
Working  Confused. What's working? You? Or the hardware? Or what? If you still can't get updates to work, please give complete details of current firmware version, etc.
NEWX85
Offline
« Reply #7 on: March 26, 2012, 08:43:36 PM » |
Working the data blog
dalecoy
« Reply #8 on: March 26, 2012, 11:01:53 PM » |
Working the data blog  I have no idea what that means. Please excuse my effort to assist.
NEWX85
Offline
« Reply #9 on: March 27, 2012, 09:38:19 AM » |
I had problems that the Data was not correct so I did everything the other members told me to do above and it works now.
dalecoy
« Reply #10 on: March 27, 2012, 09:59:14 AM » |
And you got the console firmware updated, too?
NEWX85
Offline
« Reply #11 on: March 27, 2012, 03:25:46 PM » |
nope its not working for some reason. It freezes up my computer. I'll leave it the way it is. Thanks for everyones help
NEWX85
Offline
« Reply #12 on: March 27, 2012, 03:28:26 PM » |
And It downloads 200+ records but no data from this morning just 3PM and onward werid
NEWX85
Offline
« Reply #13 on: March 27, 2012, 03:29:37 PM » |
Nevermind I see it
moto51
« Reply #14 on: April 11, 2012, 07:55:40 AM » |
I had trouble with the console not transferring archive data but live data could be seen fine. I added a couple of ferrite chokes (google them) to the cable to remove interference and that seems to have fixed it for reasons unknown to science. The other thing is to reset the console but in a specific way, let me know if you have the error again and i'll post the steps used to fix it.
