May 22, 2013, 12:58:07 PM *
Members: 6617  •  Posts: 178559  •  Topics: 18123
Author Topic: Fitzweather is Back!  (Read 1850 times)
Farmtalk
Fitzweather
« on: March 24, 2012, 12:56:06 PM »
The new version of Fitzweather is up and running! I'd really like to thank Daculaweather for helping me out along the way! Couldn't have gotten it done without his help! Very Happy
Any comments, criticisms, or questions are greatly appreciated no matter how harsh!!!! Cool
www.fitzweather.com
"Make it simple but significant"
Administrator- www.fitzweather.com
Administrator- www.triviacre.com
neondesert
« Reply #1 on: March 24, 2012, 01:28:07 PM »
Nice to see your site back up, Joe!  Cool
I did notice in FireFox (version 11.0), one of the green colored cells in the Daily Almanac table that is currently
populated with the text "Rain, T-Storm" is overlapping a small portion of the cell in an adjacent table.
The cell that is being obscured contains the text "Fitzweather's Generated Precipitation Forecast for Saturday March 24th, 2012"
and the tops of the letters Fitz are cut off.  Looks like you'll need to do some minor tweaking to correct this.
The alignment is OK in IE 9.
Larry
"But it's a DRY Heat!"
Farmtalk
Fitzweather
« Reply #2 on: March 24, 2012, 01:51:32 PM »
Thanks! I will fix that this evening! Ill run a test through a bunch of different browsers to ensure that it works correctly in each one. Smile
SteveFitz1
« Reply #3 on: March 24, 2012, 01:54:17 PM »
Couple of suggestions:
1) Get rid of the 'starry' background. Very distracting...to me anyway. I'd go with a solid color background like white.
2) Center your content box. In both IE9 and FF11 it's aligning to the left of the page. On a wide screen monitor it's very unbalanced. Centering it would make it look much better.
Keep up the good work.
Steve
neondesert
« Reply #4 on: March 24, 2012, 02:03:24 PM »
Here's a good site for testing your code against various web browsers without having to have them installed.
http://browsershots.org/
Larry
Farmtalk
Fitzweather
« Reply #5 on: March 24, 2012, 02:21:03 PM »
Steve
How can I tell if its centered on widescreens????
Thanks, I will do this tonight!!!! Very Happy
SteveFitz1
« Reply #6 on: March 24, 2012, 02:46:41 PM »
Change the resolution of your monitor so that the resolution is wider than your content box. For example, your content box (layer2) appears to be 890 px wide. Use a screen resolution on your monitor of something like 1024 px or greater. You'll then be able to see that all your content is aligning to the left of the screen and the 'empty space' is all to the right of your content.
Steve
smorris
« Reply #7 on: March 24, 2012, 03:58:58 PM »
I see exactly the same thing on Safari 5.1 on my Mac.
When I load the page, it first turns the whole wind a bright purple-pink, then applies the stars, and finally the information. I can't read the dark blue text on the black background in the upper-left corner. Highlighting it, I see that it says home, but I'd never read it otherwise.
Other than that, centering would help. It is a lot better that the way too colorful previous version!
Steve
Steve - Avon, Ohio
Davis Vantage Pro2 Plus w/FARS, Leaf & Soil Station
CWOP • WU • AWEKAS • CoCoRaHS • Skywarn • MWWN • UK Met • PWS • WeatherBug • TwitterFacebook
Farmtalk
Fitzweather
« Reply #8 on: March 24, 2012, 04:34:25 PM »
Obviously a few tweeks to perform! Very Happy Very Happy Very Happy
Now will I be able to change my resolution because the right 1/3 of my screen on my computer is unusable Sad
« Last Edit: March 24, 2012, 04:37:00 PM by farmtalk » Logged
Farmtalk
Fitzweather
« Reply #9 on: March 24, 2012, 05:12:58 PM »
Could someone tell me whether I fixed the centering issue??
smorris
« Reply #10 on: March 24, 2012, 05:30:14 PM »
Not for me on Safari.
I tried looking at the source, but I've never used layers. I'm just a basic html coder, so what you've got is beyond me to make suggestions.
Steve
Steve - Avon, Ohio
Farmtalk
Fitzweather
« Reply #11 on: March 24, 2012, 05:32:10 PM »
Other than what everyone has said like the fitting of one of the tables, the color of the home tab,and the centering issue (This one has me confused), is there anything else that should be fixed???
WxVortex
Senior Member
« Reply #12 on: March 24, 2012, 06:12:13 PM »
Looks good, agreed with the starry background being distracted, this can be fixed by centering your graphics (which it sounds like you are in the process of doing so) or changing it completely. Otherwise good stuff man!
Farmtalk
Fitzweather
« Reply #13 on: March 24, 2012, 08:40:24 PM »
Anyone have good ideas for a background???
DanS
Chiang Mai weather
« Reply #14 on: March 24, 2012, 08:47:47 PM »
perhaps something along these lines?
Dan ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
Farmtalk
Fitzweather
« Reply #15 on: March 24, 2012, 08:50:54 PM »
Looks good! Ill try and make it nice and big and then fit it on there! Very Happy
WxVortex
Senior Member
« Reply #16 on: March 24, 2012, 09:37:44 PM »
Something bright usually works best, the clouds would be great!
Farmtalk
Fitzweather
« Reply #17 on: March 24, 2012, 11:32:55 PM »
I put the clouds on there and I like it alot! And I think Ive got the overlapping issue fixed, but the centering of the page problem has me discombobulated...Could someone give me a pointer on how to fix this???
tobyspond
« Reply #18 on: March 25, 2012, 07:31:52 AM »
Try wrapping your content in a div and applying a center style to the div.
www.tobyspondweather.com
CWOP DW7499
WU KMACONCO19
twitter: @tobyspond
DougW
« Reply #19 on: March 25, 2012, 08:01:54 AM »
I was thinking that you purchased GR level3 a while back???? That would be a great addition to your site.
Doug
Farmtalk
Fitzweather
« Reply #20 on: March 25, 2012, 08:39:56 AM »
Doug
I did but I'm not able to keep my computer running 24/7, else I would do that Sad
And thats a good idea tobeyspond, I'll see if i can do that! Very Happy
WxVortex
Senior Member
« Reply #21 on: March 26, 2012, 06:34:28 PM »
just checked out your revamped site. Looks good!!
Farmtalk
Fitzweather
« Reply #22 on: March 26, 2012, 06:52:43 PM »
Thanks!! As I learn more about coding, I'll make it more complex but I think Im happy with it for now! Very Happy
Page created in 0.146 seconds with 19 queries.
