May 23, 2013, 04:27:10 AM *
Members: 6617  •  Posts: 178631  •  Topics: 18128
Author Topic: Channel 1 humidity not reading on VWS  (Read 1032 times)
KC0WNY
« on: March 23, 2012, 06:16:03 AM »
 Virtual Weather Station V14.01 P46  is not showing a data from Station 1, all other data is displaying. What is the Fix. Thanks
Using Windows 7 Pro, Serial Data Logger.
Update: Vantage Pro II Station
« Last Edit: March 24, 2012, 02:48:02 AM by KC0WNY » Logged
mackbig
« Reply #1 on: March 23, 2012, 06:49:25 AM »
Need more info, like what type of weather station do you have.....
If its a vp2, might introduce you to stevebrtx
Andrew
stevebrtx
« Reply #2 on: March 23, 2012, 09:50:54 AM »
I had passed along all I could to Ed and he emailed yesterday afternoon, so he's aware and apparently working on it. I'm on p48 at the moment.
stevebrtx
« Reply #3 on: March 23, 2012, 05:05:42 PM »
Ed wrote a diagnostic program showing the Davis data stream in VWS, I ran it and sent the results back. Not knowing exactly what to expect I don't know what it tells, but channel 1 is not mapping, so I'm guessing that means VWS is thinking the first channel coming down is really ch 1, but that's only a wild guess. So we'll see what he finds.
Edit: Sorry, that wasn't clear, it's NOT seeing channel 1 and thinks the first one it actually sees, which is in reality ch 2, is being mapped as channel 1. At any rate, I'm sure Ed will figure it out and get a fix.
On the bright side, I got the new Davis up on a 3 meter mast and hope to step over to it about midnight tomorrow night so we're close(r) to a "real" weather station - ha.
« Last Edit: March 23, 2012, 05:59:11 PM by stevebrtx » Logged
KC0WNY
« Reply #4 on: March 24, 2012, 02:41:04 AM »
Davis Vantage Pro II Weather Station
stevebrtx
« Reply #5 on: March 24, 2012, 09:30:49 AM »
I didn't hear back yet, maybe Monday. However, in my case what would normally be considered ch 1 from the ISS is appearing in "Outside" dials, gauges etc. so I'm going to use that as I step over tonite from OS to Davis.
mackbig
« Reply #6 on: March 24, 2012, 12:04:45 PM »
KC0WNY
Are you using an extra temp/hygro station in addition to the ISS like Steve is?
Did prior versions of VWS work for you?
Andrew
stevebrtx
« Reply #7 on: March 24, 2012, 04:31:23 PM »
I reinstalled p46 and shut down the remote ch 2 console and WeatherLink and get the same problem, no Ch 1 unless I check "use channel 1 as outside" and then I get a reading on a gauge. So, hopefully Ed will track down the mapping problem.
KC0WNY
« Reply #8 on: March 24, 2012, 05:35:49 PM »
Are you using an extra temp/hygro station in addition to the ISS like Steve is? NO
Did prior versions of VWS work for you? Not knowing, I cannot say, this is was my only version, but I thought it worked when I was using the basic version though.
KC0WNY
« Reply #9 on: March 24, 2012, 09:05:55 PM »
Reinstalled the Software, now everything works, go figure. Thanks to all that Replied. KCØWNY
racenet
Moderator
« Reply #10 on: March 25, 2012, 10:03:35 AM »
Did you notify Ed of this? If not, please do.
Bob
KC0WNY
« Reply #11 on: March 25, 2012, 11:27:22 AM »
Who is "ED"
Thanks KCØWNY
stevebrtx
« Reply #12 on: March 25, 2012, 12:01:16 PM »
Ed is the programmer guy at Ambient Weather who writes and maintains VWS, he's at ed@ambientweather.com
racenet
Moderator
« Reply #13 on: March 25, 2012, 01:24:29 PM »
Who is "ED"
Thanks KCØWNY
Sorry, that was a misquote.  Embarassed
KC0WNY
« Reply #14 on: March 25, 2012, 01:55:33 PM »
Sent a Note to ED, about my solution. Thanks KCØWNY
Page created in 0.11 seconds with 19 queries.
