May 22, 2013, 02:17:03 AM *
Members: 6617  •  Posts: 178535  •  Topics: 18117
Pages: [1] 2   Go Down
Author Topic: Alternative Dashboard Version 6.60 BETA starting  (Read 4039 times)
BurnsvilleWeather
Burnsville, MN USA
« on: February 18, 2012, 11:22:32 PM »
I've always wanted to do a few things with the dashboard but haven't had the time to play around with it lately and I didn't have a good option for the Lightning/Snow in the middle of the display.  Well thanks to one user who talked me into adding the Tide display, I've spent the day working both out!
In this new version, the 3rd row, second column will now have 4 options...
  • 1. Lightning Display
  • 2. Snow Display
  • 3. Tide Display
  • 4. Blank (spot for you to add in your own code)
But one thing always bugged me with this section.  If snow is set for displaying for a fixed time period, winters like this one in Minnesota will keep the snow showing even when there is none on the ground.  Worse yet, it might lead to a thunderstorm and then instead of showing my lightning display, it would be showing snow... Not what I want!
So after a thousand different code trys, I have designed it to allow lightning over-ride either the snow display or the new Tide display and show lightning stats in this spot!  When the lightning storm is done, it will resume it's normal snow or tide display.  Of course this assumes you have a lightning detector (1-wire or Nexstorm).  If you don't have lightning detection, then of course, it is a totally static display of snow, tide or blank.
Let me know what you think and if you have TIDE needs and want to beta this new version, let me know.
Scott
« Last Edit: December 10, 2012, 11:15:02 AM by BurnsvilleWeather » Logged
Scott
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
staccermaccer
« Reply #1 on: February 19, 2012, 04:54:38 AM »
Hello, Scott
Hi, I would like to give it a stab, i am living in Antwerp, Belgium, second largest port in Europe and as a facft lot's of people are visiting my site for the tides. I have put in a piece of code that shows a tide-clock but with my limited skills it's not what i really want! So i would be glad to test it for you  Razz
Staccermaccer AKA Marc,
Greetings,
BurnsvilleWeather
Burnsville, MN USA
« Reply #2 on: February 19, 2012, 09:37:33 AM »
What I'm adding in is the same script you have used, it is just in a different location and can be over-ridded by lightning.
Scott
Scott
staccermaccer
« Reply #3 on: February 20, 2012, 03:49:57 AM »
Hi Scott,
OK then, i am sure your code is much cleaner, so i still would give it a stab...
Marc,
n3ouc
Contributor
« Reply #4 on: February 20, 2012, 07:28:43 AM »
Hi Scott,
I wouldn't mind giving it a shot here. I am near the Jersey Shore and I'm sure tide information would be relavent.
Mike Stanton
Air Products Campus Weather
stormwatch
Contributor
« Reply #5 on: February 23, 2012, 12:00:11 PM »
  • 2. Snow Display
  • 3. Tide Display
Scott
Hi Scott,
I already have the Tide Section incorporated in my Dashboard (6.10). Having a trouble upgrading to 6.51 but working on that. If you need my code for including "Tides" in the "Coming Soon" section; let me know and I'll give you what I have. I think you have quite a few people living along bodies of water that would love to include this option.
www.carolinastormwatch.com
Tom M.
Carolina StormWatch Weather
Sunset Beach, NC
Grissettown-Longwood Fire And Rescue
Brunswick Co. CoCoRaHS Coordinator NC-BR-1
CWOP-0803
Advanced Skywarn Trained
BurnsvilleWeather
Burnsville, MN USA
« Reply #6 on: February 23, 2012, 10:14:49 PM »
Thanks but that part is done and working very well already, I'm just working on the code to allow lightning to over-ride snow or Tide.  Just need to do some additional testing but other things are keeping my work time at a minimum right now.  Thanks though!
Scott
Hi Scott,
Scott
BurnsvilleWeather
Burnsville, MN USA
« Reply #7 on: March 17, 2012, 05:33:10 PM »
Alternative Dashboard Version 6.60 BETA is now available for testing!
I have finally found the time to put the finishing touches on the new version.  This version contains the following new items:
  • 1. Addition of Tide Display (Not sure who originally created it)
  • 2. Addition of new ability for Lightning to over-ride display of SNOW or TIDE
  • 3. Ability to have SNOW and Lightning on at the same time
Here is how it works:
If you want to use snow and lightning or tide and lightning you now can, it will change automatically as needed.  for example:  If you have snow and lightning on, snow will display when-ever there is snow on the ground unless for some strange reason you get a lightning storm, then even if snow is on the ground, lightning will display.  When Lightning ends, snow will resume.  If you have Tide and Lightning, it will show Tides unless a lightning storm approaches, then it will show Lightning.  When the lightning is done, it will show Tides again.  If you just want tide, snow or lightning on their own, that is fine too.
NOTE:  I will have limited access to respond to questions for the next week, if you need help, post a question and I'll get back to you ASAP.  Also note, this beta requires that you ALREADY HAVE VERSION 6.5x ALREADY RUNNING TO USE and there is no directions/instructions other then those in the new config file.
Download the BETA and replace your alt-dashboard6.php and AltAjaxDashboardConfig6.php files with the new files after you have backed up your current versions.  Edit the config and you should be ready to go!  Don't forget to edit the PayPal code in the main script if you use the donation button too!
You can download the script at:
http://www.websterweatherlive.com/wxScripts.php
Scott
tonyva
Senior Member
« Reply #8 on: March 19, 2012, 12:17:09 AM »
Thanks Scott, I have the beta running on my site now and it seems to be working fine with the tide dial  Smile
http://www.mangawhaiweather.co.nz/
Davis VP2 Cabled, WDisplay, Windows XP
BurnsvilleWeather
Burnsville, MN USA
« Reply #9 on: March 22, 2012, 08:29:38 PM »
Site is looking good!  You may want to add some text to the footnotes, right now you just have those footnote numbers alone at the bottom of the main pannel.  That section in in the config file.  Just fill in the ones you use.
Scott
Scott
jgillett
Davis VP 2+ wireless, FARS, Boltek, Win7 Pro
« Reply #10 on: March 23, 2012, 04:25:11 PM »
No problems with 6.6 here, Scott (although as mentioned, can't help with the snow or tide parts).
As always. thanks for your efforts.
W7JKG
Silversword
--Stan Y.
Contributor
« Reply #11 on: March 25, 2012, 07:16:11 PM »
Scott, got the 6.60b working at my site www.dwayneyamato.com/wx/.  Looking good so far. Thank you for the updates.  Be looking for the final version...
tonyva, where/how did you put that tide dial in that box for Tides?  Since I have no snow here, I am using Lightning/Tides for this box. Also we seldom have Lightning here so the Tide will be the dominant data showing.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
MS Windows XP Pro-SP3
Davis Vantage Pro 2 Wireless + 1-Wire Solar  + 1-Wire UV  + 1-Wire Lighting
Webcam:Panasonic BL-C1A
tonyva
Senior Member
« Reply #12 on: March 25, 2012, 10:37:16 PM »
Hi Stan
I am away for a day or two, will send you the images etc as soon as I get back.
Cheers
Tony
Silversword
--Stan Y.
Contributor
« Reply #13 on: March 26, 2012, 12:58:29 AM »
Hi Tony,
Thank you for your reply and will be looking for your images and maybe a short tutorial as to where and how to place the necessary script to make it work within the Tide box.
Regards,
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
Silversword
--Stan Y.
Contributor
« Reply #14 on: March 27, 2012, 12:32:05 PM »
Thanks to Tony, I got the tide dial to work with this version.  Now, I need to figure out on how to make the back ground white square to become transparent so it will blend in with the back ground color that I have going.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
BurnsvilleWeather
Burnsville, MN USA
« Reply #15 on: March 27, 2012, 09:20:47 PM »
Stan,
To change the images to GIF, look in the functions for the following:
Code:
global $nexttidequarter;
function select_tide_image ($mins_to_next_tide, $high_or_low) {
 if ($high_or_low == 'high') $nexttidequarter = "High$mins_to_next_tide";
 if ($high_or_low == 'low')  $nexttidequarter = "Low$mins_to_next_tide";
 if($mins_to_next_tide <= 0) return $high_or_low . '_0.jpg';
 if($mins_to_next_tide >= 360) return $high_or_low . '_360.jpg';
 return $high_or_low . '_' . $mins_to_next_tide . '.jpg';
} // end function select_tide_image
« Last Edit: March 27, 2012, 09:22:58 PM by WebsterWeather » Logged
Scott
Silversword
--Stan Y.
Contributor
« Reply #16 on: March 28, 2012, 02:31:05 AM »
Hi Scott,
Thank you for the point where the change be made for editing the type of image that is displayed within this dashboard.  Got your PM on this also.
Hope to work on this area as time permits.
Thanks again for your support and the improvement for this project.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
Silversword
--Stan Y.
Contributor
« Reply #17 on: March 29, 2012, 05:27:49 PM »
Hi All,
Got most of the square white background for the tide dial to be come transparent.  Looks like it still needs some tweaking.  At least got a rough draft going.
Check it out at www.dwayneyamato.com/wx/ for any comments.
--Stan Y.
  Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
tonyva
Senior Member
« Reply #18 on: March 30, 2012, 03:40:31 PM »
Looks good  Stan Smile
Silversword
--Stan Y.
Contributor
« Reply #19 on: March 31, 2012, 01:41:19 AM »
Did more re-fining with the dials.  Less whiteness around the dials now.  Thanks Tony for your comment.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
jahuff
« Reply #20 on: March 31, 2012, 04:25:28 PM »
Hi Scott,
I have the beta running and it seems to be working fine. Dancing
Thanks for all of your work on this.
www.johnsnhweather.com
BurnsvilleWeather
Burnsville, MN USA
« Reply #21 on: April 05, 2012, 07:32:40 PM »
Hi Scott,
Site looks great!
Scott
Scott
BurnsvilleWeather
Burnsville, MN USA
« Reply #22 on: April 05, 2012, 07:33:47 PM »
--Stan Y.
   Maui, Hawaii
Stan,
The dial looks good there!  Nice job making it into a gif!
Scott
Scott
n7xrd
Contributor
« Reply #23 on: April 06, 2012, 10:29:26 AM »
--Stan Y.
   Maui, Hawaii
Looks great how do you get the silver/grey look of the dashboard???
Silversword
--Stan Y.
Contributor
« Reply #24 on: April 07, 2012, 02:53:49 PM »
Stan,
Scott
Thanks Scott for the comment.  It is a png format for now.  Don't know if gif format is better or not.  I still have issues with the dial not being centered vertically between the text and the bottom boarder of the box.  Sometimes it is centered but most of the time it kinda rests on the bottom tangent to the edge.  Is there a way to center it all the time?
Thanks for all the support and improvements to your dashboard.
Steve, hope that you made contact with Chris for info with the background that I PM'ed you earlier.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
Pages: [1] 2   Go Up
Page created in 0.141 seconds with 19 queries.
