May 23, 2013, 01:44:32 AM *
Members: 6617  •  Posts: 178622  •  Topics: 18128
Please welcome TheMOX, our newest member.
Author Topic: Lacrosse 308-807  (Read 2227 times)
VaJim
Virginia Beach Backyard Weather
« on: February 07, 2012, 06:33:36 PM »
Looks like Lacrosse has a new station.
http://www.lacrossetechnology.com/308-807/index.php
New features as compared to the previous 'pro' versions
All battery, no solar panel
color display with bells and whistles
Maybe we'll see it in Costco this fall.
DanS
Chiang Mai weather
Online Online
« Reply #1 on: February 07, 2012, 06:57:38 PM »
The color display looks interesting and cups vs. fan is nice on the anny but it looks like they took a step backwards in some areas. The temps only go down to -4F and humidity down to 20%. Also the temp/hygro being built together with the wind sensor reduces placement choices with no option to add a radiation shield. The troubleshooting section of the manual even states  "Avoid placing the remote sensor in direct sunlight as it will heat up the sensor and provide inaccurate outdoor temperature reading".  How do you place the wind sensor out of direct sunlight?  Think
« Last Edit: February 07, 2012, 09:41:21 PM by DanS » Logged
Dan ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
VaJim
« Reply #2 on: February 08, 2012, 05:53:04 AM »
.....true...sounds like they are keeping the Lacrosse tradition alive! Rolling Eyes
« Last Edit: February 08, 2012, 08:05:44 PM by VaJim » Logged
DanS
Chiang Mai weather
Online Online
« Reply #3 on: February 08, 2012, 06:07:40 AM »
I'm still doing some head scratching with this design.
« Last Edit: February 08, 2012, 08:59:23 AM by DanS » Logged
Dan ThaiWx website
scott
« Reply #4 on: February 08, 2012, 10:29:55 AM »
that is just not common sense...... d'oh!
VaJim
« Reply #5 on: February 08, 2012, 08:07:19 PM »
Dan...the part I didn't get was....without the solar panel facing south (northern folks) you have to rely on some sore of manual alignment...? Rolling Eyes
DanS
Chiang Mai weather
Online Online
« Reply #6 on: February 09, 2012, 12:22:05 AM »
It is confusing. They describe the procedure in the manual as, Mount the wind/thermo/hygro sensor then looking down at the top you rotate the wind vane around to match the compass. At this point you insert the batteries and it sets up it's north bearing this way. The part about of looking to see the top where the compass is while it's mounted? They even mention the ideal location and height for the sensor (either 6' above the peak of your roof or 33' above gnd level). No mention of a safety net below while you're above it using the compass and installing batteries. Rolling Eyes
« Last Edit: February 09, 2012, 01:13:20 AM by DanS » Logged
Dan ThaiWx website
weather1967
« Reply #7 on: February 22, 2012, 11:43:11 AM »
It need big patent for have correct temperatures.Because the temperature sensor it is inside anemometer base,and the summer with foul sun and low wind it will show + 5 c or + 7 c more from the nornal.
Must put out the PCB with electronic components from the plastic base (with batteries),and put it inside a radiation shield,and after add longer cables with soldering iron stick the anemometer cable.
« Last Edit: February 22, 2012, 11:49:55 AM by weather1967 » Logged
Best regards from Greece
Dimitris
http://users.otenet.gr/~meteo/index.html
xykotik
DonkeyTailWX DW6891
I'll deal with it tomorrow
« Reply #8 on: February 22, 2012, 10:35:43 PM »
Are you reading this LaCrosse?  You don't have to play Devil's Advocate to see a lot of flaws here.  The color screen is super-cool, but maybe make it at least compatible with something along the lines of the 28xx sensors that are not so integrated.  The photo of the temp/wind looks like it is made to be mounted on siding or wooden post, definately not above a peak.  The dimensions don't put it very far away from that exterior mounting wall...
Wind/Thermo/Hygro Sensor:
4.5"L x 12.63"W x 3.38"H
(114 x 321 x 86mm)
Facit solem suum oriri super bonos et malos et pluit super iustos et iniustos.
Springtime in Seattle...  March comes in like a lion and out like a wet lion.
kimremmel
« Reply #9 on: February 23, 2012, 09:39:48 AM »
Lets face it....Lacrosse is low end junk !  I know I have one...
weather1967
« Reply #10 on: February 23, 2012, 10:37:51 AM »
Is good with low cost from the electronic-plastic parts (no extreme freeze weather over mountain e.t.c), but it need some mods,for work correct toast
« Last Edit: February 23, 2012, 10:41:54 AM by weather1967 » Logged
Dimitris
wuhu_software
« Reply #11 on: February 25, 2012, 04:47:28 PM »
It is not a bad idea, combining the weather and picture viewer.
It does not appear to have a PC interface so unless they make it compatible with their little gateway that talks only to their site, it may be an appliance only device.
Page created in 0.214 seconds with 18 queries.
