is this the correct understanding now?
Yes, if you use the Envoy to receive/send out data, to your computer or elswewhere, the barametric pressure and inside temperature and humidity will be from the Envoy where it is located.
Is there a way to stop the Envoy from doing this and just use the Vue's Console readings?
To use the console reception data and its inside temperature/humidity and the pressure where it is located then that must be connected to computer/router.
