I post weather data here (
http://www.umaine.edu/umext/potatoprogram/alt_format.htm) and here (
http://www.umaine.edu/umext/potatoprogram/Current_Vantage_Pro.htm). All this is done with the WL software and it is working fine EXCEPT... anytime I configure the settings to upload 1-Week archive data (downld08.txt) the whole upload bombs out. I remove the report from the profile and all is OK. The downld02.txt, NOAAPRMO.txt and NOAAMO.txt work fine (as does everything else) unless I include the downld08.txt file which causes an abort and no new data.
Below is an example of the download.log:
this OK
01/17/12 12:00p (sbjweatherstation) Upload of Data Upload Profile(s) 2 completed OK.
this has the downld.txt included
01/13/12 4:26p (sbjweatherstation) Upload of Data Upload Profile(s) 2 partially completed. See error messages below.
01/13/12 4:26p (FTP) Error (0) uploading file "downld08.txt" to location "umext\potatoprogram\C:\WeatherLink\sbjweath\Templates\test\".
01/13/12 4:26p Error (text given below) while uploading file "downld08.txt" to location "umext\potatoprogram\C:\WeatherLink\sbjweath\Templates\test\". WeatherLink will reset the FTP connection and try again.
01/13/12 4:26p (FTP) 550 umext/potatoprogram/C:: The filename, directory name, or volume label syntax is incorrect.
Help!
