May 23, 2013, 12:32:16 PM *
Members: 6617  •  Posts: 178674  •  Topics: 18129
Please welcome TheMOX, our newest member.
Author Topic: Confusion with VWS tags and AJAX markups  (Read 1904 times)
jwyman
Guest
« on: February 22, 2008, 10:22:40 AM »
I am a little confused in how to implement this stuff.....
I have a .php page which is pre-processed by VWS to change the vws tags to real data within the page. Not hard, right?  Then I decided to give the AJAX stuff a try. My understanding is that I can place the AJAX markup "<span....etc.....>" within my page and have the AJAX script yank the data from wflash.txt and update the span elements within the page according to the markups.. What is confusing me is that i see not only the AJAX realted tags but within those tags appear the old VWS tags which need to be processed by VWS then FTP'd up to the server. Here is where the confusion lays.... AM I missing something? Help plz.... Confused Confused
Jim
DaculaWeather
It's a Jeep thing... you wouldn't understand.
Online Online
SCCA EM #156
« Reply #1 on: February 22, 2008, 10:31:36 AM »
Yes, the AJAX tags contain the VWS tags. Once the file is processed, unless you have other data on your page that neds to be refreshed, you don't really have to continue uploading or even processing that file. The updates will occur automatically (assuming you have WeatherFlash turned on and sending the data to the correct location on the server) without any other processing.
Steve
Davis Vue, VWS, WDisplay, VVP, StartWatch CWOP
jwyman
Guest
« Reply #2 on: February 22, 2008, 11:05:48 AM »
That's what is confusing me. I didn't think you needed to process that template file due to the span ids in the AJAX code. That means you have to have VWS pre-process the tags and FTP it up to the server... Confusion reigns!
saratogaWX
Administrator
Saratoga, CA, USA Weather - free PHP scripts
« Reply #3 on: February 22, 2008, 11:09:47 AM »
I do recommend that folks using AJAX markup also continue to upload the page (with weather software tags) in order to allow folks who've turned off JavaScript to see your weather data anyway.
So, if you're using something like
Code:
<span class="ajax" id="ajaxtemp">^vxv007^^uni007^</span>
to show the temperature, then you need to keep uploading the .htx so that VWS will replace the two weather tags with actual values.  Then the AJAX will kick in (if JavaScript is enabled), and replace the area between the <span></span> with new text.
If JavaScript is turned off in the browser and you don't upload through VWS, then the viewer sees the current temperature as '^vxv007^^uni007^' .. not too helpful.
So.. if your page has weather tags, then you should continue to upload it regularly through the weather software so your website 'works' irrespective of the browser's JavaScript on/off status.
Best regards,
Ken
Davis Vantage Pro Plus - FARS, Boltek-PCI/NexStorm, GRLevel3, WD, WL, VWS, Cumulus, Meteohub
jwyman
Guest
« Reply #4 on: February 22, 2008, 11:26:26 AM »
Ken,
  Rather than doing the below
can't I just do
<span class="ajax" id="ajaxtemp"></span>
 and have the AJAX.js place the valuse in the span for me and NOT have VWS have to pre-process tags?
Jim
saratogaWX
Administrator
« Reply #5 on: February 22, 2008, 12:44:12 PM »
Jim,
Sure, you can use <span class="ajax" id="ajaxtemp"></span> if you like, and NOT upload through VWS.
The only downside is that viewers without JavaScript won't see any weather data (since AJAX won't be functioning).
Best regards,
Ken
WeatherBeacon
Chief
« Reply #6 on: February 22, 2008, 04:38:17 PM »
Hi, Jim.
I use Ken's ajax markup (with VWS/WF), but I still also upload that particular page from VWS to the server every 10 minutes for the reason he mentioned.
Regards,
Kevin...
Mae govannen!
jwyman
Guest
« Reply #7 on: February 22, 2008, 05:12:58 PM »
Ah!!!! Finally understand.. Me slow  Brick wall Brick wall Brick wall Thanks for all the inputs.. Now to make a decision.....
Jim
Page created in 0.104 seconds with 18 queries.
