Author Topic: how to switch off computer after 3 hours running?  (Read 5264 times)
Offline Davidb
    • Glasson Sailing Club
« on: December 28, 2011, 12:55:36 PM »
Hello,
I have recently set an old PC up with Image and Movie Salsa to record images from a camera watching progress on a building site.  Not exactly a weather cam.
I want to make a time - lapse video over a long period ( maybe 12 months)
To avoid the computer running 24/7   ( noisy, power wasting etc )  I have got the Bios to start it every day at 7am which is working fine.
Now I need to figure out how to stop it if nothing moves or at a set time, eg  midday.
I am running Startwatch and Winpatrol to keep things going.
What programme could I  use to shut the PC down correctly?
David
Re: how to switch off computer after 3 hours running?
« Reply #1 on: December 28, 2011, 02:51:22 PM »
You can switch a PC on events with TOFF software from www.dennisbabkin.com
« Reply #2 on: December 28, 2011, 03:07:24 PM »
You could schedule shutdown.exe to run. There are instructions on how to use the Windows scheduler to do this at:
http://www.techrepublic.com/article/schedule-a-restart-operation-with-windows-xps-shutdown-utility/6086387
This would allow a shutdown at a specific time.
You could also use the -t option set to 3 hours (10,800 seconds) with shutdown.exe -s -t 10800 run with a batch file at start-up.
shutdown.exe /? gives the options. (Win 7 shows /s /t but -s -t works too)
Greg
Offline Davidb
« Reply #3 on: December 28, 2011, 04:34:30 PM »
Thanks both for the advice,  I have installed the TOFF software, will see how it goes.
David
Offline Davidb
« Reply #4 on: December 29, 2011, 05:01:26 PM »
well it did stop, but started again, so I have changed it from soft shutdown to " hard shutdown"
see what happens tomorrow, it looks a very useful programme, I hope it works,  David
Offline Davidb
« Reply #5 on: December 30, 2011, 08:59:50 AM »
The problem was that winpatrol had blocked it so I think we are sorted now.
