May 25, 2013, 09:09:57 PM *
Members: 6623  •  Posts: 178918  •  Topics: 18154
Author Topic: Upload webcam still-shots without streaming??  (Read 1188 times)
Chris K
Contributor
« on: December 16, 2011, 08:53:12 AM »
I'm trying to upload still cam pictures from WD, but it doesn't want to work UNLESS I have streaming enabled also.....any ideas?
webcamcapture ver 9.99
Chris
WeatherHost
« Reply #1 on: December 16, 2011, 10:02:05 AM »
Look at a separate operation.  The camera itself may have software to do scheduled uploads via FTP.
Chris K
Contributor
« Reply #2 on: December 16, 2011, 10:09:50 AM »
the cam ftp is working ok, however the cam won't take the still shots unless the streaming is enabled. I don't want to stream...takes alot of resources..
Chris
Weather Display
« Reply #3 on: December 16, 2011, 01:13:29 PM »
are you refering to the wdwebcamcapture.exe program?
I have that taking still image files OK here myself
what type of camera?
Chris K
Contributor
« Reply #4 on: December 17, 2011, 01:09:36 PM »
I am....is that the correct WD program to use to capture cam shots?? I don;t want to stream....but only takes the still shots IF direct stream is enabled....using Logitech Pro 9000
Chris
Weather Display
« Reply #5 on: December 18, 2011, 03:43:23 PM »
I have tested here again using your settings
works as advertised
the file image is updated in the directory you set at the time interval you set
with the streaming working
if you do not want to use streaming
then click disable
in the streaming tab
and click on save (right hand side)
then restart
Page created in 0.089 seconds with 18 queries.
