Hi Linda. As beaudog mentions, For the grounding, being located on sand you should be able to drive at least a 6 foot (the longer the better) copper ground rod next to the galvanized pole base. Use heavy wire and clamp the two together. Being in a salty environment, paint the connections to help slow the rusting and corrosion.
