May 21, 2013, 04:14:53 AM *
Members: 6615  •  Posts: 178462  •  Topics: 18110
Please welcome Christea, our newest member.
Pages: [1] 2   Go Down
Author Topic: Problems after VP2 firmware update  (Read 2188 times)
MesquiteWx
« on: December 01, 2011, 10:53:49 PM »
Hello, I just did the 1.90 firmware update on my VP2 and now on the console the Wind, Wind Chill, Temp, Humidity, Rain Rate are not showing. Also in the bottom right corner it was showing just a R and now it shows a L. Has anyone seen this before and is their something I need to do?
-Thanks
MesquiteWx
« Reply #1 on: December 02, 2011, 12:06:51 AM »
After going back to the Davis firmware download page I noticed I ran a firmware update that wasn't for my model even though it said VP 2 wireless. What can I do to find the correct firmware for my unit? Will I need to call Davis and get it or is there somewhere online I can download it from?
-Thanks
C5250
« Reply #2 on: December 02, 2011, 12:31:16 AM »
I prefer not make WAGs.
What hardware do you have? What firmware did you install? And what makes you think you installed the wrong firmware?
MesquiteWx
« Reply #3 on: December 02, 2011, 12:55:12 AM »
Thanks for the reply. I don't know what you are referring to by WAGs
I have a Davis VP2 6152...
I installed this firmware...
http://www.davisnet.com/support/weather/downloads/software_direct.asp?SoftCat=2&SoftwareID=199
I didn't notice until after I did it, it was to late and noticed it wasn't for my model. Now since I used the wrong one I am having the problems as stated in my first post. Davis doesn't have in firmware downloads for my model listed so I can't revert back.
Flag
« Reply #4 on: December 02, 2011, 03:05:39 AM »
6152 is the complete wireless system, 6312 is the console alone so there shouldn't be any issues with the firmware.
There may be a problem however if you have never updated to accept the direct from PC update and installed this version?
MesquiteWx
« Reply #5 on: December 02, 2011, 03:43:58 AM »
The unit can accept direct from PC updates. Problem is the firmware update didn't include the 6152 that I have and I didn't notice it until after I had already done it. It was my mistake. I got the unit in 2008 and I was updating all my software etc since I was moving everything to a new PC. Since I have installed a Firmware update that wasn't intended for the 6152 now the Wind, Wind Chill, Temp, Humidity, Rain, Rain Rate are not showing on the console. It just shows dashes like this --- where the readings should be.
Is there a way to roll this back and undo the changes or is this a case where I need to contact Davis and have them email me the correct firmware for my model?
-Thanks
johnd
Online Online
« Reply #6 on: December 02, 2011, 04:02:32 AM »
The unit can accept direct from PC updates. Problem is the firmware update didn't include the 6152 that I have ...
I think you're confused. There are four types of 'Direct from PC' VP2 console F/W updates available: Standard console and Envoy; and then cabled and wireless.
If you definitely chose the appropriate type for your specific console (the wireless standard console, I'm guessing, since that's the commonest choice) then that IS the correct choice - there is no other F/W available.
Did the F/W download seem to complete its installation OK? If not then try the F/W update again (having double-checked that you _definitely_ downloaded and used the correct version).
Otherwise, are you sure that you just don't have a wireless reception problem? No chance that the channel settings or transmitter type inadvertently got changed during the F/W update?
« Last Edit: December 02, 2011, 04:09:57 AM by johnd » Logged
Flag
« Reply #7 on: December 02, 2011, 04:03:37 AM »
Please you need to listen to what I am saying!
The 6152 is the Integrated Sensor Suite (ISS) and there is no firmware updates that you can access for this.
So have you tried to update the 6152 (ISS which is not possible) or the VP2 console 6312?
johnd
Online Online
« Reply #8 on: December 02, 2011, 04:23:38 AM »
Actually, Davis use two distinct product ID codes for some products - a model ID and a product ID, which is potentially confusing.
For console and ISS bought as part of a VP2 station, the MODEL ID would typically be 6152 in both cases, but the console PRODUCT ID would be 6312 and the ISS PRODUCT ID would be 6322.
Edit: Actually I need to correct myself here. Having just glanced at the SIM board from a wireless VP2 ISS, I see that even the PRODUCT ID is shown as 6152 (even though it's part of the 6322 ISS assembly). So there's even more scope for confusion on the SIM part number than I realised. But of course this thread is about the console and not the ISS.
« Last Edit: December 02, 2011, 10:37:18 AM by johnd » Logged
Flag
« Reply #9 on: December 02, 2011, 04:36:29 AM »
The point still is there is no firmware upgrade for a 6152, period, doesn't exist.
johnd
Online Online
« Reply #10 on: December 02, 2011, 04:44:42 AM »
If I was being argumentative (which I'm not  Smile) I could say that it's perfectly valid to talk about a firmware update for a 6152 wireless console, for example. But I do know what you mean.
SlowModem
WX @ 26.4 kbs
« Reply #11 on: December 02, 2011, 05:10:11 AM »
This seems like the only firmware update that is applicable:
The others are for envoy, cabled consoles or for using the updater.
Maybe you should download it again and try running it again.  You wouldn't be worse off than you are now.
Ten Mile, TN
http://wattsbarweather.net
W3DRM
« Reply #12 on: December 02, 2011, 10:46:51 AM »
I would suggest going to the Davis website
and THEN, looking very carefully, select the firmware download for your SPECIFIC unit. Please note older VP2's with a firmware date earlier than what is specified on the above webpage CANNOT be updated directly through your PC. If your VP2 falls into that category then you will need to borrow an update unit from Davis. Once you have a current version you will be able to download using the direct to PC firmware executables.
Also, the firmware documentation and installation process CLEARLY warns you that installation of the wrong version MAY result in your not being able to use the unit any longer and you will have to send it to Davis for repair. I'm sure they would also charge you for that too.
« Last Edit: December 02, 2011, 10:48:24 AM by W3DRM » Logged
Don - W3DRM - Minden, Nevada --- Davis Wireless VP2, VWS 14.00 p101,
StartWatch, VirtualVP, VPLive, WL 5.9.3, Win7 Ultimate-SP1
--- Logitech QuickCam Fusion webcam
MesquiteWx
« Reply #13 on: December 02, 2011, 10:56:45 AM »
Guys you are exactly right my apologizes, as you're right Davis dose confuse this since I wasn't aware of the two different model numbers. All I knew is I had a VP2 6152. I wasn't aware the console was a different model number. So after seeing the replies I looked on the back of the console and it said 6132 so the ISS is 6152. I ran a firmware update on the console. So the one I ran is the correct one according to the Davis firmware link. I ran the same one that Slow Modem and myself have both posted a link to. I don't believe it is a connection problem since the Barometer is still getting signal and it worked perfectly before I did the update. Before posting I did run the update twice and they completed successfully but still have the same result on the console.
On the Davis page it states "DO NOT USE the Direct to PC Install file if your Vantage Pro2 firmware revision is dated before November 28, 2005." Mine wasn't as it was dated 2007 so it was able to do direct PC connect update. Otherwise it wouldn't have any accepted this firmware I loaded at all. It is a little confusing since it says VP2 and not console. I bought this station in 2007 or 2008. Now that we have the model and know that I did in face install the correct firmware and ideas?
-Thanks
MesquiteWx
« Reply #14 on: December 02, 2011, 10:58:40 AM »
That is where I went, it is how I got the firmware initially.
johnd
Online Online
« Reply #15 on: December 02, 2011, 11:04:05 AM »
...now that I did in face install the correct firmware and ideas?
As per my post above:
'Otherwise, are you sure that you just don't have a wireless reception problem? No chance that the channel settings or transmitter type inadvertently got changed during the F/W update?'
MesquiteWx
« Reply #16 on: December 02, 2011, 11:19:08 AM »
No It is not a wireless reception problem as I explained previously I am getting Barometer and rain readings. the Reception is 98-100% and I have never had problems with reception.The ISS sits 15-20' above the room where the Console is. So I am 110% sure it's not reception. It worked fine BEFORE doing the firmware update. Which says it was the firmware update that caused it because installing a firmware update alone isn't going to cause poor reception afterward I wouldn't think since it had excellent reception before the update. I also did go through the setup and nothing was changed. To my knowledge there wasn't a setting to change the channel which I wish there was because I was looking and it said transmitting.
Anyways, that is irrelevant now as I ran the update for the THIRD time and I cause 3 times a charm as It is back to working perfectly again and displaying everything. Will need to keep a eye on the rain as it has rained but not showing anything. Going to climb up there and make sure nothing is blocking it which is a possibility with leaves and debris falling this time of year.
Thanks to everyone for all your help, it was greatly appreciated.
dalecoy
« Reply #17 on: December 02, 2011, 11:45:49 AM »
Note that the barometer is in the console, so getting that reading doesn't mean anything about reception.
However, rain, wind, outside temp/humidity are outside, so if you're getting any one of those then it's not a reception problem.  In any case, you can check the reception at the console (see the manual).
Weather Display
« Reply #18 on: December 02, 2011, 12:42:03 PM »
thats the key
you are not getting any data from the ISS
MesquiteWx
« Reply #19 on: December 02, 2011, 02:03:04 PM »
Thanks guys I will make note of those letters for future reference. As of now everything is back to normal and VVP has connected and sending data to WeatherLink, VWS, WD, Cumlus and VPLive.
Ericc
« Reply #20 on: December 15, 2011, 09:09:20 PM »
 I wish I found this thread yesterday...   I did exactly as the original poster did and upgraded my firmware for my 6152 unit from 1.60 to 1.90 and now the unit no longer receives packet data of any kind from any ISS unit.  I've run all the diagnostics, put the transmitter into test mode.  There is ZERO reception by the console after the upgrade.  It's functional in all other areas.   I flashed the firmware twice and both times was reported as successful.
I've cleared the data and reset the console.. Still nothing.
Everything was working just fine before the update.. This is NOT a transmitter problem it's a firmware problem.  DO NOT INSTALL 1.90 on a model 6152 console.
Does anyone know of or have a copy of the Vantage Pro2 Wireless Console Firmware v1.6, Direct PC Install file.  Davis has pulled all the older firmwares from their website.
I need to roll back the firmware to a version that works.
Eric
north of 60
Contributor
« Reply #21 on: December 15, 2011, 09:47:12 PM »
No issue with the firmware update on davis website.  I did both of my consoles without a hitch.  Why post on here that the 1.90 firmware update on davis website doesn't work?  You likely did something wrong and didn't follow directions.
dalecoy
« Reply #22 on: December 15, 2011, 10:02:05 PM »
Did the update go correctly to completion?  What firmware version does the console say it has?  [Procedure in the manual]
Did you perhaps wiggle the logger in the console after the update?  If so, try the installation procedure from the manual.  Complete power down including removing batteries, remove and install logger, reinstall power.
Have you tried re-installing the firmware update?  How did that go?
If you really want older firmware, call or email Davis and they'll tell you where to get it.  But better to ask them for support.  And there's actually a Beta version 2.03 or something like that available.
Please let us know how you solve the problem.
« Last Edit: December 15, 2011, 10:07:53 PM by dalecoy » Logged
C5250
« Reply #23 on: December 15, 2011, 10:15:35 PM »
Cleared what data? What did you do to "reset" the console?
Did you go into setup mode and insure the config is correct? It can take a few minutes for a Console to reacquire the signal from an ISS, how much time did you allow for that?
Ericc
« Reply #24 on: December 16, 2011, 02:27:20 AM »
 There is an option to clear all stored data which I did after the unit failed to process or detect the wireless data.   I waited 24 hours and the unit still had not received any data or sync'd with the ISS.
I've been in setup mode many times, everything is correct. Remember this unit was working perfectly without error before doing the firmware update.  I've reinstalled the firmware update 3 times so far. Each time the update has been without error.  I've removed power for an hour from both the ISS and the console and let it sit another 12 hours without it receiving any data.
I've run the unit with and without the data logger also.
How do you get access to the beta firmware?
Eric
Pages: [1] 2   Go Up
Page created in 0.129 seconds with 19 queries.
