May 18, 2013, 06:08:46 PM *
Members: 6609  •  Posts: 178149  •  Topics: 18096
Pages: [1] 2   Go Down
Author Topic: Sebectec IP camera  (Read 4242 times)
sebeclake
Contributor
« on: November 28, 2011, 08:07:52 PM »
If anyone would like to try it I have a new application that reads an IP cam or any web .jpg image.  So far I have tried it with Axis and Stardot cams.  It can overlay temperature and wind from weatherunderground XML or NOAA weather stations (use wundermap to find a station).  Makes time-lapse video with upload.  Uploads still images to either of 2 FTP sites.  It has a 30 day trial.  Any feedback is appreciated.
SebecTec IP cam download: www.sebectec.com/ipcam
Examples - you would pasted these into the GUI
              Stardot - USC Roach Cam: http://129.252.89.30/netcam.jpg
              Axis - Tokyo Times tower: http://221.255.120.171/axis-cgi/jpg/image.cgi
-Mike
weather1967
« Reply #1 on: November 30, 2011, 09:57:32 AM »
Hi Mike there is some manual for Sebectec?
I have the tincam software for the camera pro 9000 Logiteck ,i downloaded the free version Sebectec,i put the source image folder from tincam ,and i make a new one video folder file,i press make video now ,but it not work.
« Last Edit: November 30, 2011, 10:08:02 AM by weather1967 » Logged
Best regards from Greece
Dimitris
http://users.otenet.gr/~meteo/index.html
sebeclake
Contributor
« Reply #2 on: November 30, 2011, 11:32:34 AM »
Hi, take a look at the settings under "set up processing" on the Video tab page.  If you want it to search subfolders there is a checkbox for that.  The default setting is to process only images created today.  Use the calendar or process all jpg image button.  I think the processed images should all be the the same aspect ratio.  Sorry there is no manual as yet.
« Last Edit: November 30, 2011, 11:42:38 AM by sebeclake » Logged
Axelvold
« Reply #3 on: November 30, 2011, 03:52:49 PM »
-Mike
You did wrote 30 day trial, I did just download it and it says that the evaluation period have expired.
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
sebeclake
Contributor
« Reply #4 on: November 30, 2011, 05:02:29 PM »
There seems to be an issue with the license manager.  If you had previously installed the SebecTec program for the Olympus camera it won't issue a new 30 days for the IP version.  A fresh insall will get 30 days.  Is that the case?  I will see if I can correct that and issue a new build.  May take a few days.
-Mike
weather1967
« Reply #5 on: December 01, 2011, 12:50:27 AM »
Mike when i open the free sebectek program, when press make a video now  ,pop up window say mencoder.exe have problem and must stop the aplication.
Where is this problem ?
Dimitris
Axelvold
« Reply #6 on: December 01, 2011, 01:28:30 AM »
-Mike
Yes. I did previously have the sebevtec program installed.
Looking forward to that fix.
Lars Magnusson
Axelvold / Sweden
sebeclake
Contributor
« Reply #7 on: December 01, 2011, 06:29:48 AM »
Re mencoder - make sure when making a video that there are photos in the video source folder and that they all have he same aspect ratio.  In general, you should create a folder just for the downloaded images on the Time-Lapse & FTP tab page and use the same folder for Source Images on the Video tab page.
« Last Edit: December 01, 2011, 08:31:08 AM by sebeclake » Logged
weather1967
« Reply #8 on: December 01, 2011, 09:07:31 AM »
You are sure the free version make and upload videos ?
I tried it enough but not work anything ,anyway i will use the photolapse with a embed code for website and i upload manual-operated.
Dimitris
sebeclake
Contributor
« Reply #9 on: December 01, 2011, 09:20:40 AM »
Dimitris, yes of course absolutely it makes and uploads the time lapse video. If you like send me a screen capture of your Video settings.
-Mike
« Last Edit: December 01, 2011, 09:59:28 AM by sebeclake » Logged
Axelvold
« Reply #10 on: December 01, 2011, 09:22:12 AM »
It does work, I use for 5 of my 7 webcams.
Lars Magnusson
Axelvold / Sweden
weather1967
« Reply #11 on: December 01, 2011, 09:29:42 AM »
Ok ok,here we are,all the pics in file tincam/pictures have the same dimensions from tincam software 640x480.
« Last Edit: December 01, 2011, 09:32:10 AM by weather1967 » Logged
Dimitris
Axelvold
« Reply #12 on: December 01, 2011, 09:35:17 AM »
I see some difference betwen our settings.
For example I have set it to process the images at 23:59 and I have ticked in the option date range.
And I only do a movie once a day.
You could try that and see if that's working.
Lars Magnusson
Axelvold / Sweden
weather1967
« Reply #13 on: December 01, 2011, 10:19:38 AM »
I fix it the problem it was not support Greek language at files,i remove the tincam file in the D:/ disk without the Greek  <<Tά έγγραφά μου >>,and work perfect
Thanks a lot
Dimitris
duke666
Contributor
« Reply #14 on: December 05, 2011, 02:55:11 PM »
Will this only work with IP cameras or can it be used with USB too?
Duke
Davis VP2 - 24hr FARS, Cumulus weather software.
Nightingale Weather PHP
sebeclake
Contributor
« Reply #15 on: December 05, 2011, 06:23:23 PM »
It can read some IP cams and can also read the .jpg image from a website.  So if your USB cam is uploading an image the software can read it back, archive and make the time-lapse.  Direct USB is coming. -Mike
cohassetsteve
« Reply #16 on: March 08, 2012, 07:16:05 PM »
I'm currently using the free version of sebectec webcam version 3.2.3 software and all works well, I have found a glitch, though, when I decided to make .flv videos instead of .avi to make it easier to publish on my web page. The flv videos have color problems - with the avi's the colors seem to be true, i.e. the plants are green, etc and with the flv version some of the plants are  sort of blue. Is there come sort of adjustment that could be made to remedy that of is it just the nature of flv's?
Another question it there a way to stream the avi's from a web page? If so my question above is moot.
sebeclake
Contributor
« Reply #17 on: March 09, 2012, 01:07:40 PM »
You can try increasing the bit rate and see if that makes a difference in the video quality.  The "payfor" versions - IP cam and SP-500 versions have just been updated with an .mp4 video file option.  You could try that format and see if it makes a difference.  I don't yet have the .mp4 option in the free version.
cohassetsteve
« Reply #18 on: March 09, 2012, 11:41:21 PM »
Thanks for the response, I should have posted here sooner to inform you that the wierd colors were being generated by VLC    Embarassed absolutely no problem with your software
DaculaWeather
SCCA EM #156
« Reply #19 on: April 13, 2012, 04:44:00 PM »
Mike so far I love it.
Question. If I wanted to create 7 videos, one for each day of the week, and link to them on a web page, is that possible? In other words, after video 7, it starts over and overwrites video 1.
Steve
sebeclake
Contributor
« Reply #20 on: April 13, 2012, 05:48:16 PM »
It's not currently setup to make a new name for each day.  I could think about having that as an option to upload and cycle the name over N-days.
What you are asking for could be done external to the program by using a script to copy the file and rename it each day and then upload.  Or it might be possible to do that on the server using a php script.  I haven't used php much so I can't help there.
-Mike
DaculaWeather
SCCA EM #156
« Reply #21 on: April 13, 2012, 09:46:05 PM »
Something like that would be great.
Steve
gt651
« Reply #22 on: April 17, 2012, 12:17:18 PM »
-Mike
Anyone needing custom script work including php, I'd highly recommend Dave Tuplin at:
http://www.dwgsoftware.com/
He has done many scripts for my site and I couldn't be happier.  You'll get a professional job for a fair price.
DaculaWeather
SCCA EM #156
« Reply #23 on: April 17, 2012, 12:25:09 PM »
GREAT! I've been looking for a good php developer!
Steve
Stetson1
Stetson Hills Weather
« Reply #24 on: April 17, 2012, 02:36:36 PM »
You don't really need any PHP code, a simple windows script could be setup to take the file on a given day and rename it to like monday.wmv, each day of the week could be covered, then all you need to do is automate it using scheduler (or something like that) and upload to your site.
Todd
Weather Underground PWS KCOCOLOR131
MADIS ID: D4524
Pages: [1] 2   Go Up
Page created in 0.121 seconds with 19 queries.
