Weather Display
« Reply #75 on: February 07, 2012, 06:37:40 PM » |
Maybe I missed this, but does this item also store data like the Davis version for a period of time in case WD gets hung or is shut down? yes, that is posted in the information in this thread
belfryboy
« Reply #76 on: February 08, 2012, 03:23:59 AM » |
I currently run sloweather's cable which works fine... Also is this cable capable of doing software updates to the console should Davis release one in the future?
Yep. That's right, it has the same storage capacity as the Davis logger. I can't be certain that it does the firmware upgrade, since I have a VP1 that does not support cable uploads, but if SloWeather's cable can do it, then I don't see any problems, perhaps anyone that receives one of my cables can give it a go and report back?
Buy your own clone logger
Nessimmersion
Offline
« Reply #77 on: February 09, 2012, 07:37:58 AM » |
Ref belfry boy Is there a way to configure your datalogger to work wirelessly from a Vantage Vue to a PC? I will not be able to run a cable from here my console is situated to my PC, so I'm looking for a workaround to allow me to save the data to my PC. Any help / guidance much appreciated
frisfur
Offline
« Reply #78 on: February 09, 2012, 09:35:56 AM » |
Hi Rob Received and installed the logger All is working beautifully thanks very much!
The only thing that caught me is in the configuration screen of Cumulus Make sure communication is set to serial not USB, I thought as it had a USB connection that was the one to choose, After a few minutes of playing around, clicked on serial and hey presto! I have data!
« Last Edit: February 09, 2012, 09:39:57 AM by frisfur »
MaxHawkins
« Reply #79 on: February 09, 2012, 10:01:05 AM » |
If you're running Windows (I imagine you are) then this might be a shout http://www.silexamerica.com/products/usb_device_connectivity/sx-2000wg.html. I was looking at getting their Ethernet-only version for my console but as it turned out I didn't end up with that setup. It has software for connecting the USB to the computer. Saying that, I can't guarantee it will work but I can't see any reason why it won't.
belfryboy
« Reply #80 on: February 09, 2012, 10:25:21 AM » |
Thanks Chris, i hadn't thought to point this out, but that is correct. since the PC sees the logger on a virtual com port, then Cumulus should be set for serial. Rob
Nessimmersion
Offline
« Reply #81 on: February 09, 2012, 11:37:37 AM » |
If you're running Windows (I imagine you are) then this might be a shout http://www.silexamerica.com/products/usb_device_connectivity/sx-2000wg.html. I was looking at getting their Ethernet-only version for my console but as it turned out I didn't end up with that setup. It has software for connecting the USB to the computer. Saying that, I can't guarantee it will work but I can't see any reason why it won't. [/quote] Thanks, The Silex is around £105 here & a datalogger from Befryboy would be around ??? So am I better spending this much on a probable fix or should I spend a fortune on the Davis remote set up? Any opinions Thanks
belfryboy
« Reply #82 on: February 09, 2012, 11:46:29 AM » |
Nessimmersion
Belfryboy logger is priced at £50 (and that includes postage.) although I could add acouple of wireless transponders for about £30, give me a couple of days and I'll let you know if I have a solution...
PM me if you are interested
« Last Edit: February 09, 2012, 03:07:32 PM by belfryboy »
MaxHawkins
« Reply #83 on: February 09, 2012, 01:12:35 PM » |
Thanks Chris, i hadn't thought to point this out, but that is correct. since the PC sees the logger on a virtual com port, then Cumulus should be set for serial. Rob I spent about 10 minutes trying to work out why it wouldn't connect too, then I changed it to serial and behold, it worked.
« Last Edit: February 10, 2012, 07:43:24 AM by MaxHawkins »
frisfur
Offline
« Reply #84 on: February 10, 2012, 05:37:58 AM » |
Nessimmersion
I would be intersted in some sort of wireless transponder too Rob How big would it be and how would it work?
phill
Offline
« Reply #85 on: February 10, 2012, 07:25:00 AM » |
Hi Rob Received and installed logger runing great. logger very well made and it works a treat if you are thinking on buying one get one you will not be sorry. thanks alot rob.
belfryboy
« Reply #86 on: February 10, 2012, 07:48:40 AM » |
 Thanks for the reviews guys, i have been wanting to do this sort of thing for a while, glad to be of service. "Roll up roll up, get 'em while they're 'ot!!"Again many thanks to Dekay for the inspiration!
Gretnawx
« Reply #87 on: February 10, 2012, 11:24:40 AM » |
So the question is when will the lawyers be calling regarding patent violation. Or perhaps you have a arrangement with Davis to market their patented technology?
There are 10 types of people in the world - Those that know binary and those that don't
SlowModem
« Reply #88 on: February 10, 2012, 06:58:07 PM » |
 Thanks for the reviews guys, i have been wanting to do this sort of thing for a while, glad to be of service. "Roll up roll up, get 'em while they're 'ot!!"Again many thanks to Dekay for the inspiration!  ROFL That sounds just like Miss Brahms!
Garth Bock
« Reply #89 on: February 10, 2012, 09:16:26 PM » |
 Davis VPro2,VWS,WL,VVP,WD,WDL,Cumulus,WV32,VPLive
Bushman
« Reply #90 on: February 11, 2012, 12:01:58 AM » |
What patent??
belfryboy
« Reply #91 on: February 11, 2012, 05:37:08 AM » |
apparently Davis have a patent on either SPI communication protocol, or Dataflash chips, I didn't know that, thanks for pointing it out.  I have made sure that this will not work with WeatherLink software, even though I now know how to. This is to prevent software piracy, which has previously been a problem. I'm sure Davis have been following this thread, and as of yet have received no contact.
« Last Edit: February 11, 2012, 11:10:38 AM by belfryboy »
ukwoody
Senior Member
Offline
www.woodyspembs.org.uk The Pembrokeshire web site
« Reply #92 on: February 11, 2012, 12:40:25 PM » |
I would have thought that providing you havent gone out of your way to break their patents etc, and you keep things on a small local scale, it would probably cost them more to sue you then to let you get on with it. Especially since, (Davis take note here!) I only bought a Vue, BECAUSE you have made an interface available at a sensible cost. If I HAD to buy the Davis one, I would have bought the OS WMR200 instead due to lack of funds. So actually Davis have already gained form you.
Anyway, since they havent been onto Sloweather yet either, I really wouldnt worry at this stage my friend. Looking forward to getting mine this coming week! Woody
xykotik
« Reply #93 on: February 11, 2012, 12:43:25 PM » |
apparently Davis have a patent on either SPI communication protocol, or Dataflash chips, I didn't know that, thanks for pointing it out.  I have made sure that this will not work with WeatherLink software, even though I now know how to. This is to prevent software piracy, which has previously been a problem. I'm sure Davis have been following this thread, and as of yet have received no contact. I'm sure the datalogger is patented by Davis. But unless you cloned theirs, yours is an new way of doing the same thing. Unless the datastream from the connector on the back is copyright (like National Football League broadcasts, I don't think possible) then you are just using what you found, like DeKay with the wireless ISS data in his console project. But if there is a patent on the protocol, then you can't create a new invention that creates it or uses it like an open standard. If it was scrambled using a proprietary (trade-secret) method, then you would need their license to use it, like cable-tv signals. If the chip is commerically available without restricted use, then that shouldn't be a problem, as when you patent a chip, you can control it's use through specific language in the patent. For example, if it says "this chip is for logging the davis protocol" then they wouldn't be distributing it to the open market. If the patent says "this chip can be used for logging" and they make it publicly available, you can purchase and use it for your own logger, just not clone/counterfeit the chip. You can't patent a broad use, it has to be specific. So, unless the answer to any of these questions is yes, you are probably in the clear, otherwise you will need a license from the patent holder to distribute/sell your derivative invention. By the way, if you wanted patent protection for your NEW improved device, the clock is ticking. Under US and EU laws, you have one year from the time you made it public to apply or it becomes public domain. - Is the protocol patented?
- Is the datastream claimed under copyright?
- Does the patent on the chip list specific intended (controlled) uses?
- Did you reverse engineer any portion of a patent by deconstruction of a licensed product?
- Did you have access to any resources or proprietary materials belonging to the patent holder?
Note, this is not legal advice. Consult an attorney for that. I'm probably making all of this up. YMMV. Yada yada. If I HAD to buy the Davis one, I would have bought the OS WMR200 instead due to lack of funds. So actually Davis have already gained form you.  Brilliant example of free-market capitalism.
« Last Edit: February 11, 2012, 12:46:46 PM by xykotik »
Facit solem suum oriri super bonos et malos et pluit super iustos et iniustos.Springtime in Seattle... March comes in like a lion and out like a wet lion.
belfryboy
« Reply #94 on: February 11, 2012, 02:24:25 PM » |
Davis usually list their patents in their documentation, and having looked through these I can see no reference to the datalogger. The datalogging chip is an off the shelf Dataflash chip, commercially available, and all Davis do is write values to memory addresses, and read them back again. I would suggest that it would be extremely hard for Davis to patent that process.
George Richardson
« Reply #95 on: February 11, 2012, 02:56:17 PM » |
"I would suggest that it would be extremely hard for Davis to patent that process." Yeah, they're not a drug company!
DeKay
« Reply #96 on: February 11, 2012, 07:05:18 PM » |
Again many thanks to Dekay for the inspiration!  No problem. Unless you count frying my LCD a problem. My replacement is in the mail so that problem should go away soon. I'm sure the datalogger is patented by Davis.
Show me. I'll help you out and give you a head start. I have made sure that this will not work with WeatherLink software, even though I now know how to.
Interesting... The datalogging chip is an off the shelf Dataflash chip, commercially available, and all Davis do is write values to memory addresses, and read them back again. I would suggest that it would be extremely hard for Davis to patent that process.
^^^ This ^^^. And the entire data exchange is driven by the firmware on the console, which we neither copy nor modify. The low level interface is Atmel's design, from their processor chip to their memory chip. The clone logger is analagous to putting Energizer batteries into a Duracell flashlight. "Roll up roll up, get 'em while they're 'ot!!"
UK humour (note the spelling) will always be beyond me, I'm afraid.
xykotik
« Reply #97 on: February 11, 2012, 07:27:22 PM » |
Quote from: xykotik on Today at 09:43:25 AM I'm sure the datalogger is patented by Davis.
I said I'm no patent attorney. How about... "Davis 'may have' patented it." If they didn't, definately no problem. If they did, I still don't see how either yours or Bellfryboy's work would be a problem. A proto monkey-wrench looks a lot like a snap-on. I say "nice work!"
Bushman
« Reply #98 on: February 13, 2012, 12:42:53 PM » |
apparently Davis have a patent on either SPI communication protocol, or Dataflash chips, I didn't know that, thanks for pointing it out.  I have made sure that this will not work with WeatherLink software, even though I now know how to. This is to prevent software piracy, which has previously been a problem. I'm sure Davis have been following this thread, and as of yet have received no contact. What software piracy?? You can freely download WL if that is your concern. Sure, they say you need a license, but that sure does not match with their actions. heck, I think the CD license is really just the cost of the box and CD.
belfryboy
« Reply #99 on: February 13, 2012, 03:52:52 PM » |
AFAIK you cannot download WL in it's entirity, just the upgrades. Either way using it without a licence would be deemed as piracy, certainly in the UK it would. Whilst many people do use "hooky" copies of software, I do not wish to promote this. Likewise I would not suggest that any one uses a hacked copy of WeatherDisplay.
