May 23, 2013, 04:07:32 PM *
Members: 6618  •  Posts: 178687  •  Topics: 18129
Please welcome moranbahweather, our newest member.
Author Topic: Backdoor RH% Sanity Check?  (Read 1090 times)
Old Tele man
Online Online
« on: November 11, 2011, 06:38:42 PM »
How many people have compared their OSI weather station RH% values against other surrounding CWOP or NWS values in an effort to learn how "close/far" their OSI values are from reality?
I ask, because it's looking as though the TEMP's are OK (±1ºF), but the RH% and DEWPOINT TEMP (Tdp) values are obviously not OK. The Tdp values around me (3 other CWOP within 5 miles) seem to be basically "flat" with minor fluctuations (not counting big WX changes), while MY Tdp values are mirroring the TEMP shape both day and night...which (to me) indicates the RH% values are wrong, because Tdp is merely a derived (calculated) function of TEMP and RH%.
Anybody else notice similar "idiosynchracies" in their OSI weather station outdoor sensor (THGN801) values, especially RH% and Tdp? If yes, what have you done to compensate for their error(s)? Any suggestions or ideas? I've already written OSI asking about "better" accuracy, but I'm not holding my breath.
Thanks...
« Last Edit: November 11, 2011, 08:16:16 PM by Old Tele man » Logged
• SYS: Davis VP2/WL-IP & Envoy8X/WL-USB
• CWOP: DW6988 - Cortaro, AZ
• WU: KAZTUCSO202 - Countryside Homes
SlowModem
WX @ 26.4 kbs
« Reply #1 on: November 11, 2011, 07:05:13 PM »
Thanks...
AZ CWOP - DW6988 (inactive)
I have a LaCrosse, Davis and OS all on the same pole.  They all read pretty close (most of the time) (except that the Lacrosse only goes up to 87% RH).
Ten Mile, TN
http://wattsbarweather.net
Faceng Ret
Senior Member
« Reply #2 on: November 11, 2011, 07:21:56 PM »
I just recently installed a Davis VP2 and have had an OS WMR200 for over 2 years. I have the temperature/humidity sensors mounted on the same post at the same height. Both the OS and Davis sensors are mounted in a daytime FARS. The temperature readings are consistently within 1/2 a degree of each other, but the OS humidity reading is always 8 to 10 percent lower than the Davis. On the consoles which are within 2 feet of each other, the OS always shows the same 8-10 percent less for indoor humidity. On CWOP the humidity on the Davis is very close to that reported by stations within 4 miles of my station.
SlowModem
WX @ 26.4 kbs
« Reply #3 on: November 11, 2011, 07:40:17 PM »
...which LaCrosse outdoor sensor are you using?
I have the LaCrosse WS-2316, OS WMR968 and Davis VP2.
Ten Mile, TN
SlowModem
WX @ 26.4 kbs
« Reply #4 on: November 11, 2011, 08:38:38 PM »
...something I didn't mention, the outdoor THGN801 (as well as the indoor 10-channel THGR810) are the newer Protocol #3 devices, not the older Protocol #2.1 devices, which negates any "backward" compatibility.
...I searched, and see that OSI has had problems with their RH% sensor accuracies for quite awhile now...although, those would have been Protocol #2.1 sensors.
Now that I think about it, I don't use the THGR968, the RH died shortly after being put in serivce.  I use the THGR122N.
Ten Mile, TN
Page created in 0.096 seconds with 18 queries.
