May 22, 2013, 04:59:50 AM *
Members: 6617  •  Posts: 178537  •  Topics: 18117
Please welcome TheMOX, our newest member.
Author Topic: How many?  (Read 908 times)
moehoward4
Online Online
« on: October 23, 2011, 09:55:41 AM »
I'm running VVP with N8VBvCom and WL, VWS, VPLive and Cumulus. Can I get more ports out of the N8VBvCom, and how do you do that??   TIA    Jack   The latest versions of everything.....
saratogaWX
Administrator
Saratoga, CA, USA Weather - free PHP scripts
« Reply #1 on: October 23, 2011, 04:11:36 PM »
VirtualVP only supports 4 concurrent COM ports (so no more ports on that system once they're all in use), but it does support an additional 4 TCP/IP ports (for a total of 8 weather software programs you could be running).
If your new weather software supports TCP/IP connection, then use that, otherwise, you can switch one of the current COM port users to use TCP/IP instead and free up the old COM port for use by the new software.
I have VVP set to use COM ports (5 to 8 ) for WeatherLink, Weather-Display, VWS and Cumulus.
Then the first TCP port is used by Meteohub on the SheevaPlug. .. I still have 3 more TCP ports to play with.
BTW.. I've found that a second VVP running on a different PC on my local network can easily connect to the first VVP via TCP/IP and offer another 4 COM and 4 TCP ports for testing on the second system Smile
Davis Vantage Pro Plus - FARS, Boltek-PCI/NexStorm, GRLevel3, WD, WL, VWS, Cumulus, Meteohub
moehoward4
Online Online
« Reply #2 on: October 23, 2011, 04:16:15 PM »
saratogaWX, thanks for the help, now to go seeing about the new alternatives.   THANKS again
Page created in 0.094 seconds with 18 queries.
