Author Topic: yr.no forecasts worldwide-script  (Read 24273 times)
Offline mickopla
    • Waterford City Weather
Re: yr.no forecasts worldwide-script
« Reply #25 on: December 20, 2011, 12:01:21 AM »
I have the script working but want to embed it in my website with a yowindow above. I tried a few things with no luck. Whats the best way to include it in a website php ? Here is what i have so far www.waterfordcityweather.com/yr/yrtest.php
Mick
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
« Reply #26 on: December 21, 2011, 04:53:27 PM »
hi
send this pM to Mick:
I started in yr_xmlII.php with:
ini_set('display_errors', '1');
for cache/paths I have:
// Cachesettings etc. settings
$qarefetchSeconds = 3600;   // How often it refresh the cache, 3600 recommended
$imgdir = "images2/";   // Icons-folder
$jsfolder = "jquery/";
$cssfolder = "scripts/css/";
$cachefolder = "/var/www/vhosts/weersverwachtingen.eu/httpdocs/cache/";
....and here (around line 146 ) in yr_xmlII.php I filled in my station lat/lon
date_default_timezone_set($tz);
$qacacheName = $cachefolder.md5($lat.$lon).'.xml';
$URLS = "http://api.yr.no/weatherapi/locationforecast/1.8/?lat=52.4385368327251&lon=4.8264312744140625";   // URL to the ENGLISH page on yr.no where location is
were the lat/lon is my station so find out
hope this helps
Hi guys,
i've set it like Ed too but some problems persist.
City doesn't still show but ony lat and long.
The nearby webcam below the page doesn't show anymore.
Geoip doesn't work.
Link: http://www.meteocarmignano.it/wxysforecast.php
Any ideas?
Regards,
Alessandro
« Last Edit: December 21, 2011, 04:55:26 PM by i_fiorentino »
Offline mickopla
« Reply #27 on: December 22, 2011, 10:24:26 AM »
hi
hope this helps
Hi guys,
Geoip doesn't work.
Any ideas?
Regards,
Alessandro
Any chance you could post the code you used for your wxysforecast.php. I want to put my yowindow and forecast script on the one page like yours. Cheers
Mick
Offline jompa68
« Reply #28 on: March 05, 2012, 04:48:12 AM »
Hello,
i get alot of errors if i run default settings in yr_xmlII.php. i only change to have my location as default but it will not appear in front page.
// Units
$useC = 1; // Use Celsius, else F
$useKMH = 0; // Use Km/h
$useMPH = 0; // Use Mph, if both KMH and MPH is zero is default m/s used
$useHPA = 1; // Use hPa, else inHg
$useMM= 1; // Use mm, else in
// Timesettings, normal PHP/date-tags used
$datestyle = "d.m.Y"; // Style of short date
$timestyle = "H:i"; // Style of time
$longdate = "d.m.Y H:i"; // Style of long time + date
$deftz = "Europe/Stockholm";
$pagename = "yrtest.php";
$geonameusr = "hofors"; // IMPORTANT! You need to signup at geonames.org (FREE), put username here
$imgdir = "images/"; // Icons-folder
$cssfolder = "css/";
$cachefolder = "cache/";
$days = array('Sunnuntai','Maanantai','Tiistai','Keskiviikko','Torstai','Perjantai','Lauantai');
// Default place
$cod = "SE";
$cou = "Sweden";
$cit = "Hofors";
$lat = 60.5457;
$lon = 16.2866;
http://www.xn--hoforsvdret-r8a.se/yr/yrtest.php
What have i miss?
Offline mickopla
« Reply #29 on: March 09, 2012, 01:40:40 PM »
Hello,
// Units
// Default place
$cod = "SE";
$cou = "Sweden";
$cit = "Hofors";
$lat = 60.5457;
$lon = 16.2866;
What have i miss?
I've been trying for months to find a solution to the same problem with no luck. Its a shame as it would be a great script if it worked properly.
    • Meteopistoia.it
« Reply #30 on: March 10, 2012, 05:20:45 PM »
Hi guys,
If you choose another city from menu the forecast seems to remain the same!  :-(
It remains also the impossibility to choose default city from menu....
Does it happen to you too?
Regards,
Alessandro
Offline mickopla
« Reply #31 on: March 11, 2012, 02:20:34 PM »
Hi guys,
Regards,
Alessandro
My forecasts do change when the city does but won't load a default place on start. http://www.waterfordcityweather.com/yr/yrtest.php
    • Meteopistoia.it
« Reply #32 on: March 11, 2012, 05:08:03 PM »
Hi guys,
Regards,
Alessandro
Yes,
because i've set this code:
$URLS = "http://api.yr.no/weatherapi/locationforecast/1.8/?lat=43.8000&lon=11.0333"; // URL to the ENGLISH page on yr.no where location is
with my coordinates....the script goes directly on my place but if i choose other cities it shows the same forecast.
Your issue it's a known issue......i hope that Henkka fix it soon as possible!
Regards,
Alessandro
Offline jacg
    • Het weer in ruinen
« Reply #33 on: March 12, 2012, 12:32:08 PM »
Solution:
Change the lines between 85 - 130 by these:
// CONFIG END
$q = $_SERVER["QUERY_STRING"];
if ($q != "") {;
$q = explode("|",$q);
$lat = $q[1];
$lon = $q[2];
$tz = $q[3];
$cit = $q[4];
$cou = $q[5];
$cod = $q[6];
//$g = utf8_decode(urldecode($g));
//$gs = explode('/',$g);
//$g = str_replace("/","",strstr($g, '/'));
$mc = parse_url($_SERVER['HTTP_REFERER']);
$MH = $mc['host'];
if(isset($_COOKIE["yrfav-fi"]) && !is_numeric($lat)){
$q = explode("|",$_COOKIE["yrfav-fi"]);
$lat = $q[0];
$lon = $q[1];
$cit = $q[2];
$cou = $q[3];
$cod = $q[4];
$frcid = $lat.'|'.$lon.'|'.$cit.'|'.$cou.'|'.$cod;
elseif(!is_numeric($lat)&&isset($_SERVER["HTTP_GEOIP_LATITUDE"])){
$cod = $_SERVER["HTTP_GEOIP_CITY_COUNTRY_CODE"];
$cou = $_SERVER["HTTP_GEOIP_CITY_COUNTRY_NAME"];
$cit = $_SERVER["HTTP_GEOIP_CITY"];
$lat = $_SERVER["HTTP_GEOIP_LATITUDE"];
$lon = $_SERVER["HTTP_GEOIP_LONGITUDE"];
elseif(is_numeric($lat)){$frcid = $lat.'|'.$lon.'|'.$cit.'|'.$cou.'|'.$cod;}
else{$frcid = $lat.'|'.$lon.'|'.$cit.'|'.$cou.'|'.$cod;}
$URLS = "http://api.yr.no/weatherapi/locationforecast/1.8/?lat=$lat&lon=$lon"; // URL to the ENGLISH page on yr.no where location is
// refresh cached copy of page if needed
// fetch/cache code by Tom at carterlake.org
And everything should work  ;)
Jacco
Offline katakomba
« Reply #34 on: March 12, 2012, 05:44:36 PM »
well nice script but i found significant differences between real altitude and api 1.8 model altitude
Offline mickopla
« Reply #35 on: March 12, 2012, 06:12:20 PM »
Solution:
// CONFIG END
if ($q != "") {;
$lat = $q[1];
$lon = $q[2];
$tz = $q[3];
$cit = $q[4];
$cou = $q[5];
$cod = $q[6];
$MH = $mc['host'];
$lat = $q[0];
$lon = $q[1];
$cit = $q[2];
$cou = $q[3];
$cod = $q[4];
Jacco
Well done Sir. Followed your instructions and now the script is working perfectly  =D>
Now to include it on my website within menus and alike.
« Reply #36 on: March 14, 2012, 12:48:01 AM »
Mine is working okay, except I can't adjust units of measurement to imperial, except for wind, which is able to be set to mph.  Also month and day are in reverse order from the way I have them set.
http://stillwaterweather.com/yrtest.php
Also the 2nd home page using modified AltDashboard 6.81 at http://stillwaterweather.com/wx/2ndhome.php
    • Meteopistoia.it
« Reply #37 on: March 15, 2012, 07:26:28 PM »
Solution:
// CONFIG END
if ($q != "") {;
$lat = $q[1];
$lon = $q[2];
$tz = $q[3];
$cit = $q[4];
$cou = $q[5];
$cod = $q[6];
$MH = $mc['host'];
$lat = $q[0];
$lon = $q[1];
$cit = $q[2];
$cou = $q[3];
$cod = $q[4];
Jacco
Very nice Jacco!
Thank you very much,
Alessandro
Offline mickopla
« Reply #38 on: March 16, 2012, 10:57:22 AM »
Solution:
// CONFIG END
if ($q != "") {;
$lat = $q[1];
$lon = $q[2];
$tz = $q[3];
$cit = $q[4];
$cou = $q[5];
$cod = $q[6];
$MH = $mc['host'];
$lat = $q[0];
$lon = $q[1];
$cit = $q[2];
$cou = $q[3];
$cod = $q[4];
Jacco
Very nice Jacco!
Alessandro
Hi Alessandro
I see you have the script included with your menus. What code are you using for your wxysforecast.php??? I want to have the script looking like yours.
Cheers
Mike
Offline mava
    • mavahome
« Reply #39 on: March 19, 2012, 02:45:49 PM »
I have the script working now.  :grin:
But I can't figure out how to display only 3 cameras instead of 4.
3 cameras would fit perfectly to the Saratoga template.
Any suggestions?
http://www.mavahome.com/wxyr2.php
Offline mickopla
« Reply #40 on: March 19, 2012, 06:54:07 PM »
Any suggestions?
Not an answer to your questions but i was wondering what code are you using for your wxyr2.php script? I want my page looking like yours within the saratoga template. Thanks in advance
Mike
Offline mava
    • mavahome
« Reply #41 on: March 20, 2012, 03:49:56 AM »
Copied this to a new page. Also changed the paths in yr_xmlII.php since wxyr2 is in root.
<div id="main-copy">
<script>
if(!!!document.createElement('canvas').getContext) {
document.write('<script src="http://cdn.nordicweather.net/excanvas.min.js"></scr' + 'ipt>');
</script>
<?php
include 'yr2/scripts/yr_xmlII.php';
echo $yrhead;
</head>
<body>
<div style="width:650px";>
<h3>&nbsp;&nbsp;yr.no V2</h3>
<br/>
<?php
echo $yrtable;
</div><!-- end main-copy -->
Offline mickopla
« Reply #42 on: March 20, 2012, 10:26:53 AM »
<script>
</script>
<?php
echo $yrhead;
</head>
<body>
<br/>
<?php
echo $yrtable;
I tried the code above which works to a certain extent but i have no table or conditions icons. You can view it here www.waterfordcityweather.com/wxnewpage.php
Any ideas on how to get the icons and table to work. They are working fine for me here www.waterfordcityweather.com/yr/yrtest.php
Mike
Offline Torjan
    • regnskvett
« Reply #43 on: March 20, 2012, 03:13:30 PM »
Any suggestions?
Hi!
Tray this in yr.css
.jcarousel-skin-ie7 .jcarousel-container-horizontal {width: 610px;height: 140px;padding: 20px 20px 20px 20px;}
.jcarousel-skin-ie7 .jcarousel-container-vertical {width: 610px;height: 245px;padding: 40px 20px;}
.jcarousel-skin-ie7 .jcarousel-clip-horizontal {width: 590px;height: 160px;}
Torjan
Offline mava
    • mavahome
« Reply #44 on: March 20, 2012, 06:12:37 PM »
Takker Torjan  :grin:
Offline jgillett
  • unnamed weather station, Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #45 on: March 20, 2012, 10:03:38 PM »
Still have the following problems, mentioned by others earlier but not answered that I have found...
1. Date and time formats are not following what I have set in config.
2. Graph shows mm, C, and hPa, rather than what I have set.
3. Table shows temp in C, pressure as 1016.2 inHg (!), and incorrect date and time formats.
http://tiggrweather.net/yr/yrtest.php
Thanks.
W7JKG
BUY FROM AMAZON  HERE... Thank You! :-)
Offline mickopla
« Reply #46 on: March 21, 2012, 11:17:41 AM »
<script>
</script>
<?php
echo $yrhead;
</head>
<body>
<br/>
<?php
echo $yrtable;
Mike
Any ideas on this guys. Want to get this working and put a link to it on my website
Cheers
Mike
Offline Lee10
« Reply #47 on: December 19, 2012, 06:41:10 PM »
Only recently found this thread so I do apologise for not starting a new topic.
I recently have had a go at the fantastic yr.no forecast script on my website but despite it working very nicely and smoothly I can't get the graph or webcams to show up and I'm having problems getting the drop-down menus to work.
I have altered the settings in yr.nowxII.php file and changed the default location, but do I need another line or coding or alter parts of the file to achieve the results above. I have also changed the chmod settings for cache and directory folders as per installation instructions.
The website is http://www.theweatheronline.net/yr/yrtest.php
Any help would be greatly appreciated
« Last Edit: December 19, 2012, 06:43:11 PM by Lee10 »
« Reply #48 on: December 19, 2012, 08:59:06 PM »
Sorry, but I don't know how to help you, but my yr page can bring up the Portsmouth forecast, if you want to see it.  It has the graph as well as a bunch of webcams.  http://stillwaterweather.com/yrtest.php?|50.79899141148548|-1.0912513732910156|Europe/London|Portsmouth|United%20Kingdom|GB Maybe you need to reinstall the script while carefully following instructions.
 I still wish the options for imperial measurements would work for me.   Maybe the author of the script has lost interest in supporting it.
« Last Edit: December 19, 2012, 09:04:30 PM by Bunty »
Offline Lee10
« Reply #49 on: December 20, 2012, 07:35:46 AM »
Thanks for your reply
It seems to work fine well the temperatue, images etc is fine if not working very smoothly but just can't get the menu to drop down when you type in the search box for a different location, was wondering if this is because of a mssing script or can you alter in yp.wII file.
