May 25, 2013, 08:53:59 AM *
Members: 6623  •  Posts: 178864  •  Topics: 18148
Please welcome Porchpup, our newest member.
Author Topic: Davis serial data-link to wireless solution  (Read 1793 times)
AL Estep
« on: October 11, 2011, 09:45:28 AM »
Gents,
 I have a Davis serial data-link for my Vantage PRO2. the connection is fifty ft long and well withing specs for a serial connection. But I really would like to go wireless with this connection and then be able to not have a cable running thru the trim around the cellar door to get the data to the WX computer.
Does anyone have a solution that would connect to the the Davis serial data logger(RJ) and then go wireless to the Davis computer connector (blue RJ to nine pin)?
Al Estep
Davis Vantage PRO2 wireless
Firefox browser 20.0.1
VWS  version 14.01.P45
Elevation 7483 ft
d_l
Slide Mtn - Mt Rose
« Reply #1 on: October 11, 2011, 10:12:43 AM »
Most of the potential solutions aren't going to be cheap.  Maybe something like this would work: IOGEAR's Serial Adapter with Bluetooth?  All I know about it is what I've read on their web pages.
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*2-Meteohub, WL 6.0.0, WU & W4U=KNVRENO37 NetcamXL
People always talk about the weather, but they never do anything about it.  Not me.  I'm gonna measure it.  www.tceweather.com
dalecoy
« Reply #2 on: October 11, 2011, 10:47:06 AM »
Gents,
Thanks for moving this to a new topic.  I did a search and didn't find anything that I would call a "good, cheap" wireless solution - but perhaps I missed something and someone will point us to it.
Perhaps if you describe your physical situation a bit more, we could suggest alternatives.  For instance - should we assume that the console is in the cellar and the computer is not?  Or the reverse?  What else is in the cellar?  Phone wires?  Do you have a wired or wireless network in the house?
Bushman
« Reply #3 on: October 11, 2011, 11:11:23 AM »
http://www.fjord-technology.com/datenlogger_xbp.html  (Need to translate from German)
xykotik
DonkeyTailWX DW6891
I'll deal with it tomorrow
« Reply #4 on: October 11, 2011, 11:22:45 AM »
German - to - English
Facit solem suum oriri super bonos et malos et pluit super iustos et iniustos.
Springtime in Seattle...  March comes in like a lion and out like a wet lion.
dalecoy
« Reply #5 on: October 11, 2011, 12:31:19 PM »
Need to translate the price from Euros - would be something like $325 + shipping.
Need to check, but I'm guessing that the frequencies used would not be legal in the US.
dalecoy
« Reply #6 on: October 11, 2011, 12:38:07 PM »
Assuming this is a wireless VP2, anything more expensive than the Davis 6316 http://www.davisnet.com/weather/products/weather_product.asp?pnum=06316 would be unreasonable.
$195 list, available cheaper at various other stores.
johnd
« Reply #7 on: October 11, 2011, 01:05:25 PM »
You maybe need to specify what sort of wireless you want. I'd have thought that some sort of WiFi Device Server, eg
http://www.lemosint.com/device_servers/device_servers_details.php?itemID=585
might be the cheapest option (and assuming that you might have WiFi available already). It's not a serial to serial link (at least not in a hardware sense) but does the same job. Just don't forget that you'll probably need a modem adapter on the device server input to cross over the Rx/Tx lines.
Of course there are plenty of more costly options like a pair of MaxStream wireless modems
Bushman
« Reply #8 on: October 11, 2011, 01:09:53 PM »
It uses run of the mill 2.5 ghz.  Fine everywhere.
dalecoy
« Reply #9 on: October 11, 2011, 03:02:22 PM »
Ah.  Same band as microwave ovens, etc.
Bushman
« Reply #10 on: October 11, 2011, 04:25:37 PM »
2.5?  I meant 2.4  My bad.  And yeah, same as lots of wifi routers etc.
AL Estep
« Reply #11 on: October 11, 2011, 07:32:58 PM »
ok, more data the console is in the living room  hanging on a wall.
The weather computer is in the cellar in my work from home office.
I want to use a wireless RF connection other than Bluetooth since the distance exceeds what Bluetooth is capable of doing.
in the serial discussion they talked about a little wireless adapter that connected to the serial connector of the VP2 console. I was wondering if that could be adapted to what I wanted to accomplish. That wireless adapter and serial connection is in two parts one for a serial port the other to transmit & receive the data.
Al Estep
Elevation 7483 ft
dalecoy
« Reply #12 on: October 11, 2011, 07:52:24 PM »
AL Estep
« Reply #13 on: October 12, 2011, 09:19:49 AM »
hard wired network, and phone lines
Al Estep
Elevation 7483 ft
dalecoy
« Reply #14 on: October 12, 2011, 10:02:00 AM »
So, would it be:
1.  If there are unused wires in your phone lines (i.e., standard wiring and only one incoming phone number), you could use the unused wires to connect the serial logger to the computer.
2.  If the hard wired network is accessible from the console, there are two possibilities:
A.  There are always unused wires in the network cable, that can be used (without interference) to connect the console to the computer.
B.  You could get a WeatherLinkIP logger.
And, to answer "in the serial discussion they talked about a little wireless adapter that connected to the serial connector of the VP2 console. I was wondering if that could be adapted to what I wanted to accomplish" ... yes, I believe that it could.  Note that it's not a "finished work, buy it and plug it in" appliance, but if you have technical experience, you could try it.  It's also not a logger, so requires a reliable 24/7 computer.
johnd
« Reply #15 on: October 12, 2011, 10:09:26 AM »
And a third would be to connect a cabled device server (serial-to-ethernet adapter) to the network. Not very expensive and work well.
d_l
Slide Mtn - Mt Rose
« Reply #16 on: October 12, 2011, 11:25:10 AM »
The distance exceeds 330 feet??!!!!  The Bluetooth devices I linked to have that distance limit.
--Dave--
Bushman
« Reply #17 on: October 12, 2011, 11:45:44 AM »
Depends on the class.  Class 1 is supposed to be 100m at optimal conditions but most devices are Class 2 - 20 meters.
d_l
Slide Mtn - Mt Rose
« Reply #18 on: October 12, 2011, 12:19:13 PM »
.. and the device I linked to is Class 1! Sheesh!
--Dave--
AL Estep
« Reply #19 on: October 12, 2011, 11:44:51 PM »
Sorry to make this complicated, due to construction of my house a Bluetooth device will not work between floors, I'm lucky to get 30 FT with a Bluetooth device.
Al Estep
Elevation 7483 ft
dalecoy
« Reply #20 on: October 13, 2011, 09:58:17 AM »
So, which of the dozen-or-so alternatives that folks have suggested, seems most attractive to you?
d_l
Slide Mtn - Mt Rose
« Reply #21 on: October 13, 2011, 10:36:36 AM »
If you are certain a Class 1 Bluetooth device can't transmit the distance needed, then Dale's suggestion of an Envoy at your computer is likely the next cheapest method and almost certainly the most reliable choice available. An Envoy can be bought for under $130.
--Dave--
SLOweather
Administrator
« Reply #22 on: October 13, 2011, 10:48:43 AM »
I agree. While I'm among the first to want to throw technology at a problem like this, with serial-ethernet adapters and WiFi clients and such, the Envoy is, to me, the best solution for you.
Page created in 0.122 seconds with 18 queries.
