I was experiencing bizarre counter behavior on my Hobby-Boards lightning detector. When I started posting my station data to PWS Weather, I could see that my rain gauge was also showing huge counts in the precipitation chart.
The tip-off was the frequent lightning detector counts of 4294967295 which corresponds to xFFFFFFFF. This is the blank page in the DS2423 counter used in the rain gauge and lightning detector. I also found from various application information on One-Wire that negative voltage transients on the One-Wire bus can cause disruption to the chips via the substrate.
The DS2423 data sheet says:
When applying the Read Memory + Counter command to a page that does
not have a counter associated, the master will read FFFFFFFFH instead of a valid count.There were several recommendations in the application notes, including using a hub (already was doing that) and various ramp rates. The one that caught my eye was the recommendation to add a Schottky diode to the most distant node of the One-Wire bus. This clamps the negative transient to -0.3V.
I placed the diode at my hub just to test it because if it was the wrong polarity it would short out the bus. Immediately, I started seeing massive continuous errors on the lightning detector. Since the diode was at the opposite end of where it is supposed to be, I wasn't surprised that this could make it worse.
I installed the Schottky diode a few days ago and it seems to have cured the problem. I went through a major lightning storm last night without any false counts. Time will tell, but so far so good.
I read about this in "Springbok Diagnostics 1-Wire Design Guide v1.0" (pg. 36) and the "OneWire Design App Note" from Dallas Semiconductor (Maxim).
The Springbok paper is at
www.1wire.org/Files/Articles/1-Wire-Design%20Guide%20v1.0.pdfIt is critical that the diode be placed at the far end of the One-Wire microLAN and that the cathode (banded end of a leaded device) is on the "data" line not the ground. Otherwise you will have a shorted bus. (it doesn't hurt anything permanently, it just won't work).
Springbok recommends a 1N5817 or BAT54S. A standard rectifier diode will be slower and allow 0.6V reverse voltage, so they are not suitable.
Greg
Update: I did get a count indicating a read error late this morning. It still seems much better behaved now.
Hmmm... I see in the schematic for the lightning detector that there is already a BAT54S Schottky diode. Not sure if this means that it was open circuit, or something else is going on now.
OK, the xFFFFFFFF count happened only twice since I put the Schottky diode at the end of the net (about a week). I now think that the first one was a power transient. The other one was at start-up OWW after a power-off (power failure). Otherwise, both the xFFFFFFFF and the crazy count issue seems to be gone.
The explanation I believe lies in the datasheet for the BAT54S and the 1N5819 that I used.
The 1N5819 is 400mV @100mA.
The BAT54S is 800mV @100mA.
Hence, the BAT54S, while being a Schottky diode, isn't as effective as a clamp as the 1N5819. The BAT54S could allow enough negative voltage below -0.3V that the substrate issue could occur, whereas the 1N5819 has a better chance of clamping it. It all depends on the current that the diode is absorbing during the negative transient.
