Author Topic: About data transfer  (Read 3222 times)
Offline hswaters
  • hswaters
About data transfer
« on: July 13, 2011, 08:36:03 PM »
I have started a trial use of Cumulus.  I see in the internet setup part that it has two sections already set up for APRS/CWOP, Wunderground and PWS.  Does this mean that if I want to send data to any other system I have to work out the format of what to send?
Offline neondesert
    • http://www.neondesertweather.com
Re: About data transfer
« Reply #1 on: July 14, 2011, 07:12:55 PM »
Correct.  The software is setup, as you have already noted, to send data to those third parties.
Where are you trying to upload to?
Larry
"But it's a DRY Heat!"
Offline hswaters
  • hswaters
« Reply #2 on: July 14, 2011, 09:36:29 PM »
I was just trying to be sure I was doing things right.
Offline mikesin
    • Valencia, Pa
« Reply #3 on: July 16, 2011, 09:25:36 PM »
I read your post on sandsoft's forum, did you sent Steve then info? Im interested in the response....
Offline hswaters
  • hswaters
« Reply #4 on: July 16, 2011, 09:33:29 PM »
If you are talking about the rain not being displayed on the cumulus program the problem was apparently caused by the Davis DLL not running from 20:00 until later the next day.   It seems like I had installed a different web cam at the time the DLL stopped.  I guess the install did it.  If I had restarted windows it would not have happened.  I installed a web cam that has a resolution of 800x600 pixels.  Quite an improvement over the old logitech ball cam I was using.
Offline hswaters
  • hswaters
« Reply #5 on: July 16, 2011, 09:35:27 PM »
Possibly you are referring to the FTP errors I was getting.  I did not read enough of the post.  I was sending redundant data.  The most popular forums are already, all you have to do is click the box and cumulus takes care of all data transfer.
Offline mikesin
    • Valencia, Pa
« Reply #6 on: July 17, 2011, 09:37:19 PM »
 I was referring to the DLL issue you had - and i posted to the wrong thread :(((  Thanks for the update..
