Author Topic: What's You Hottest Temperature this Year?  (Read 47267 times)
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
Re: What's You Hottest Temperature this Year?
« Reply #125 on: July 29, 2011, 04:55:37 PM »
Since I have been here, we have had a high temp of 96, dew points in the low to mid 70s, and the highest heat index being 109 here. To the west they reached 110!
Although it is hot here still (Last advisory read 92), a cold front that swept through the area a couple of days ago dropped dew points back to the upper 60s, making heat indeces around 100.
Joe Fitzwater
Chief Meteorologist for WVNS-TV 59 in Beckley, WV
Work Page on Facebook -> www.facebook.com/meteojoe
Work Page on Twitter -> https://twitter.com/meteojoe
Waterfalls -> www.wvfalls.com
Offline Aardvark
    • turned off
« Reply #126 on: July 29, 2011, 05:50:44 PM »
99.5 , hot enough for me,  but we sure could use the rain.  peaches are small and hard,  used to be bigger by now.  maybe I need to go waste water on them.
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #127 on: July 29, 2011, 06:23:25 PM »
As of yesterday, this would tie for the 8th hottest summer on record for Charleston, WV, and we're still 10 degrees above average today.
Joe Fitzwater
« Reply #128 on: July 29, 2011, 09:35:49 PM »
High temp   101
on a different day- High dew point  85   My THSW that day was 130.
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #129 on: July 29, 2011, 10:03:46 PM »
102.0°F
22-Jul-2011
Ed
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Davis Vantage Pro2+ with full FARS
« Reply #130 on: July 30, 2011, 06:20:46 AM »
The Highest Temp for Phoenix was 122F on Jun 26 1990.  I however didn't move here until the following July.  So I "Missed" it.  We did have a 121F in July 1995.
This year, we had 119F with around 7% humidity (what they call a Dry Heat) near the end of June.  Need to look it up.
We have had an unusually dry "Monsoon" this year.  Can't think of many days were it was really moist hot which would be typical during Most of July though the End of August.  As a result, it has been a fairly comfortable hot this summer, unlike what the mid-weat and now the east have been getting.
All you need is Time, Aptitude and Desire ... and you can build just about anything...
Offline meteolarissa
  • Personal weather station in North Greece
    • Current Weather in Larissa , Greece
« Reply #131 on: July 30, 2011, 06:54:56 AM »
106 TO 107F or 40.9 to 41.6 celsius in my city Larissa in north Greece... \:D/ \:D/ \:D/ \:D/
MeteoLarissa PWS,Thessalia,Greece.VP2 6153 with Heater and Solar Sensor.Camera Creative Live+ Logitech pro9000+ +Weatherlink+WD10.37+VWS+VP+Wxsolution++++ etc
Offline Cienega32
    • East Mesa Weather
« Reply #132 on: July 30, 2011, 02:12:21 PM »
You're going by the airport numbers prior to your move tho', correct? How do your own overall summer numbers line up with theirs?
I remember my last summer in Vegas (2005) as being a record setter and every station on my side of town was consistently 5+ degrees higher than LAS.
Pat ~ Davis VP2 6153-Weatherlink-Weather Display-StartWatch-VirtualVP-Win7 Pro-64bit
Offline neondesert
    • http://www.neondesertweather.com
« Reply #133 on: July 30, 2011, 04:09:32 PM »
That was a HOT one for sure!
NeonDesertWeather
July 2005 13th-19th Daily High Temperatures
13  115.9°F
14  116.2°F
15  114.2°F
16  117.4°F
17  118.3°F
18  117.1°F
19  115.9°F
FWIW, my temps are never the same as McCarran's.
Since I'm at a lower elevation my maximum temps are usually a few degrees higher
while overnight minimums are a few degrees lower.
Larry
"But it's a DRY Heat!"
Offline TNETWeather
« Reply #134 on: July 30, 2011, 04:55:46 PM »
The date was July 2nd, not June like I thought.
PHX Reported:
Mean Temperature      101 °F avg  94 °F
Max Temperature         118 °F avg 106 °F Record 118 °F (2011)
Min Temperature         84 °F  avg    80 °F Record  65 °F (1911)
119F was recorded at my station:
July 2nd:
Average temperature     98.7°F
Average humidity        24%
Average dewpoint        53.9°F
Maximum temperature     119.1°F on day 02 at time 14:51
Minimum temperature     76.6°F on day 02 at time 05:53
Maximum humidity        37% on day 02 at time 00:38
Minimum humidity        15% on day 02 at time 16:43
Maximum dewpoint        63.4°F on day 02 at time 12:43
Minimum dewpoint        40.5°F on day 02 at time 3:11
Maximum pressure        29.644 in. on day 02 at time 08:00
Minimum pressure        29.513 in. on day 02 at time 19:43
Maximum windspeed       21.9 mph on day 02 at time 23:57
Maximum gust speed      29.9 mph from 158 °(SSE) on day 02 at time 23:57
Maximum heat index      123.3°F on day 02 at time 14:48
Average barometer       29.6 in.
Average windspeed       2.9 mph
Average gustspeed       5.3 mph
Average direction       51° ( NE)
Offline Old Tele man
  • Singing in the rain...
« Reply #135 on: July 30, 2011, 05:07:19 PM »
...before they moved the weather station at the airport, Yuma, AZ, *used* to battle with Thermal, CA, for the dubious title of "HOTTER-than-HELL" capital of USA.
...Tucson's record high is 117ºF on 26-June-1990. And, I recall the airlines having to abort to Tucson for landings when Phoenix airport temp was 122ºF because their electronics weren't "certified" for operation above 120ºF!
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #136 on: July 30, 2011, 06:53:10 PM »
Incredible.  Tulsa's record high ever was on Aug 10 1936 at 115ºF
Sofar my station has reported a high of 108.9ºF twice this year.
And Tulsa is on par for its hottest summer ever recorded.  Our current mean for this summer sofar is around 88.5.  Summer of 80 was 87.1.  We'll likely break it, as the weather heads are saying no relief in sight likely for at least three weeks.
Here's my July as of yesterday...
« Last Edit: July 30, 2011, 07:00:28 PM by BigOkie »
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #137 on: July 30, 2011, 07:24:44 PM »
Tied it again yesterday at 96!
Joe Fitzwater
Offline KeithBC
« Reply #138 on: July 30, 2011, 08:53:52 PM »
@#$% ](*,)  Here it is the end of July / beginning of August, traditionally the hottest week of the year, and our high for the year is still only 25.2C.  If anyone has some heat to spare, I'll take it off your hands.
Offline Cienega32
    • East Mesa Weather
« Reply #139 on: July 30, 2011, 11:59:26 PM »
NeonDesertWeather
13  115.9°F
14  116.2°F
15  114.2°F
16  117.4°F
17  118.3°F
18  117.1°F
19  115.9°F
I remember the weathernets around town on the news that week - all the ones by me in the Ft Apache/Twain area were running 120s. Every one of them. It was brutal for sure. Even with the chilled air being aimed at my bed, I still had a floor fan running. I had already decided to move from Vegas prior to that but that pretty much cinched it entirely.
Now I'm nice and cool with only a 108 as a record high (station).
Offline neondesert
« Reply #140 on: July 31, 2011, 12:13:39 AM »
108!  We do that here in our sleep...literally!
I'll send you a sweater so you don't catch cold!  :lol:
Larry
Offline Cienega32
    • East Mesa Weather
« Reply #141 on: July 31, 2011, 02:57:56 PM »
As long as it comes with some of those negative Dew Points...
Offline Aardvark
    • turned off
« Reply #142 on: July 31, 2011, 03:15:41 PM »
hot all week. Better than ice, snow and low wind chills.
The soil moisture reading in my garden was 42 at the 4 inch level and 41 at the 12 inch level...  I figured since there was no rain in the forecast, time to water the garden.
Peaches on the trees are small for this time of the year,  that rain in June didn't seem to help them in July.
Anyway...it is hot, humid and just nasty that way, but I'd rather have this than the cold
Offline tomcj2
    • CanbyWeather
« Reply #143 on: July 31, 2011, 04:39:04 PM »
I disagree.  When it is cold you can always put another sweater on.  When it is hot you cannot do anything.
By the way,  we reached 89.7°F  on July 6.  Great "No Summer"  so far.
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
    • Watts Bar Weather
« Reply #144 on: July 31, 2011, 06:53:42 PM »
On the one hand, an average person can survive hot weather relatively easy.  On the other hand, no one is immune to freezing to death.
Offline AWL
    • Ardmore Weather Live
« Reply #145 on: August 02, 2011, 09:46:09 PM »
What a heat wave we are in the middle of.....37 now in a row above 100°. Set a new all time high record for my station today of 112.6°.
« Last Edit: March 19, 2015, 05:29:01 AM by DougW »
Offline wxtech
    • Lexington, Ga. Weather
« Reply #146 on: August 02, 2011, 11:52:13 PM »
Today was the hotest in 2011.  NWS predicted 99ºF and we reached 102.7ºF in Downtown Lexington, Ga.
They're predicting 102 for tomorrow.
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #147 on: August 03, 2011, 12:13:00 AM »
Boy that new Acurite is getting a good thorough check out (on the high side anyway).
Offline wxtech
« Reply #148 on: August 03, 2011, 12:17:24 AM »
I have some other data that's not posted on the comparison and it's amazing how close all the numbers are.  If this were a blind test, no one would be able to decide which is the $100 unit & which is the $1000 unit.
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #149 on: August 03, 2011, 02:33:50 AM »
I'm sure NE Oklahoma can beat that tomorrow.  We're possibly going to break the city alltime record of 115.  Today's official high at the airport was 112.  They're calling for 114, but that all depends on the timing of the front that's moving this way.  If we get the compressional heating that happens in advance, I'm guessing we'll get 116 or 117.  If not, it will likely be closer to 114.  My station registered 113.9 degrees today.  For another alltime station record.
Here are yesterdays temperature history readings:
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KOKTULSA13&day=2&year=2011&month=8
Weather radios:
Reecom R-1650
Sangean CL-100
