May 25, 2013, 11:05:47 AM *
Members: 6623  •  Posts: 178875  •  Topics: 18148
Pages: 1 ... 9 10 [11] 12   Go Down
Author Topic: Weather Underground NWS Streaming Project  (Read 68045 times)
hayskswx
« Reply #250 on: March 20, 2012, 12:11:44 AM »
Im just going to do it on a desktop pc instead. when i plug the cable in i can barely hear it. Im using a midland 300 radio and got the audio cable plugged in the outlet that says pc and then into the computer. I have a wu id so i guess i have a handle
Ryan
www.hayskansasweather.com
hayskswx
« Reply #251 on: March 20, 2012, 01:08:24 AM »
Going to do it on a desktop pc instead. Got the cable and a midland 300 radio but can barely hear radio . Cant figure it out
Ryan
hayskswx
« Reply #252 on: March 20, 2012, 02:02:06 AM »
cant download edcast anymore its not available?
Ryan
kray1000
Purveyor of wry
« Reply #253 on: March 20, 2012, 08:19:53 PM »
I posted a link to it in another thread.
Found it.  Try this link:
Alternate link to download Edcast.
« Last Edit: March 20, 2012, 08:23:04 PM by kray1000 » Logged
Kevin Ray
Roanoke, VA
Wireless VP2, Stardot NetCam, ImageSalsa 2.0.12, MovieSalsa, Nexstorm, WASP2, Skymet, VWS14.01p33, WD 10.37N build 03
kray1000
Purveyor of wry
« Reply #254 on: March 20, 2012, 08:27:29 PM »
You'll probably need to increase the volume of the radio.  The volume control will increase the audio through the cable just as it would for the speakers.
Kevin Ray
Roanoke, VA
hayskswx
« Reply #255 on: March 20, 2012, 10:39:13 PM »
Do I have to have the radio on loud all the time?  Explain please
Ryan
hayskswx
« Reply #256 on: March 20, 2012, 10:41:09 PM »
Turned up volume on radio but can barely hear it. The line in audio is NOT muted
Ryan
kray1000
Purveyor of wry
« Reply #257 on: March 21, 2012, 12:15:23 AM »
And you definitely have the audio cable plugged into the "Line In" jack and not one of the others?
Kevin Ray
Roanoke, VA
hayskswx
« Reply #258 on: March 21, 2012, 02:12:18 PM »
yes i do. what end do you plug the mono to stero adapter?
Ryan
hayskswx
« Reply #259 on: March 21, 2012, 02:17:28 PM »
When i go to download this i get a little ways and it says this next Malicious Web Site Blocked
Ryan
kray1000
Purveyor of wry
« Reply #260 on: March 21, 2012, 05:43:30 PM »
Wrong quote.  I assume you're talking about downloading Edcast.  I didn't have any issues when I downloaded it.
You can try ScannerCast instead of Edcast.
Kevin Ray
Roanoke, VA
kray1000
Purveyor of wry
« Reply #261 on: March 21, 2012, 05:45:40 PM »
You don't need any mono/stereo adapters.  If what you have is a mono cable, just use that.
Kevin Ray
Roanoke, VA
hayskswx
« Reply #262 on: March 21, 2012, 09:19:55 PM »
Ok. I've been using a stereo cable. I'll try the mono. Do u have to have the radio playing all the time or can u just leave it on the radio and turn down volume on radio?
Ryan
kray1000
Purveyor of wry
« Reply #263 on: March 22, 2012, 05:07:08 AM »
Not what I was saying.  I was under the impression you didn't have a stereo cable.  Either cable will work fine, but the stereo will sound better if that's what you have.  So if you were using a stereo cable, why did you need a mono to stereo adapter?  In general you should avoid using adapters when you can because you'll lose voltage and pick up interference.
Once you have the hardware set up, the radio will be on all the time, but you won't hear it at all.
The radio volume (before you plug the dubbing cable into the radio) will be louder than a normal listening volume but not all the way up.  After you plug in the other end of the cable to the "Line In" jack on your computer, you should hear the radio output in your computer speakers (unless you have them muted) until you mute the "Line In" feed in your computer's audio settings.
Once you get it working to this point, you're ready to move on to the software portion, but we'll deal with that in another session.
Kevin Ray
Roanoke, VA
hayskswx
« Reply #264 on: March 22, 2012, 11:17:53 AM »
I have a 1/8 gold platter stereo cable with 2 male ends I got from radio shack. I have a midland wr300 radio. Which input do I plug it in. They have pc, headphone, and external antenna. I emailed midland and they told me the pc jack was just for them at the factory to program the radio. It's of no use to customers.
Ryan
hayskswx
« Reply #265 on: March 22, 2012, 11:21:31 AM »
On wu instructions it said to use a mono to stereo adapter.
Ryan
hayskswx
« Reply #266 on: March 22, 2012, 12:08:37 PM »
Got it working out the computer speakers. Clear as a whistle. Next step is software
Ryan
hayskswx
« Reply #267 on: March 22, 2012, 12:12:46 PM »
Dont know what  program to use to set it up?
Ryan
hayskswx
« Reply #268 on: March 22, 2012, 01:26:25 PM »
Got it connected to computer. Works perfectly. Downloaded edcast. Configured edcast and put information to match handle name on wu. But cannot connect edcast to wu?  Any suggestions?
Ryan
hayskswx
« Reply #269 on: March 22, 2012, 01:43:51 PM »
Im connected to edcast and see the green lines but I cant get a transfer rate?
Ryan
hayskswx
« Reply #270 on: March 22, 2012, 02:42:12 PM »
Im using windows 7. Maybe there is something I dont know? Is that the problem?
Any suggestions Please?
Ryan
kray1000
Purveyor of wry
« Reply #271 on: March 22, 2012, 06:37:05 PM »
Indeed it does.  Don't worry about the adapter, you don't need it... the software encoder will produce dual-channel output regardless of the input.
Will try to address your other questions later.  Review the instructions again on setting up the encoder (configuring edcast) and see if you missed anything.  Keep in mind that you won't yet see your stream listed on wunderground.com, there is an additional sign-up that is needed for that... but you should be shown on http://audiostream.wunderground.com/.
Kevin Ray
Roanoke, VA
hayskswx
« Reply #272 on: March 22, 2012, 07:05:32 PM »
I'm not showing up on the link u sent. The problem is that I cannot connect to socket in edcast.  It counts down from 10 saying connecting and when it get to 1 it says connected for 1 second then disconnects. Checked firewall and everything. Can't figure it out.
Ryan
kray1000
Purveyor of wry
« Reply #273 on: March 22, 2012, 09:27:26 PM »
Sounds like a password problem.  You do need your WU password (the password associated with your WU handle), even though it's not shown in the wunderwiki screenshots.
Kevin Ray
Roanoke, VA
hayskswx
« Reply #274 on: March 22, 2012, 09:32:30 PM »
I'll check on that tommorrow. On break at work now.
Ryan
Pages: 1 ... 9 10 [11] 12   Go Up
Page created in 0.107 seconds with 19 queries.
