May 24, 2013, 11:48:48 AM *
Members: 6620  •  Posts: 178772  •  Topics: 18139
Author Topic: best Outdoor Webcam in Budget?  (Read 7305 times)
LTCSZ
Senior Member
« on: May 27, 2011, 02:47:38 PM »
Hi: With a budget of under $200, can anyone recommend a good outdoor webcam that I could use for my weather site? Prefer wireless (I guess), but open to any suggestions...Thanks!
Steve
Steve
Retired Lieutenant Colonel, USA
Garden City, KS, USA
Budgie
Contributor
« Reply #1 on: May 27, 2011, 08:17:41 PM »
I've been looking recently as well.
I actually got an IP cam that had an IP66 protected case (the best protection) but the image was nasty.
I understand that the Panasonic BLC-140 is good but the case protection is only described at "splash-resistant", so I'm not sure it would do for me.
Wireless is a bit miss-leading when it comes to these as they have to have some sort of connection, be it power supply, data or both. Some have power over CAT5 which means the power & the data is sent via one CAT5 cable.
In the end I went for another normal webcam, well I've got two to choose from, a Logitech Pro 9000 or a Microsoft Liftcam Studio. I'll just make another waterproof box to put it in. These will give good quality images and are far cheaper than an outdoor cam.  Wink
« Last Edit: May 28, 2011, 06:39:06 AM by Budgie » Logged
LTCSZ
Senior Member
« Reply #2 on: May 27, 2011, 08:31:43 PM »
Yeah, I am sort of coming to that conclusion myself...I like the Lifecam also...I figure some sort of plastic box with a hole for the lens is all I would need for outside...It would be up under the eaves of my deck anyway, so it would probably be fine...Thanks for the info...
Steve
Steve
LTCSZ
Senior Member
« Reply #3 on: May 27, 2011, 08:43:39 PM »
By the way: What webcam software do you use/recommend? Thanks again,
Steve
Steve
LFWX
Liberty Township, Butler County, Ohio
« Reply #4 on: May 28, 2011, 01:06:31 AM »
I'm using a Logitech Webcam Pro 9000 and this enclosure http://cgi.ebay.com/New-Outdoor-Housing-w-Heater-fan-CCTV-camera-AC-24V-/260536654774?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D10%26pmod%3D220238109831%26ps%3D63%26clkid%3D238597793497991258
...and Image Salsa software.
I think this will fit your budget.
www.LFWeatherCenter.com
CWOP: DW1039
CoCoRaHS: OH-BT-1
Weather For You: DW1039
Midwestern Weather Network
Budgie
Contributor
« Reply #5 on: May 28, 2011, 06:36:30 AM »
Steve
At the moment I'm using a Lifecam Cinima in a DIY box that runs through Weather Display's Webcamcapture program. You can see the image + time lapse here: http://www.hebwx.co.uk/wxvideo.php
LFWX,
Thanks for the idea, I managed to find a few of those outdoor housings over here as well.
Better then the DIY housing I've currently got and a good price!!  Very Happy
« Last Edit: May 28, 2011, 06:40:09 AM by Budgie » Logged
stewart45
« Reply #6 on: June 06, 2011, 04:22:09 AM »
I,ve been using a BL-C140 for about 3 years now I'ts in a totally exposed position facing the Noth Sea and has taken all weather's without a hiccup, and thats without any protective case, can definatly recommend it, picture quality is not bad either http://www.weatherwatcher.co/wxcam.php
Dr Obbins
« Reply #7 on: June 06, 2011, 06:43:35 AM »
Another BL-C140 user here. It is facing northwest mounted under the eves of the roof.
http://www.cavecountryweather.com/webcam.php
Previously I used a Logitech Webcam Pro 9000 also. For some reason I couldn't get it to work on my new win7 computer though.
I would recommend either one.
CNYWeather
« Reply #8 on: June 06, 2011, 07:35:57 AM »
Same enclosure and camera here, except I'm using Weather Display Webcamcapture.
http://www.cnyweather.com/livecam.php
hdmax
« Reply #9 on: June 21, 2011, 03:18:41 PM »
Some of you have incredible web sites, I am starting to think I need a designer to set mine up, as I have no idea where to start.
 I purchased a domain from godaddy.com, then went with e-rice, I have a Davis Vantage Pro 2, Data logger serial, VWS for the software.
 I do not have my serial port addon card yet, should be here tomorrow.
 I am completely lost!
Ugly Duckling
__Darlin' Jill__
« Reply #10 on: June 21, 2011, 05:38:23 PM »
Need a little hand holding? When my Vue arrives in a couple days I'll be next to you. Maybe you've already had a chance to look at software. The only thing I've done so far is get advice regarding what weather station to buy.
You're ahead of me having domain and host. I'll do my best to catch up.  Rolling Eyes
Many Happy Weather Changes,
Marci Anna
        Davis Vantage Vue
SoMDWx
« Reply #11 on: June 21, 2011, 07:02:34 PM »
Tony,
 What are you using to create the streaming vieo? Very Nice!
Jim
Jim Wyman
Certificate In Weather Forecasting Graduate, Fall '11, PSU
Creator of Scit Pro
Southern Maryland Weather
http://somdweather.com
http://scit.somdweather.com
neondesert
« Reply #12 on: June 21, 2011, 07:11:00 PM »
Beautiful looking stream.  Cool
It doesn't seem to work in Firefox though (at least not in 5.0).  Sad
Larry
"But it's a DRY Heat!"
CNYWeather
« Reply #13 on: June 21, 2011, 09:04:38 PM »
Weather Display Webcamcapture software runs the stream Jim.
 I'll see whats up with the new Firefox too Sad
Cienega32
« Reply #14 on: June 21, 2011, 09:05:36 PM »
4.01 looks fine, FWIW.
Smooth stream!
DaculaWeather
SCCA EM #156
« Reply #15 on: June 22, 2011, 12:39:54 PM »
I still say the Sharx camera's are among the best (of course, I have one!). My next purchase will be one of their outdoor camera's.
3 different size streams at once
internal web server and DVR
motion detection
ftp transfers
wired or wireless IP camera
IR (good to 40 feet) or not
Steve
CNYWeather
« Reply #16 on: June 22, 2011, 12:48:52 PM »
^^^  Yep, what Steve said  Very Happy
Page created in 0.22 seconds with 19 queries.
