May 26, 2013, 03:50:26 AM *
Members: 6623  •  Posts: 178941  •  Topics: 18156
Please welcome Porchpup, our newest member.
Author Topic: Carterlake & Meteohub Data  (Read 4758 times)
Coachless
« on: May 26, 2011, 09:26:51 PM »
I was wondering what others are doing or some suggestions. I've just started using the meteohub and WD Live. But I like the scripts from Carterlake to fillout the rest of my website; but the plug-in wants data from Weather Display. Is there a way to take the sensor data from Meteohub and get it into one of the plugins? I was trying to avoid running a PC 24/7, and switched to this device. Any suggestions. Thanks.
d_l
Slide Mtn - Mt Rose
« Reply #1 on: May 26, 2011, 09:44:52 PM »
Does the plug-in use data from clientraw files which the meteohub should be outputting for WDL?
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*2-Meteohub, WL 6.0.0, WU & W4U=KNVRENO37 NetcamXL
People always talk about the weather, but they never do anything about it.  Not me.  I'm gonna measure it.  www.tceweather.com
Coachless
« Reply #2 on: May 26, 2011, 09:50:10 PM »
no, it appears it's looking for a file called testtags.php, which WD creates and pushes to the website. The only choice I have with data is a text file or an xml file.; which when I use those through the script, it tells me there is not data.
saratogaWX
Administrator
Saratoga, CA, USA Weather - free PHP scripts
« Reply #3 on: May 27, 2011, 12:39:54 AM »
The meteohub station would need it's own plugin to make it work correctly since meteohub creates only the realtime WD files used with Weather-Display Live.  I'll have to investigate the Meteohub docs to see what tags are available for use, and then see what's possible in a plugin.
Best regards,
Ken
Davis Vantage Pro Plus - FARS, Boltek-PCI/NexStorm, GRLevel3, WD, WL, VWS, Cumulus, Meteohub
pablo_660
« Reply #4 on: June 20, 2011, 11:04:10 PM »
Hello,
I use the template with meteohub. I adapted the file testtags.php for the update of the ajax-dashboard.
Also you will have to make some change in the file ajax-dashboard.php
With the Metohub you must upload to your server the file testtags.html as testtags.php.
CNYWeather
« Reply #5 on: June 21, 2011, 07:31:16 AM »
I was checking those out and came across the WeatherPlug on Rainmanweather
http://www.rainmanweather.com/site/products/WeatherPlug-IP
Seems like he's got it squared away on how to update the Carter Lake dashboard
http://www.rainmanweather.com/wxplug/
Tony
saratogaWX
Administrator
« Reply #6 on: June 21, 2011, 05:28:06 PM »
I've got a new Meteohub setup on a Sheeva Plug (WeatherPlug from rainmainweather.com) and am working on creating a MH-plugin for the template set.  Should have a test version out early next week Smile
We (wife and I) just got back from the Chicago area where we were helping our daughter/husband move into their new home.  Still a bit 2-hr-jet-lagged.
n.b. The MH-plugin won't use the WD-style testtags.php for inputs, it will use the MHtags.php/MH-defs.php to tie the Meteohub variables to WD-variable names used in the gizmo/dashboard, just like the plugins for VWS, WeatherLink, and Cumulus.  That way, the Meteohub native variables will be available in the $WX[] array for use in your own pages if desired.
The MH-plugin will use a version of the AJAX script for Weather-Display as Meteohub does create the clientraw*.txt family of files Smile
Ugly Duckling
__Darlin' Jill__
« Reply #7 on: June 21, 2011, 05:45:41 PM »
Wonder how long it will take before I understand what is being said here. Have no idea what you said. Guess newbies such as I shouldn't be reading such things. For adults only!
Many Happy Weather Changes,
Marci Anna
        Davis Vantage Vue
saratogaWX
Administrator
« Reply #8 on: June 21, 2011, 06:02:25 PM »
Hi Marci Anna, and welcome to wxforum.net Smile
I'd developed a website template set using PHP (a website programming language) and a JavaScript that adds near-realtime updates to some of the weather conditions displayed on the pages.  The initial template set worked only with Weather-Display software, but the Version 3 template sets now work with 4 different weather software programs: Weather-Display, VWS, WeatherLink and Cumulus.  The support for each unique software package is contained in what I call a 'plugin' (a .zip file that contains files to use on the website to support that weather software package).
Website programming is quite a popular item for weather enthusiasts to be able to easily present the weather conditions from their weather station and weather station software.  Hopefully, you'll find it as enjoyable (and somewhat addictive) as you get your station in operation.  See the templates at http://saratoga-weather.org/wxtemplates/index.php
Best regards,
Ken
Ugly Duckling
__Darlin' Jill__
« Reply #9 on: June 21, 2011, 08:19:09 PM »
Best regards,
Ken
Thank you so much for explaining but someone told me you are a really great guy. I see that goes without saying.
I'll understand what you said more once I begin using it myself. I can't wait to get started.
I enjoy your website!
Marci Anna
        Davis Vantage Vue
CNYWeather
« Reply #10 on: June 21, 2011, 10:14:22 PM »
Cool. I saw one of those on that site and it peaked my interest. I'd be interested in your review of it Ken.
pablo_660
« Reply #11 on: June 24, 2011, 12:33:36 AM »
Good news, I will be enthusiasts to test the new plugin on my site  Smile
Thank you !
GeirO
GeirO
« Reply #12 on: August 01, 2011, 02:08:15 PM »
as of today I have started using Meteohub, so I wonder, have you made a plugin for Meteohub? I am about to implement the templates now Smile
Thanks, and regards from the Norwegian Mountains
Geir
www.gunnarnu.com/var/index2.html
(new page under construction, this is the old WDL based one)
saratogaWX
Administrator
« Reply #13 on: August 01, 2011, 02:18:41 PM »
Funny you should ask Smile
I've been working on a Meteohub plugin for the templates (see the work-in-progress here).  I'd received some wonderful work from Rob of www.rainmanweather.com on getting this started.  I've also asked Boris if a new tag set can be added (for authoritative 'yesterday' data).
Still in development .. hope to release in a week or so.
Thanks for your interest...
Best regards,
Ken
GeirO
GeirO
« Reply #14 on: August 01, 2011, 05:13:30 PM »
that is nice to hear! I am building my new side based on your templates now and will get my new Davis Vantage Pro2 weather station next week and then start to get live data into Meteohub. Your plugin seams to arrive in perfect time for me then, thanks.
saratogaWX
Administrator
« Reply #15 on: August 01, 2011, 05:23:51 PM »
I'll let you know when a plugin is ready for testing on your site Smile
GeirO
GeirO
« Reply #16 on: August 03, 2011, 08:20:40 AM »
thanks, IŽll be waiting Smile
saratogaWX
Administrator
« Reply #17 on: August 09, 2011, 05:03:02 PM »
The wait is over Smile
I've just released the Meteohub plugin for use.
The install page has the download, and there are two new setup/config pages for Meteohub.
Please let me know how it works for you!
Best regards,
Ken
GeirO
GeirO
« Reply #18 on: August 09, 2011, 05:51:16 PM »
looking forward to try it out! Unfortunately not until thursday Sad
pablo_660
« Reply #19 on: August 11, 2011, 11:04:34 AM »
Best regards,
Ken
Great, I'll update my site with the new plugin in the next days
Thank you for your job  Very Happy
GeirO
GeirO
« Reply #20 on: August 12, 2011, 08:16:48 AM »
I seam to have trouble uploading the graphics, size 0 kb is usually not good... ? any ideas? Clientraw files are ok
saratogaWX
Administrator
« Reply #21 on: August 12, 2011, 12:56:41 PM »
What is the URL for the new website?  Did you generate the graph template, install it in /graphs in Meteohub, then use Manage Graphs to edit the units used?
GeirO
GeirO
« Reply #22 on: August 12, 2011, 02:37:38 PM »
my new pages are here http://www.gunnarbu.com/varet/index.php
I did generate the graph template, I think, but I might likely have done something wrong. I uploaded the template files to /graphs in Meteohub and I edited the units, but obviously I have missed something Sad
GeirO
GeirO
« Reply #23 on: August 13, 2011, 05:49:56 AM »
When I generate the files, tdpb2day.mg, windrose.mg, windrain2day.mg get a .txt extension when downloading them on my mac, I remove the .txt part before copy them to MeteoHub, but still only 0 kb file size both on FTP and local copy
Bunty
Stillwater marks the spot.
« Reply #24 on: October 17, 2011, 01:42:35 AM »
Marci Anna
As long as you don't use software as elaborate and complex as Weather Display, you should have nothing to worry about.
Page created in 0.118 seconds with 19 queries.
