Author Topic: WxFlash FTP works, but ASP/PHP doesn't  (Read 6346 times)
Offline AzJazz
« on: May 02, 2011, 06:52:00 PM »
I have a GoDaddy Account, and I can get WxFlash to update when I FTP the files up, but no luck when trying ASP or PHP.
Can anyone tell me what am I doing wrong?
AzJazz
Offline jay_hoehn
    • Jay's Woodcrafts
Re: WxFlash FTP works, but ASP/PHP doesn't
« Reply #1 on: May 03, 2011, 12:53:26 PM »
Make sure you are updating to the correct location in VWS.  Also make sure you put the "?" at the end of you submit script. ex: http://www.yourgodaddy.com/weather/scripts/submit.php?
Also remember you were supposed to rename the submit.php script.
Jay
Davis Vantage Pro2 Plus
VVP
Weather Display
Offline AzJazz
« Reply #2 on: May 04, 2011, 07:39:03 PM »
Hi, Jay!
Yep ... I have the "?" at the end of my ASP submit script line in VWS.
I tried renaming the script on the website (and in VWS), and saw no difference. Also, I tried editing the ASP script on the website to have the same User ID as VWS (I modified the "DEMO" value in the ASP script to match the User ID field value in the VWS WeatherFlash window).
I'm sooo cornfuzed!
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #3 on: May 05, 2011, 10:57:25 AM »
AzJazz,
Are you sure your host supports ASP.  Who is the host?
Jay
VVP
Weather Display
Offline AzJazz
« Reply #4 on: May 09, 2011, 02:13:50 AM »
Hey, Jay -
My host is GoDaddy.com. According to GoDaddy, my configuration is: ASP.Net 2.0/3.0/3.5 and PHP 5.x
I still haven't figured out what is going wrong with VWS / WxFlash yet.
I must be doing something really goofy, but I can't figure out what.
AzJazz
« Last Edit: May 09, 2011, 02:15:54 AM by AzJazz »
Offline Jumpin Joe
    • Joe’s Weather
« Reply #5 on: May 18, 2011, 12:06:42 AM »
I am having a similar issue.
I just setup WxFlash and it seems to work.... problem is when you click on Weather Flash in my fly-out menu it fills the screen and to get back to my home page I have to click on the back button on the browser.
http://www.joesweather.info/wxindex.php
I believe it has to due with the screen size but have no idea where to fix it.
Any suggestions?
Joe
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #6 on: May 18, 2011, 09:17:58 AM »
Any suggestions?
Joe
Not the same at all Joe. Your Weather Flash install is updating just fine.
The issue you are having is how the scripts that run your site interact with Weather Flash when launched from your side menu. Weather flash is working fine.
Bob
Offline Jumpin Joe
    • Joe’s Weather
« Reply #7 on: May 18, 2011, 10:02:45 AM »
Thanks Bob... Would you happen to know how to resolve the size issue? Which scripts and which settings?
Joe
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #8 on: May 18, 2011, 01:44:52 PM »
AzJazz,
Sorry I did not get back to you I had a issue with my table saw and injured my thumb.  Are you still having issues with the WeatherFlash updates?
Jay
VVP
Weather Display
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #9 on: May 18, 2011, 09:44:11 PM »
AzJazz,
Jay
It would be in your Carter Lake PHP scripts and I would assume the WeatherFlash script also. I have never used the Carter Lake scripts, so haven't a clue what to do there.
Bob
