June 20, 2013, 02:28:28 AM *
Members: 6697  •  Posts: 181466  •  Topics: 18424
Please welcome ThePontificator, our newest member.
Author Topic: Nightime temp error  (Read 2044 times)
merlinwx
Senior Member
« on: January 28, 2011, 11:15:50 PM »
I see a definite trend developing between daytime and nightime temp QC readings.  Daytime readings tract right on top of QC tracks but right at sunset the actual and QC tracks split to about 4.5 degrees difference (actual above QC).  Then before sunrise, QC and actual converge to coincidence.  Anyone else seeing anything like this?
Davis Vantage Pro 2/WeatherLink 5.9.2
WD/VVP/VPLive/StartWatch
WU-KCOCANON7/CWOP-DW5626
jgillett
unnamed weather station, Boltek, Win7 Pro
« Reply #1 on: January 29, 2011, 01:12:36 AM »
Yep. Been seeing that here almost since day-1 (over 4 years now) with my VP2. Finally gave up worrying about it.
W7JKG
DanS
Chiang Mai weather
Online Online
« Reply #2 on: January 29, 2011, 03:00:50 AM »
I see on your CWOP pages that the closest site is 13 miles away and if that's what they use for QC I personally wouldn't sweat it. I also see some other remote possibilities from your station installation pics. The fat tree limb underneath and/or the huge stones on the ground below could retain heat from the daytime sun.?.? If you really have a problem with it you could try a temporary relocation to another area free of these possible 'heat retainers' to see if the QC temp charts change.
Here is my CWOP temp graphs with one sensor (DW2642) mounted next to the house (north side under an overhang). The DW4009 sensor is out in the open with grass below and nothing nearby that holds the days heat like the house obviously does here. VTCC is the nearby airport.
My 2 bucket tips worth.
« Last Edit: January 29, 2011, 03:33:22 AM by DanS » Logged
Dan ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
ocala
« Reply #3 on: January 29, 2011, 06:31:44 AM »
I agree with Dan I wouldn't sweat it either. It's just the micro-climate for your area.
Below is my graph for 3 days. You can see I'm below the other stations in the area at night. It's been that way for 5 years.
Oh yeah, interesting installation there on the tree. I have never seen a station mounted on a tree.
« Last Edit: January 29, 2011, 06:35:43 AM by ocala » Logged
merlinwx
Senior Member
« Reply #4 on: January 29, 2011, 10:13:38 AM »
I think you're right about micro-climate.  There is a neighbor VP2 station about a mile down the road at the same elevation (non reporting station).  I've been comparing my data with his and we seem to be tracking within .5 degree.  Researching the reporting stations around my area, looks like the same thing happens at night just to a slightly lesser degree.  I still find the phenomenon interesting...makes you wonder about the QC algorithms MADIS uses.  Don't think I'll worry about it...I'm probably closer to truth than MADIS in this case.
ocala
« Reply #5 on: January 29, 2011, 03:22:09 PM »
All MADIS can go by is what's reported to them. They don't check each station for the correct installation.
A station that has sensors mounted over asphalt  or concrete on a hot day is going to be different then one mounted over grass. Also, said station is always going to be an outlier in regards to data. That is going to throw off  the QC analysis. Even if all the stations around you are mounted correctly their differences in elevation will affect the temp reading. Don't get caught up in getting two thumbs up for your station. You just need to know that your set up is correct. Judging by your post here you already do. Smile
Stetson1
Stetson Hills Weather
« Reply #6 on: February 28, 2011, 06:07:06 PM »
Closest station to me is 2 miles away and 2 hundred feet higher. We track pretty close but the overall QC is off by 4 degrees every night. The rest of the stations in my area are anywhere from 3.4 to 8 miles away. 2 miles here could mean 300-500 feet in elevation change so I would expect some differences, but seriously 8 miles in my QC is a little over a 1000 feet different elevation wise. In addition, I have a creek that runs behind my house and everyone in the neighborhood knows we have an interesting micro-climate going on.
I used to worry about my ratings and decided that it was a waste of time.
Todd
Weather Underground PWS KCOCOLOR131
MADIS ID: D4524
Page created in 0.217 seconds with 19 queries.
