May 22, 2013, 08:41:57 AM *
Members: 6617  •  Posts: 178546  •  Topics: 18119
Please welcome TheMOX, our newest member.
Author Topic: Startwatch and Virtual Serial Ports Emulator VSPE  (Read 3787 times)
duke666
Contributor
« on: March 06, 2011, 02:58:10 PM »
Is any one using VSPE from Eterlogic with startwatch?
I am asking because although the emulator works flawlessly with VVP and my weather software, I cannot get startwatch to start VSPE because when you save the paired port configuration it saves it as a .VSPE file and from what I know startwatch will only start .EXE.
Duke
Davis VP2 - 24hr FARS, Cumulus weather software.
Nightingale Weather PHP
Garth Bock
Bloomington, Illinois Weather
I went dark to protest SOPA
« Reply #1 on: March 06, 2011, 04:36:19 PM »
Is it possible to parse your file on a command line for Startwatch ? That is  vspe.exe /filelocation/filename.vspe  .... and let StartWatch execute that line ? Sorry just guessing here. I dont run StartWatch but like Windows Startup you can have the .exe call its associated config file if it is not a defaulted name but putting the file to open after the execution call.
Davis VPro2,VWS,WL,VVP,WD,WDL,Cumulus,WV32,VPLive
duke666
Contributor
« Reply #2 on: March 07, 2011, 02:31:13 PM »
Thanks for your suggestion - but no luck. I'll keep trying though.
Thanks.
Duke
up10ad
« Reply #3 on: March 07, 2011, 03:11:20 PM »
I run it at windows startup.  Here is the information from the help file:
Autorun: command line shortcut
If you want to automatically load virtual devices configuration at Windows startup, please follow the steps shown below:
Step 1.
Create configuration and save it using "File => Save as..." command. Remember config file location (for example it can be c:/config.vspe)
Step 2.
Create windows shortcut. If you have installed VSPE at default location ("C:\Program Files\Eterlogic.com\Virtual Serial Ports Emulator") shortcut parameters must be as shown below:
Target: "C:\Program Files\Eterlogic.com\Virtual Serial Ports Emulator\VSPEmulator.exe" -minimize -hide_splash c:/config.vspe
Start in: "C:\Program Files\Eterlogic.com\Virtual Serial Ports Emulator"
Rick
Have you joined USAWeatherFinder.com yet?
duke666
Contributor
« Reply #4 on: March 09, 2011, 02:11:27 PM »
Yes that starts it but doesn't get round the problem of StartWatch being able to start it and therefore monitor and restart it if required when I am away.
I have sent an email to support as they recommend this driver but I have not heard back yet.
Duke
Bushman
« Reply #5 on: March 09, 2011, 02:20:11 PM »
Just a crazy thought:  compile the batch file (with .vspe flag) into a .exe and have SW  monitor that.
whitenemesis
Senior Member
« Reply #6 on: March 09, 2011, 03:03:52 PM »
I had the same problem getting VSPE to load the configuration file on start-up until I put the file in root C: any sub folder wouldn't work
c:\config.vspe -minimize -hide_splash
Now it all starts up ok loads the config file and minimises without showing the splash screen
Sorry, should have said the above is n the Params field of the VSPE program options within Startwatch
« Last Edit: March 09, 2011, 03:06:03 PM by whitenemesis » Logged
up10ad
« Reply #7 on: March 09, 2011, 03:15:16 PM »
I guess I don't see the point of having StartWatch 'watch' the VSPE.  It is a low-level driver as opposed to an interactive program, and shouldn't need and perhaps even shouldn't be subjected to monotoring.
Rick
Andy Thompson
Andy's Live Weather Stations
« Reply #8 on: March 09, 2011, 11:15:36 PM »
I am using the com0com driver with my operating system. But it only works with the 64-Bit.
Regards,
Andy Thompson
www.madeliasliveweather.com
duke666
Contributor
« Reply #9 on: March 10, 2011, 01:56:52 PM »
Thank you all for your help and suggestions but whitenemesis has solved my problem, thank you, all works perfectly.
Duke
whitenemesis
Senior Member
« Reply #10 on: March 10, 2011, 02:17:18 PM »
Duke
Pleased it worked for you!  Very Happy
Page created in 0.085 seconds with 19 queries.
