May 23, 2013, 04:47:58 AM *
Members: 6617  •  Posts: 178633  •  Topics: 18128
Please welcome TheMOX, our newest member.
Author Topic: Questions  (Read 2871 times)
chief-david
Educational Weather
Space Academy for Educators
« on: January 31, 2011, 10:15:59 AM »
I just signed up and set up CWOP.
DW6947
How is an easy way to check if every thing is getting trough,.
A lot of documentation for a Monday.
WL log says successfully uploaded APRS.
http://www.findu.com/cgi-bin/find.cgi?call=DW6947
I did have to change the port to 23.
« Last Edit: January 31, 2011, 10:18:21 AM by chief-david » Logged
Vantage Pro Plus 6163
Wunderground KMNMINNE28
CWOP DW6947
Midwesternweather.net
twitter @RMSWeather
Facebook
Skywarn Stormspotter
http://weather.rms.rdale.org/
SlowModem
WX @ 26.4 kbs
« Reply #1 on: January 31, 2011, 11:03:55 AM »
DW6947
I don't see anything on the link above.
You can try looking at this link to see if any data is getting through:
http://www.findu.com/cgi-bin/rawwx.cgi?call=DW6947
It lists the raw data from your computer going to cwop.
You may have a coordinate or id or password entered wrong somewhere.  Or it may just take a day or so to get you entered into the system.
Good luck!
« Last Edit: January 31, 2011, 11:06:20 AM by Slow Modem » Logged
Ten Mile, TN
http://wattsbarweather.net
wuhu_software
« Reply #2 on: January 31, 2011, 11:48:46 AM »
Try port 14580.
chief-david
Educational Weather
« Reply #3 on: January 31, 2011, 12:12:31 PM »
I will let it run for a day and see what happens
If not, I will try a different port
It is set up for every five minutes.  Is that ok or should it be different?
CWOP DW6947
twitter @RMSWeather
Facebook
wuhu_software
« Reply #4 on: January 31, 2011, 12:37:05 PM »
5 is good, 10 is also fine.
The main database is sent out every 15 mins from findu.
chief-david
Educational Weather
« Reply #5 on: January 31, 2011, 04:19:47 PM »
She's in!!!!!
CWOP DW6947
twitter @RMSWeather
Facebook
SlowModem
WX @ 26.4 kbs
« Reply #6 on: January 31, 2011, 04:24:02 PM »
Great!   Applause
I see it here:
http://www.findu.com/cgi-bin/wxpage.cgi?call=DW6947
Ten Mile, TN
chief-david
Educational Weather
« Reply #7 on: January 31, 2011, 06:11:35 PM »
My question to myself
Why didn't I do that three years ago?
CWOP DW6947
twitter @RMSWeather
Facebook
DanS
Chiang Mai weather
Online Online
« Reply #8 on: January 31, 2011, 06:57:53 PM »
I glimpse the " Neighboring Stations " section at the bottom daily to give a quick check of my stations health. Wink
Dan ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
ocala
« Reply #9 on: January 31, 2011, 07:21:23 PM »
Chief I believe the folks at CWOP had requested a while back that your update time be an odd number like 7,11, 13 etc. They had said the reason was because everyone was uploading at 5, 10, and 15 minutes which really taxed their servers. The whole idea was that while everyone wouldn't change their update interval those that did helped the system handle everything better.
chief-david
Educational Weather
« Reply #10 on: February 02, 2011, 10:23:53 AM »
WL only has five minute increments.  d'oh!
Is that what the offset time is for?
CWOP DW6947
twitter @RMSWeather
Facebook
JACK10562
DW5051
« Reply #11 on: February 20, 2011, 04:45:50 PM »
For example if you have ten minute upload frequency and have the offset for 1:03a, (for instance) then uploads will occur 3 minutes after the ten minute period, at:
1:03
1:13
1:23
1:33
1:43 and so on, throughout the day
CWOP redistributes your data. Check out MesoWest for your data and that of surrounding stations.
You can save profiles of different / favorite areas to view.
http://mesowest.utah.edu/cgi-bin/droman/mesomap.cgi?profile_id=FTME7Wk926JiQAZ
Here is the NOAA MADIS surface data map:
http://madis.noaa.gov/sfc_display/
Left Click and drag to zoom in on the map for more local detail.
Right click and drag for distance measurement between points.
More stuff to do, just in case you were all caught up! Cool
« Last Edit: February 20, 2011, 05:25:06 PM by JACK10562 » Logged
CWOP:DW5051
MADIS ID:D5051
WU:KMAEASTH4
CoCoRaHS:MA-BA-23
DavisVantagePro2Plus#6163
Cumulus 1.9.3(1059)←☼
chief-david
Educational Weather
« Reply #12 on: February 23, 2011, 09:40:03 AM »
just one issue with WL and CWOP
In WL internet settings, I had to turn on  "Internet Transfer Enabled"
Now it leaves an error that says  "error connecting to the FTP server (87)
It is always connected to the net- by network access-school access.
2. Does INTERNET TRANSFER ENABLED have to be on for CWOP  to work?
CWOP DW6947
twitter @RMSWeather
Facebook
Page created in 0.118 seconds with 19 queries.
