June 19, 2013, 09:50:53 PM *
Members: 6697  •  Posts: 181439  •  Topics: 18420
Please welcome ThePontificator, our newest member.
Author Topic: VVP--Protect console...  (Read 1235 times)
merlinwx
Senior Member
« on: January 24, 2011, 10:42:49 PM »
On the VVP communications settings page, what are the "protect console" boxes for and when should they be checked?
Davis Vantage Pro 2/WeatherLink 5.9.2
WD/VVP/VPLive/StartWatch
WU-KCOCANON7/CWOP-DW5626
Andy Thompson
Andy's Live Weather Stations
« Reply #1 on: January 24, 2011, 10:52:36 PM »
I think its for if you are sending data over a public network, and you don't want anyone else logging into your console. I think thats what it does...
Regards,
Andy Thompson
www.madeliasliveweather.com
linuxfreak
Hamilton Central Mountain Weather
Contributor
Wink, wink!
« Reply #2 on: January 25, 2011, 05:54:26 AM »
It stops a piece of weather software from sending "bad" commands to the console, like writing to the EEPROM memory!  d'oh! Sorta turns that port into "read only".
George
George
Davis VP2/FARS, VVP, WD, WL, WSWin, Cumulus, NexStorm, StrikeStar, NSLog, XPort(GPS), WASP2, DigitalAtmosphere, ScannerCast(WUradio), Intel Atom N330 dual-core, 2Gig ram, Windows XP Home SP3  d'oh!
CWOP - DW3112, PWS & WU - IONHAMIL2, AWEKAS - 5112, CWON, WML - WD01901
tinplate
Moderator
« Reply #3 on: January 25, 2011, 09:35:23 AM »
Yes, the protect console feature is for when you have the virtual console ports exposed to the internet when you want to connect to the station remotely. It tells VirtualVP to quietly ignore commands that change anything in the console such as setting the time, calibrating the sensors, writing to EEPROM, etc. It makes the virtual console "read-only".
merlinwx
Senior Member
« Reply #4 on: January 25, 2011, 09:14:02 PM »
Ok, think I get it now.  So, I should check the 'protect console' box next to any weather SW I'm using to send data to the internet, e.g., WD messages to twitter and WU, and VPLive messages to CWOP/APRS?
tinplate
Moderator
« Reply #5 on: January 26, 2011, 02:28:43 AM »
When you really want to use "protect console" is when someone can connect directly to a VirtualVP port from the internet. Usually you have to have your computer connected directly to the internet (not behind a router), or if it's behind a router, you will have had to set up the router to forward port requests to the computer running VirtualVP. You don't need it if your weather programs are just sending data out to the internet.
Page created in 0.195 seconds with 20 queries.
