Author Topic: VWSaprs version 2 has been released  (Read 56808 times)
Offline racenet
  • Moderator
    • NH Weather Data
Re: VWSaprs version 2 has been released
« Reply #50 on: January 22, 2011, 07:30:31 AM »
Humm, all appeared to be working fine, but not this morning.
The temps are not being sent correctly. We are currently at -10. The CWOP data screen shows the correct values, but it is sending 0 as the temp. Looking at my overnight data, it appears that 2.0.0.7 starts sending nd contunues to send 0 as soon as the temps hit the - values.
My site is CW1773
Bob
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #51 on: January 22, 2011, 07:40:20 AM »
Fell back to 1.9.8 and the temps are being sent fine.
Bob
Offline up10ad
  • USA Weather Finder
  • Station will be back up someday...
    • Forecaster without a site
« Reply #52 on: January 22, 2011, 09:34:01 AM »
Dr. Tim,
Really appreciate the update, it is working fine for me so far.  I'll monitor and post as needed.
Rick (K6DYC)
Have you joined USAWeatherFinder.com yet?
Offline Meteorologica
« Reply #53 on: January 22, 2011, 11:17:55 AM »
Bob, there is a later version that should fix the negative temperatures. We spotted that one yesterday!
« Reply #54 on: January 22, 2011, 11:22:23 AM »
Do I now set the altitude in console and in VWS Software
Yes
Do I correct it in console or in the VWS Software
Console
Do increase or decrease to correct it? http://weather.gladstonefamily.net/site/C4784?tile=10;days=1.5#Data
Increase your console's pressure by the looks of it
Will it fix it on its own?
No
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #55 on: January 22, 2011, 03:19:23 PM »
Thanks Tim. I will install that tonight and see what happens.
Bob
Offline NDSWeather
  • NDS Weather - Ken Caryl Colorado
« Reply #56 on: January 22, 2011, 05:34:00 PM »
Yes Done, Now I will wait 24 Hours
Console Will Wait 24 Hours
No
Thanks, Will give it a try
6153 Davis Wireless Vantage Pro2 FW 1.90 Serial Port
VWS 14.01p48b / ImageSalsa 2.0.13b Weather Edition / WeatherLink 6.0.0
VWSaprs 2.0.1.0 KCOLITTL9 CW4784
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #57 on: January 22, 2011, 10:00:53 PM »
Installed it and nope, not fixed. - temps still show 0. The only difference now is, it shows 0 in both the CWOP data screen and what it sends to CWOP. Before, it did show the correct temp on the data screen.
Dropped back to 1.9.8 and the temps are correctly sent.
Bob
« Reply #58 on: January 23, 2011, 04:36:56 AM »
Okay, I'll take another look. Thankfully we never get that cold here  :grin:
« Reply #59 on: January 23, 2011, 05:59:12 AM »
Okay Bob, can you give 2.0.0.9 a go. It seems fine with simulated data.
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #60 on: January 23, 2011, 11:45:42 AM »
Will do. It will  really get a test tonight.  ;)
Offline GWBF5
« Reply #61 on: January 23, 2011, 12:50:39 PM »
Hello everyone,I would like to share my experience with VWSaprs.
I own a desktop that runs on windows 7 64 bit.
I use wlink/dlogger 5.8.2
        VWS 14.01p33
         WUHU 1,0,216,173
I am using VWSaprs2.0.0.0 download
VWS and VWSaprs are both set to  deg f,mph,inhg,altft,rainin
                                                datbaseupdate timer and VWSaprs send rate are both set to 10min.
when i downloaded the program i replaced 1.98 with 2.0.0.0
I have not had one glitch yet.
My one issue was when restoring the program from the task bar and going to the stat or vws info page it came up blank.I quickly reloaded the program and figured those parameters are set and to leave those two pages alone.The report page comes up everytime on restore.I had a minimum temp of -0.5 this morning which registered as 0 which is ok.My fear is should i update to the latest version or leave well enough alone.I like having software up to date.
Also as a side note i believe wxreport.txt file was also uploading windspeed and gust in knots.I like the fact it uses the database.
                                                         Thank you
Offline NDSWeather
« Reply #62 on: January 23, 2011, 01:37:09 PM »
        VWS 14.01p33
         WUHU 1,0,216,173
My one issue was when restoring the program from the task bar and going to the stat or vws info page it came up blank.                                                         Thank you
This will go away with 2.0.0.9
You also do not say what Weather Startion Hardware you have nor do you have your Profile Info filled in.
I would like to see your stats for your station. Who do you upload to, do you have a web site?
NDS Weather
Offline GWBF5
« Reply #63 on: January 23, 2011, 02:14:49 PM »
Sorry about that Doh...
My weather equipment is Davis WeatherMonitorII complete with a USB connection from the datalogger to the computer.
I upload to CWOP(DW2489),Weatherunderground(KNYSARAT7),AWEKAS,WEATHERBUG and PWSweather.com.I don't have a website as of the present.I use VWS for CWOP and WeatherUnderground.I use a csv file generated by VWS for AWEKAS,Weatherbug and PWSweather.com.I have to explore the profile area and update it eventually.
        Thank you
Offline GWBF5
« Reply #64 on: January 23, 2011, 08:43:50 PM »
I will have to update to 2.0.0.9 my temp of -2 degrees is registeri ng as 0 degrees.not good....owise it ran quite well
Offline racenet
  • Moderator
    • NH Weather Data
« Reply #65 on: January 23, 2011, 09:05:16 PM »
Yes, 2.0.0.9 takes care of the - temp issues. Has been working well here all evening. Will keep an eye on it as the temps fall. Expecting well below -20 tonight.
Sure glad it is now working correctly. Thanks Tim!
Bob
Offline GWBF5
« Reply #66 on: January 23, 2011, 09:10:39 PM »
version 2.0.0.9 took care of the temp issue but 1 don't see the date and the zulu time on the raw aprs file.Is that a bad thing.
no more blank screens either.my current temp is -3 degrees.waiting for double digit below zero to see if all goes well
« Reply #67 on: January 24, 2011, 01:56:10 AM »
We no longer send the date and time as its tagged on automatically when the aprs servers receive it. They completely ignore the time we send thm so there is no point sending it!
Offline Petaris
    • Frederic School District
« Reply #68 on: January 26, 2011, 09:29:29 AM »
After upgrading from 2.0.0.6 to 2.0.0.9 it seems I am no longer sending data to APRS.  Is there a way to make it try to send immediately?  Or a log so I can see what the issue is?
- Petaris
"The World is Open.  Are You?"
DW6850
RainWise MK-III RTI-LR
VWS 14.01
VWSaprs 2.0.0.9
ImageSalsa 2.0.13
« Reply #69 on: January 26, 2011, 09:36:30 AM »
Try unticking the minimise box, another user had this as a solution.
Offline Petaris
« Reply #70 on: January 26, 2011, 09:52:02 AM »
I didn't have the minimize box ticked.  Any other ideas?
Running on WinXP Pro by the way.
- Petaris
DW6850
VWS 14.01
VWSaprs 2.0.0.9
ImageSalsa 2.0.13
« Reply #71 on: January 26, 2011, 09:53:36 AM »
Please contact us directly and we will go through a debug routine with you. sales at meteorologica.co.uk
Offline Petaris
« Reply #72 on: January 26, 2011, 10:18:07 AM »
OK, I sent an email with the details.  Thanks for helping out!  :)
- Petaris
DW6850
VWS 14.01
VWSaprs 2.0.0.9
ImageSalsa 2.0.13
« Reply #73 on: January 26, 2011, 04:47:14 PM »
So, now you figured out your weather station's clock was wrong, is VWSaprs working for you?
Offline Petaris
« Reply #74 on: January 28, 2011, 12:32:48 PM »
Yeah, it started working again.
Everything seems fine now.
Thanks!  :)
- Petaris
DW6850
VWS 14.01
VWSaprs 2.0.0.9
ImageSalsa 2.0.13
