Author Topic: saratoga tweetwx  (Read 267 times)
Offline txweather.org
    • Texas Weather
saratoga tweetwx
« on: May 16, 2019, 08:27:46 PM »
Does the conditions tweet only work with testtags.php?
I use meteohub, nano sd, and meteobridge could any of this work?
Offline sacreyweather
  • Echo Valley Weather
Re: saratoga tweetwx
« Reply #1 on: May 16, 2019, 09:10:04 PM »
I have been using TweetWX with Cumulus and CumulusMX for sometime now without any issues.
Saline Weather on Twitter
Blitzortung Station 1387
    • Texas Weather
« Reply #2 on: May 16, 2019, 10:32:54 PM »
John, I am not sure I am following... The question is, Can TweetWX use anything other than testtags.php? What are you using to feed data to TweetWX? Is it CUtags.php?
« Reply #3 on: May 17, 2019, 11:28:57 AM »
Yes, you can use it with CUtags.php (and CU-defs.php which convert CU-specific variable names to the expected WD variable names).
Try just changing the include('testtags.php') to include('CUtags.php') and see how it goes...
    • Texas Weather
« Reply #4 on: May 17, 2019, 11:46:23 AM »
Hello Ken,
Thanks for your reply. I no longer use cumulus... I was trying to figure out if it works with any other program. I use Meteohub and meteobridge.
« Reply #5 on: May 17, 2019, 12:43:59 PM »
For Meteobridge (and the Saratoga template), use include('MBtags.php')  .. likewise if Meteohub is used with the Saratoga template, then include('MHtags.php')
    • Texas Weather
« Reply #6 on: May 17, 2019, 01:46:58 PM »
YAY!
Thanks!
