Author Topic: Nano SD Saratoga wxstatus is wrong  (Read 549 times)
Offline txweather.org
    • Texas Weather
« on: May 04, 2019, 01:01:28 PM »
I am using Nano SD and is not reporting the correct uploaded data, file, and model.
https://www.txweather.org/wxstatus.php
Re: Nano SD Saratoga wxstatus is wrong
« Reply #1 on: May 04, 2019, 01:06:50 PM »
According to your Settings-weather.php
$SITE['WXtags']        = './MBtags.php';  // for weather variables
Your MBtags are in your document root.
That file has
date|2013-03-17|// local date:|:
time|13:17:44|// local time:|:
dateUTC|2013-03-17|// UTC date:|:
timeUTC|20:17:44|// UTCtime:|:
so is really the sample file I'd included in the MB-plugin.zip ..
You need to set MeteobridgeNano SD to do the FTP to your site, then status should display correctly.
    • Texas Weather
« Reply #2 on: May 04, 2019, 01:22:18 PM »
That file has
I fix that but is still showing: Meteobridge weather data    NOT Current    170291:21:49    > 0:05:15
11/30/1999 12:00am
    • Texas Weather
« Reply #3 on: May 04, 2019, 01:26:15 PM »
« Reply #4 on: May 04, 2019, 01:27:35 PM »
Ummm, no.. not quite fixed.  The MBtags.php on your site is empty (no contents).
You need to have the Nano reload your tags template from https://www.txweather.org/gen-MBtags.php
And.. I'm not sure the Nano can do https -- you may have to use http://www.txweather.org/gen-MBtags.php after temporarily turning off your http->https redirect on your website.
    • Texas Weather
« Reply #5 on: May 04, 2019, 01:33:13 PM »
Ok, Thanks Ken... The reload work. Things seem to be falling in place....
