I use MT for my website.
It however is not listed. How do I get it listed for use?
Also, it doesn't use GPS properly. May need to set that as a prompt so we can allow it easier.
Hello Jonny,
Your site has been added to the list of beta testers for the App.
If you already installed the app on your phone, go to settings (upper top corner) /Data&Sync and clean the cache to see your site in the list.
If you don't have the app yet, download it from Google Play :
https://play.google.com/apps/testing/com.meteotemplate.meteotemplateDo not forget to download and install the App plugin on your site :
https://www.elspinars.es/dev/appPlugin.zipIf you plan to send notifications to your users, do also install the Triggers Plugin :
https://www.elspinars.es/dev/triggers.zipThere is also a small block you can install on the custom version of your mobile page to promote the app :
https://www.elspinars.es/dev/appBlock.zipAll is available from
https://www.elspinars.es/dev/app.phpI would need more details about the GPS issue you mentionned. When you first install the app, there is an authorization request to use your device's location. If rejected, the app will use a dummy one. You may be able to authorize the location usage again by going to the app settings (on your device, not in the app).
Feel free to ask any question via email or on the forum and do not hesitate to report any bug/issue or to share any idea you have to make this experimental application reach the next stage.
Cheers,
Pol-Brieuc
