Author Topic: Meteobridge upload to more than one MySQL server  (Read 176 times)
Offline lobsterman
    • Cape Small Harbor Weather
« on: April 25, 2019, 09:50:09 PM »
My guess is that the answer to my question is NO, can't be done.
So, is it possible to configure MB to upload to more than one MySQL server?
Offline lobsterman
Re: Meteobridge upload to more than one MySQL server
« Reply #2 on: April 26, 2019, 10:48:21 AM »
https://dev.mysql.com/doc/refman/8.0/en/replication.html
True, replication is likely the answer but I haven't found a tutorial that's at my very low pay grade!
« Reply #3 on: April 26, 2019, 11:45:46 AM »
Another solution is to run the Meteobridge and also run Weather-Display at the same time. Weather-Display can use the Meteobridge as a data source. Then you can configure both the Meteobridge and Weather-Display to both send to two different SQL databases.
Tele-Pole flag pole not up yet
Offline droiddk
« Reply #5 on: April 26, 2019, 12:00:44 PM »
A PHP-script can insert into MySQL so use a HTTP Request. Place the PHP-script on your server and make sure a password is included in the query-string. No/missing password = no insert.
Regards
Davis Vantage Pro2 Plus
WeatherFlow Sky & Air
Ventus W830
