Author Topic: Decimel Degrees in Celsius  (Read 726 times)
Offline greyhame
    • Squirrel Cove, BC Weather
« on: April 20, 2019, 03:17:46 PM »
I know this has been mentioned several times buried in threads, but I wanted to surface it to a full topic. Losing decimal degrees Celsius for Temperature and Dew Point in the new PWS UI feels like a real loss. I am on the west coast of Canada where we hover within decimal degrees of fog and freezing throughout much of the winter. Whole degrees Celsius feels like a large margin of error in reported temperature and dew point. Would really love to see that return to decimals. Attached is a comparison of whole vs. decimal degrees between the old UI and new for April 18 at my weather station.
 [ You are not allowed to view attachments ]   [ You are not allowed to view attachments ]
Offline wxnut99
Re: Decimel Degrees in Celsius
« Reply #1 on: April 20, 2019, 03:36:27 PM »
0.1C resolution is a must for metric users. Considering that the vast majority of the world uses metric for weather observations, it should be a priority. Evidently WU will be going back to that at some point. They have heard the complaints.
The odd thing is WU has 0.1 km/h resolution for wind, and .01 mm resolution for precipitation, which is MORE than needed. Go figure..
« Last Edit: April 20, 2019, 06:31:51 PM by wxnut99 »
Offline QldTech
« Reply #2 on: April 25, 2019, 01:08:00 AM »
I also couldn't agree more - bring back the 0.1C resolution for the temperature. Also in the interests of data quality, I am dumb founded as to why you do the conversion to F for data storage. This is really silly as any data from those weather stations that send them in as Celsius and then converted to Fahrenheit causes loss of data accuracy so in reality significantly degrades the quality of the data.
Offline tombcd
« Reply #3 on: April 25, 2019, 01:20:08 AM »
Guys this is apparently beyond IBM, Deep Blue, Cloud, etc. computing power to calculate decimals so we shouldn't expect that ;).
Enough has been said about the update in general but judging from the whole updating process which was an epic fail/snafu that should go into guides like "How not to update production environment" I'm not even surprised such bugs exist. And yes - things like this should have been rectified in 1 day. They probably have 1 or 2 people working on the project so it is what it is. And not answering support requests is another thing that describes the company.
« Last Edit: April 25, 2019, 01:40:04 AM by tombcd »
« Reply #4 on: April 25, 2019, 03:32:47 AM »
I'm sure this a top priority. Certainly it is higher priority than the webcam issues.
Tele-Pole flag pole not up yet
Offline Tizme
« Reply #5 on: April 27, 2019, 01:50:37 AM »
The problem seems to be the inability of those in charge of the updating to correctly convert between Imperial & metric or appreciate the implications of their actions to date.
Apart from the obvious outcome of dropping the decimal degrees in Celcius, there is also the incorrect use of the metric units commonly used.
The symbol for metre is m not mt;  rainfall is normally measured in mm not cm; no it was not 67C at home this afternoon (18C) and my station is not 1161mt ASL but 353m.
Their navigation is also a little awry as stations in NZ that I checked were all placed around 600 Km out to the East in the Pacific.
So hopefully they get the coding sorted out soon and reintroduce the decimal degrees in Celcius as well.
Offline gvspfc
    • Blumenau/Brazil Wunderground
« Reply #6 on: April 29, 2019, 11:00:17 AM »
Following this topic. I also think this issue has to be a high priority one. For metric, the decimals "tenths" are a must.
Thank you WU guys
Offline wxnut99
« Reply #7 on: May 02, 2019, 12:25:28 PM »
Still no progress on getting 0.1C resolution displayed (both data and graphing)  (Not that I'm using WU anymore to track my data.. I have other software to do that) Anybody hear of anything from WU on when this may be resolved? Not sure why it's taking so long.. how hard can it be to make such a straightforward and much requested change?
Offline TomD
« Reply #8 on: May 04, 2019, 06:46:12 AM »
Temperature is displayed as an integer yet wind speed is shown to the first decimal place. Who or what can measure wind speed with that accuracy and why would you want to?
It seems to me that the variables used to hold these values are incorrectly defined. Temperature should be defined as single precision and wind speed as an integer, Programming 101.
Offline QldTech
« Reply #9 on: May 05, 2019, 10:07:41 AM »
Unfortunately I don't see this being fixed for some time as it will need a complete rewrite of all the variables use for both data ingestion and display. Holy crap what a job.
Someone really should have had a look at the standards for meteorological data and they would have been able to see the following variables, well as specified for a metric system  :lol:
                          ONE SECOND DATA FORMAT.
Ident   Name in Full                         Units                          Format        Value
Tsam    Air Temperature sample        deg. Celsius (C)         *##.#        99.9
Wsam   Wet Bulb Temp sample         deg. Celsius (C)        *##.#        99.9
Hsam    Relative Humidity sample      percent (%)               ###           999
Ssam    Wind Speed sample              knots                         ###           999
Dsam    Wind Direction sample          degrees ()                ###           999
R          Rainfall                                millimetres (mm)       ###.#        999.9
Psam    Barometric Pressure sample  hectopascals (hPa)     ####.#      9999.9
where  "#" / one digit ie. 0 to 9.
"*" / one digit or a minus sign ie. 0 to 9 or "-"
Note: If the sensor is missing or the data is invalid then value is replaced by 9s
« Last Edit: May 06, 2019, 07:53:49 AM by QldTech »
