Author Topic: PurpleAir PA-II and RF noise  (Read 595 times)
Offline torkelmj
    • My weather station, etc.
« on: January 23, 2019, 07:28:32 AM »
A word of warning regarding the PA-II for those hams / amateur radio operators intending to install one:
The PA-II (or the included power supply, I didn't dig further into the issue) generates a huge amount of noise in the RF spectrum.
I operate it of the 230 VAC mains @ 50 Hz and the PA-II renders large portions of the HF radio spectrum useless. The PA-II isn't located anywhere near the antenna or transmission line systems.
Once outdoor temperatures get a bit more friendly I'll try replacing the power supply with  another one to see if it helps.
« Last Edit: January 23, 2019, 10:00:57 AM by torkelmj »
Offline AF6GL
    • Jeffries Ranch Weather Center
Re: PurpleAir PA-II and RF noise
« Reply #1 on: January 25, 2019, 02:08:07 PM »
Thanks for the heads up. Keep us advised of what you find out.
Offline Cetan
« Reply #2 on: February 18, 2019, 02:08:03 PM »
Good find.  I am looking into the PA-II.  I'll hold off until spring.  I working (fighting) with Tesla now about my solar panels - one at a time is enough.  73.  N3QXX
Offline KennyBKK
    • Khu Khot WX Station
« Reply #3 on: February 24, 2019, 09:26:43 AM »
Hi torkelmj,
The power supply refer to is the black one or a new 'Nest' brand?
regards,
Kanok  HS1PDY
Ambient Weather WS-1400
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
Offline n4khq
« Reply #4 on: March 30, 2019, 06:15:38 PM »
Not sure which power supply I have, bought about over a year ago and on 80 meters the noise level goes from S5 to S9 when I plug the purple air into AC power. You found any solutions? I attaches a photo of the power supply
Offline txweather.org
    • Texas Weather
« Reply #5 on: March 30, 2019, 08:09:01 PM »
That's the old power supply and that power supply if I am not mistaken has been recalled.
https://www.purpleair.com/recall
Does not look like the pic but I would still check with Purpleair.
Offline n4khq
« Reply #6 on: March 31, 2019, 08:29:10 AM »
I will check with Purple Air. Thanks
