Author Topic: C84428 Problem  (Read 1605 times)
Offline shirsch
C84428 Problem
« on: November 12, 2017, 02:45:14 PM »
Just got a C84428 to replace my Weather Direct model. Works great and could not beat the $50 price offer from la Crosse. The one issue I have is the time on the station since the time change Day Light Standard time. When I change the time back one hour on the station it goes back after an hour to one hour ahead. I have the View app and tried setting the time zone to central time from eastern time to make up the hour difference but no go. I understand the station connects to the NIST server but the time never changes to Day Light Standard. Any ideas???
Steve
Offline dupreezd
Re: C84428 Problem
« Reply #1 on: November 12, 2017, 03:03:09 PM »
Did you perform this step?
Press and release the CH/+ to toggle the DST (Daylight Savings Time) either ON or OFF. Not every state uses DST. If the Weather Station is in a region without DST, users should turn this setting off. Press down and release the SET button. This will switch the flash to the Radio Controlled Time. Press the CH/+ button to toggle the Radio Control to either ON or OFF. Press and release the SET button. This activates the hour setting.
Davis VP2 6163 | Meteobridge
CWOP - FW0717
Blitzortung 2100
Offline shirsch
Re: C84428 Problem
« Reply #2 on: November 12, 2017, 05:17:06 PM »
My station does not have the CH/+ button just the + button
