Author Topic: Weather Sticker Stopped working.  (Read 424 times)
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« on: July 28, 2017, 06:55:27 PM »
I have made no changes to the Weather Sticker here in the forums or on my website, but they both have stopped working.  I appear to be using the last known version of wxgraphic.php which is 6.3.  I have included copies of both of the files straight from my website plus direct links to the them and PHPinfo.  Any idea what is going on or needs fixed?
www.mountcrawfordweather.org/wxgraphic/wxgraphic.php
« Last Edit: July 29, 2017, 08:32:41 AM by sam2004gp »
Re: Weather Sticker Stopped working.
« Reply #1 on: July 28, 2017, 11:20:51 PM »
The image doesn't show due to an embedded PHP error message
<b>Warning</b>:  imagecreatefromgif() [function.imagecreatefromgif]: Filename cannot be empty in /home/content/s/a/m/samwarren/html/wxgraphic/wxgraphic.php on line 461
Line 461 in wxgraphic.php is
             $ccicon = imagecreatefromgif($vws_icon[$forecast]);
The value for $forecast comes from Line 290:
      $forecast = trim(strtoupper($data[13]));
In config.txt you specified
// THIS IS NOT A URL!!
// if using WD clientraw.txt supply the path to it.
$data_file_path  = 'http://www.mountcrawfordweather.org/VWS/data.txt';
and that should NOT be an URL, but a relative file path like
$data_file_path  = '../VWS/data.txt';
looking at http://www.mountcrawfordweather.org/VWS/data.txt shows
11:10pm,7/28/17,69.3,75.7,69.3,95,67.8,29.76,Falling,0.0,NE,2.49,0.0,,6:16am,8:31pm as the contents.
In it, $data[13] = '';
(or null) and that's causing $forecast to be null and so the lookup for an icon fails and the error message gets generated.
In the stickertags template for VWS, the template is supposed to contain
^vst143^,^vst142^,^vxv007^,^vxv021^,^vxv019^,^vxv005^,^vxv022^,^vxv023^,^vst140^,^vxv002^,^vxv001^,^vxv121^,^vxv003^,^climate_cconds1^,^vst144^,^vst145^ so it is the ^climate_cconds1^ variable that VWS is not processing correctly.
There's a couple of ways to fix this:
1) get VWS to associate a nearby METAR with ^climate_cconds1^  or
2) comment out the code for icon selection in wxgraphic.php
Hope this helps... and THANKS for providing both URLs and copies of the code.  It makes a 1-pass diagnosis possible :)
Best regards,
Ken
BTW:
Looking at your phpinfo, I see:
allow_url_fopen   On
allow_url_include   On
You should set
allow_url_include = off
in your php.ini -- including URLs can provide a path to execute foreign/malicious code on your website remotely.. not a good thing.
Offline sam2004gp
  • Weeeeeeeee!!!!
« Reply #2 on: July 29, 2017, 08:31:43 AM »
 \:D/ THANK YOU VERY MUCH KEN!!!!  \:D/
You gave me enough info to figure out what I needed to change....
So with all the Wunderground changes lately, many of their functions like NWS alerts, Almanac and Current climate conditions no longer work with VWS. So I had stopped the automatic update of VWS going out to the internet and retrieving that data.  And since VWS is no longer being updated, I was basically S.O.L.   :evil: ](*,)
However your suggestion to see if I could get the Metar Conditions, did get me to thinking.  The recommended VWS tag to use in my input data file was ^climate_cconds1^ but by changing it to the "weather" tag for my Metar Station of KHSD which is ^mtr014KSHD^ brought it back to me.
Now I only wish, that VWS gave me a tag to output a text version of VWS's Smart Forecast Function, which I use for my weather icon on the my main page, then all would be perfect.   ](*,)
Offline sam2004gp
  • Weeeeeeeee!!!!
« Reply #3 on: July 29, 2017, 10:12:21 AM »
*** UPDATE  ***
...But then Metar variable I choose above does not always have a value and returns a NULL value on occasion(We have some changing weather today), making my problem occur again. But then I noticed a 2nd variable that VWS returns for the Metar that always has a value but not as "weather condition" accurate as my first variable.  So therefore I added the additional Metar data variable into the array of the Data.txt and then added a clever little if then statement in the PHP code of wxgraphic.php, in case of NULLs.
.... thank goodness for my coding days of Pascal and Basic from 25+ years ago.
 \:D/
