Author Topic: NOAA RADIO HARDWARE  (Read 5177 times)
Offline DW7240
    • The Vicarage Weather Feed
NOAA RADIO HARDWARE
« on: March 30, 2017, 11:05:26 AM »
Everyone using NOAA Weather Radio please reply with what current hardware you use to receive these broadcasts.  I know that Mike (Cutty Sark Sailor) would like to compile this information into a list for new and future users to determine what hardware to use to obtain these broadcasts.  Information such as radio make / model, and any other types of interface including the new USB type Dongle receivers etc.  Also include any information on external antenna / indoor whips etc.
With regards to Randy's (Valentine Weather) reply on the other Wxforum post - NOAA WEATHER RADIO by Mike, (and from which this new thread was started - ALL CREDIT TO Randy for asking the question, I have only started the new thread), you can also submit along with radio types, the encoder your using, and whether your including the stream on your website.  Any other reverent information you think would help a newbie, PLEASE INCLUDE, use Mike's input as an example....
Thanks in advance.
Nick. dw7240.com.
« Last Edit: March 30, 2017, 06:58:34 PM by DW7240 »
Offline Andy G
    • SunPrairieWeather.com
Re: NOAA RADIO HARDWARE
« Reply #1 on: March 30, 2017, 11:33:07 AM »
Here Goes
My hardware is a Bearcat SC-150 Sportcat scanner witha a Diamond D130J Super Discone Antenna. I already had the antenna for my scanners it was a huge upgrade from the stock antenna.
~Einstein
Davis VP2 24 FARS
Offline 92merc
  • BismarckWeather.net
« Reply #2 on: March 30, 2017, 11:34:16 AM »
Bismarck, ND  -  WXL78
Using a NooElec SDR radio in conjunction with a Raspberry Pi2.
Antenna is the fixed length black one included with purchase.  I was close enough to tower that an external wasn't needed.
http://www.nooelec.com/store/nesdr-smart.html
Offline Cutty Sark Sailor
« Reply #3 on: March 30, 2017, 12:34:51 PM »
Midland WR-300/s with standard slip-rod antenna..
WIN 7, 8, 10 platforms
testing various encoders, settings, etc... testing one home brew ground plane for a distant station.
BUTT, M3W, MIXXX, etc at DynDns.org mounts.
Primary stream on Frankfortweather.us/ noaaweatherradio.org is Broadwave off a 300 on the
brilliant little WIN7 HP S5510F that powers virtually all FrankfortWeather.us. stuff.
« Last Edit: March 30, 2017, 01:07:07 PM by Cutty Sark Sailor »
    • LiVE WEATHER
« Reply #4 on: March 30, 2017, 12:35:23 PM »
I removed my post thought we were doing a streaming setup.
Added post on other thread: https://www.wxforum.net/index.php?topic=31396.400
Reply #420
« Last Edit: March 30, 2017, 03:37:49 PM by ValentineWeather »
« Reply #5 on: March 30, 2017, 01:08:11 PM »
Shoot... I thought what you had was cool... :eek:
Offline tim273
« Reply #6 on: March 30, 2017, 01:11:02 PM »
Computer: Raspberry Pi 3 with Raspbian Jessie - perfect for running 24/7 without the issues that Windows sometimes has, plus very low power.
Radio: NooElec Mini 2+ TCXO: http://www.nooelec.com/store/sdr/sdr-receivers/nesdr/nesdr-mini-2-plus.html along with the metal enclosure: http://www.nooelec.com/store/nesdr-enclosure-206.html
Antenna: Coax cable with 17 1/2 inches of the jacket stripped off (to expose 17 1/2 inches of bare inner coax wire) and mounted in the attic.  I have the tools to make my own coax cable so I just put an F connector on one end and then ran the coax up to my attic with the stripped end and mounted it up there.
Adapters: To hook from the coax to the RTL SDR, I purchased two adapters, this one: http://www.nooelec.com/store/male-mcx-to-male-sma-pigtail-rg316-0-5-length.html to and this one: https://www.amazon.com/DHT-Electronics-coaxial-adapter-female/dp/B00CVTRGIC
Streaming Software: RTL SDR (https://github.com/osmocom/rtl-sdr) and Darkice (http://www.darkice.org/ and https://github.com/rafael2k/darkice)
A guide to set up the Raspberry Pi and RTL SDR is here: http://www.wxforum.net/index.php?topic=31582
In the past I've used a Reecomm R-1630 with a Raspberry Pi, Darkice and this sound card: https://www.amazon.com/Behringer-UCA202-BEHRINGER-U-CONTROL/dp/B000KW2YEI and this adapter https://www.amazon.com/gp/product/B0052A2LYG along with a pair of RCA cables.  I actually found a mono 3.5mm to dual RCA splutter, it may have been at Radio Shack before they stopped selling that stuff but I can't seem to find another one like it.
For hooking the coax antenna cable to the radio antenna RCA connector, I needed one of these: https://www.amazon.com/Coaxial-Adapter-Female-Male-Style/dp/B000AAL4PA
Bonus Item:
Uninterruptible Power Supply (UPS): https://www.samsclub.com/sams/1350-battery-backup/prod8410081.ip  I happen to have a Sams Club membership and saw this one day at the store.  This will keep your stream up and running if there is a power outage, which of course happens when there is severe weather and people need your stream the most!  You'll need to plug your computer, radio (if it's external), and router/modem into it to keep the stream going.  Depending on what kind of computer you have, it will last 30 minutes to a few hours.  On mine, the total load with Raspberry Pi/RTL SDR, modem and router is about 15 watts, so mine should last a couple hours or so.  If you search on Amazon for UPS, you'll find quite a few to choose from.
« Last Edit: March 30, 2017, 01:44:33 PM by tim273 »
Offline DW7240
« Reply #7 on: March 30, 2017, 01:25:06 PM »
Hi Tim.
You've outdone me  :grin: :grin: awesome amount of information there, THANK YOU !!  =D>
Lets get this listing growing !! remember, not expecting everything but the kitchen sink in your reply, as long as the radio in use is listed and has the necessary audio output (ear/headphone socket/RCA connections etc, any other info is a bonus !!  \:D/
Nick. dw7240.com
Offline tim273
« Reply #8 on: March 30, 2017, 01:45:13 PM »
Hi Tim.
Nick. dw7240.com
Thanks!  I try to be thorough and I actually just updated it with a couple more things I forgot.
Offline wxthomson
    • http://www.minnetonkaweather.com
« Reply #9 on: March 30, 2017, 08:16:53 PM »
Bonus Item:
Excellent information.
I may try building one of those.
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #10 on: April 02, 2017, 06:50:15 PM »
My radio and antenna is pushing 30 years old.  I use a Radio Shack Pro 38 scanner that the audio amp failed on 10 plus years ago that I did not want to give up on.  So I disconnected the audio output jack from the audio amp and using a coupling cap wired the audio at the input of the volume control into the earphone jack, then let my computer amplify the signal to the needed level.
The antenna is a Radio Shack discone scanner antenna of the same age that can support transmission on a few bands, well before a couple of the ground plane rods fell off it could.   ;)  I have it on top of a 30' tower.
I use an APC UPS700 to hold power on the scanner, weather station and to charge my work and personal cell and a UPS450 for the DSL modem/router, use the internal battery in the Aspire One netbook that transmits the stream to the net.  The batteries buy me some time but during an extended power outage a Honda EU3000is inverter generator keeps things running until the batteries give out in the phone company remote terminal.
« Last Edit: April 02, 2017, 06:52:49 PM by Mark / Ohio »
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« Reply #11 on: April 02, 2017, 07:05:10 PM »
I had that same radio shack scanner and it has the same problem yours had. But unlike you. I junked mine :-( That is a great idea for yours.
I don't even bother with a UPS. No point out in the country here. if the power is out so is the internet in this town. ;-)
Offline Mark / Ohio
  • Live from Mars!
« Reply #12 on: April 02, 2017, 08:52:47 PM »
I had some concern using that low of a level audio signal input about RF noise from the computer getting into it.  But it has worked well now for several years.  I keep the radio and audio cable off to the side from the computer.  Also found the shortest cable I could find in my junk collection.  It is a mono cable from the radio to a mono to stereo adapter into the computer.  You can see the adapter on the left side below the white USB plug which is my serial to USB adapter for the weather station.  Right side USB cable is my web camera in the window.  The aluminum tray looking thing below the computer is a dual fan laptop cooler.
Those old scanners still show up on eBay.  I believe they were made by Uniden for Radio Shack.
Edit: I should also add I have the antenna lead ran through a surge suppressor with coax cable protection and two separate ground blocks on the cable tying together my electrical house ground and a second external 9ft ground rod.  That antenna picks up some serious static charge during a storm.  One time while disconnecting it at the beginning of a storm from my police scanner I got a zap out of it about the equivalent of holding on to a lawnmower spark plug.   :lol:  Knock on wood the ground blocks and suppressors seem to have worked to keep it bled off and prevented damage to the radio and computer for several years now.  Course that will not stop a direct hit.  I've seen surge suppressors in pieces and melted after direct hit.  Thus why I would like to get the antenna for the radio into the attic at some point since it needs to run 24/7.
« Last Edit: April 02, 2017, 09:15:35 PM by Mark / Ohio »
Offline Sooner Al
  • Old enough to know better...
« Reply #13 on: April 28, 2017, 04:24:04 PM »
RadioShack Weather Alert Clock Radio with SAME, model 1200996...
Retired NWS ESA/ET
Sys: Davis VP2 (Wireless)
    • LiVE WEATHER
« Reply #14 on: April 28, 2017, 04:49:54 PM »
If anyone is broadcasting radio for website feed and notice hum when plugged into AC power this little gadget eliminated the hum for my setup.
Its a ground loop isolator.
https://www.amazon.com/Mpow-Ground-Isolator-Stereo-System/dp/B019393MV2/ref=sr_1_2?ie=UTF8&qid=1493412310&sr=8-2&keywords=hum+eliminator
Offline Shino353
« Reply #15 on: January 01, 2018, 11:10:18 PM »
All I have is this old Midland model:13-901
Offline blacklistedcard
« Reply #16 on: April 09, 2018, 02:12:00 AM »
I have the same radio.  Picked it up for$10.00
Offline Felix1
  • PhD Engineering Physics
« Reply #17 on: April 09, 2018, 04:42:51 AM »
Sangean CL-100 with external antenna
S.A.M.E. Table-Top WX Hazard Alert w/AM/FM-RBDS Alarm Clock Radio
Offline Rovingnome
« Reply #18 on: November 02, 2018, 03:45:21 PM »
Offline Rovingnome
« Reply #19 on: November 02, 2018, 03:45:56 PM »
Offline Rovingnome
« Reply #20 on: November 02, 2018, 03:47:43 PM »
Realistic 12-140 Weather Alert Radio
Realistic 12-143 pocket weather alert radio
Got these radios in 1990, our NWS operate on 162.475mhz, so I use these....
Offline PaulKTF
« Reply #21 on: November 22, 2018, 10:29:08 AM »
I have a few Reecom R-1650 models. I like them because they're easy to set up and program, dependable, support S.A.M.E, and (unlike the Midland WR-300 models I was using before) they observe the EOM (End Of Message) signal. This model also has an AM/FM radio with options to preset stations.
I have a few of them scattered around the house and I'm very happy with them. It's the model I would recommend for home use without hesitation.
« Last Edit: November 22, 2018, 10:33:56 AM by PaulKTF »
-Paul.
Offline W Thomas
  • Welcome To Life In The High Country!
    • Smyth Weather
« Reply #22 on: November 28, 2018, 10:41:30 PM »
I have been programming the NWR frequencies into my Harris M7100 console setup and using a 5/8 wave base antenna. Programmed one group to decode and another group to scan and monitor. Worked real well at the other location and had great audio for streaming but since we moved into this hollow of sorts the reception is hit and miss even with the preamp enabled. May try a yagi when I can and hopefully it will be more reliable. The test alert sounded today for the first time in several weeks hopefully I can improve on that :-)
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
